Replacing upper ball joints. Do I need to replace lower after two years?
Discussion in '1st Gen Tundras (2000-2006)' started by Dolfimus_prime, Nov 24, 2024.
  1. Nov 24, 2024 at 6:26 PM
    Dolfimus_prime
    Dolfimus_prime [OP] New Member
    2006 Black DC
    GX460 brake caliper & rotor upgrade.
    Lately, I’ve been hearing a clunking sound coming from the right front side of the Truck. It doesn’t happen all the time, and I definitely hear it at lower speeds. Assuming it was the upper ball joint, I attempted to add grease as recommended by the manufacturer only to find that the grease was coming out from the backside of where the boot is torn. They are the SPC brand and I replaced them in March of 2022, along with the lower ball joints with OEM. The upper ball joints are SPC and I plan on replacing those with the new version they offer. My question for you All is, should I replace the lower ball joints As well? My assumption is no that I don’t have to Unless there’s play, but I just wanted to ask to see what you all think. I appreciate any advice
  2. Nov 24, 2024 at 6:41 PM
    Dook55
    Dook55 RCLB Guy
    Montana
    The lower ball joints are probably still fine if you used OEM 2 years ago. Just check the bolts. The clunk might be a sway bar bushing. Even if they don't have noticeable slack, they sometimes clunk. They did on mine. I replaced them and the clunk was gone.
    KNABORES and Dolfimus_prime[OP] like this.
  3. Nov 25, 2024 at 5:27 PM
    bfunke
    bfunke Tundra Curmudgeon
    If you used any aftermarket LBJ two years ago, they are 24 months overdue for replacement.
