Ode to FGT; a refresh story
Discussion in '1st Gen Tundras (2000-2006)' started by KNABORES, Jun 20, 2024.
  1. Nov 20, 2024 at 3:07 PM
    #241
    KNABORES [OP] Sarcasm incoming
    The Maxlife works for Dex IV. My transmission uses DexIII
  2. Nov 20, 2024 at 4:11 PM
    #242
    Also did the electrical tape wrap on all the door strikers. Eliminated the clunky sounds when driving on bumpy roads. Nice and quiet inside.
  3. Nov 20, 2024 at 4:12 PM
    #243
    We have the same transmission. I remember this debated at length on here before and ultimately I came to the conclusion that Maxlife was fine. Hope so. I've been running it in my truck for 5 years now.
    MT-Tundra and 455h0le_dachshund like this.
  4. Nov 20, 2024 at 4:13 PM
    #244
    Maxlife may be backwards compatible. Not sure.
  5. Nov 20, 2024 at 4:13 PM
    #245
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    x2 :anonymous: 3ish yrs
  6. Nov 20, 2024 at 4:25 PM
    #246
    BroHon likes this.
  7. Nov 20, 2024 at 5:02 PM
    #247
    shifty` You can call 1 (800) PP5-1-DooDoo
    All DEX fluids are reverse-compatible by standard.
    G_unit3000 and 455h0le_dachshund like this.
  8. Nov 25, 2024 at 8:07 AM
    #248
    Added some loops to my roof rack attachments inside so I can bungee some fishing poles up there. Loops are paracord.
  9. Nov 25, 2024 at 6:36 PM
    #249
  10. Nov 25, 2024 at 6:38 PM
    #250
    Rip some lips!
  11. Nov 30, 2024 at 12:53 PM
    #251
    New tow hooks have arrived. These things are beefy. Built for Ford F150s. Front bolt lines up great, back hole is more of a large slot, the bolt falls within the large slot. Will need a piece of flat bar to cover the slot when installing. Have to trim the small plastic wing shields coming off of the skid plate. Have to trim the edge of the skid plate. Mocked up with the bolts just letting it hang, should work out great.
  12. Nov 30, 2024 at 1:25 PM
    #252
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Holy shite those are beefy! :thumbsup: and perfectly color accented :rolleyes: Nice
  13. Dec 2, 2024 at 7:50 PM
    #253
    Got the tow hooks mounted. Involved some mild trimming of the lip of the skid plate next to the tow hook mounts. Also trimmed the plastic wing openings to accommodate. Used the factory tow hook on the drivers due to the bolts being long. Will swap for shorter bolts later. Passenger side has a plate steel bracket from my old bull bar that I modified to use as the mounting plate to cover the larger rear bolt opening on the F-150 tow hook mounts. Turned out good. Will revisit the tow hooks when I refinish the front bumper and skid plate.
  14. Dec 2, 2024 at 8:24 PM
    #254
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Were you missing the OEM loops they used to transport the trucks on trailers?
    Initially that's where I put my shackles. Even after I got my Coastal bumper, I left em there until I realized it had spots for em that were kinda hidden.
    Looks good thought.
    Weagle and Fobroader like this.
  15. Dec 2, 2024 at 8:27 PM
    #255
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Ok so you're just missing one.
    I left both on my truck and the tow hook. Didn't feel any reason to remove em even once I got skids and bumper and moved the shackles.
    So you're building your own bumper and skids?
  16. Dec 3, 2024 at 5:27 AM
    #256
    I don’t have any of the factory tie down loops any longer. Not building any bumpers or skids at the moment, gonna pull my bumper and skid off and clean them up and bedliner them both.
  17. Dec 5, 2024 at 8:37 AM
    #257
    Moving the 7 pin from hanging below the bumper, to integrated into it. Hole for the drivers side LP light is used, bumper cutout behind it to accommodate the wiring run.
    Will clean up all the wiring underneath and remove the hanging 7 pin soon.
    Weagle, Fobroader, shifty` and 3 others like this.
  18. Dec 5, 2024 at 8:48 AM
    #258
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Look at that fancy backup sensor.
  19. Dec 5, 2024 at 9:06 AM
    #259
    Ha. Not exactly
  20. Dec 5, 2024 at 9:38 AM
    #260
    gnatehack
    gnatehack New Member
    Middle of Minnesota
    13 SR5 5.7 4x4 Bench
    Up to date maintenance
    I like the high and tight look on these 1st Gens. Seems more period correct to my lil brain...
  21. Dec 5, 2024 at 9:44 AM
    #261
    Didn't post it here earlier, so here's the wheels with the modified (cut to be shorter) center caps and black lug nuts.
    Before:
    After:
  22. Dec 5, 2024 at 10:01 AM
    #262
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    What is it?
    noahrexion likes this.
  23. Dec 5, 2024 at 10:02 AM
    #263
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I prefer the Metallica lugs myself.
    When I get my black six spoke 17's I'll be ditching my black splined lugs for some normal metallic ones. Should break up the black some and go nicely with the brushed TRD center caps
    Weagle likes this.
  24. Dec 5, 2024 at 10:04 AM
    #264
    They're marker lights. I started with these eagle eyes back up lights at the corners of the bumper that worked OK. Then the lens fell off of one and I had upgraded my factory backup lights with the high output Osrams. So I replaced them with some LED marker lights. Looked a bit unbalanced, so I added a second set of them closer to the center of the bumper. Smoked lenses so you can't really see them until they are lit up at night with the parking lights.
    After backup light swapped for marker light:
    location of all of them now:
    Tlar25 and des2mtn like this.
  25. Dec 5, 2024 at 10:56 AM
    #265
  26. Dec 9, 2024 at 5:29 AM
    #266
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Shorter bolt part number
    90119-A0028
    These are fine thread so ordering new might be easier
  27. Dec 9, 2024 at 2:06 PM
    #267
    bfunke
    bfunke Tundra Curmudgeon
    @KNABORES - do your wheels rub the bumper? I wonder if your could use a spacer to move the bumper forward a cm or so. They 2.5Gen guys do something like that I think.
  28. Dec 9, 2024 at 2:51 PM
    #268
    They did rub the bottom air deflector a smidge when I had the spacers on. I trimmed the bottom air damn corners a little. Then I removed the spacers and with the 4.5" backspacing wheels I'm running there's no rubbing.
    Weagle likes this.
  29. Dec 11, 2024 at 8:17 PM
    #269
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    those are some sexy tires and wheels. I'm gonna modify mine a little bit which will help but I wish I had a semi gloss finish like yours instead of matte
    I would love those tow hooks but not sure they will work on my 06
  30. Dec 11, 2024 at 8:34 PM
    #270
    Why wouldnt they?
    Weagle[QUOTED] likes this.
