wheel painting problems
Discussion in 'Detailing' started by tjacob95, Nov 23, 2024.
  1. Nov 23, 2024 at 4:50 PM
    tjacob95
    tjacob95 [OP] New Member
    2014 toyota tundra limited
    ok need advice on painting wheels, I painted my tss wheels gloss black and i went a little too heavy on the spray, now I have runs and orange peel... I sanded down using a scotch final stripping pad but still see some on the runs and heavy spots, what grit sand paper should i use to smooth them back out again to be able to respray them? i have practiced a little on another rim and know how to get the finish I'm looking for now...
  2. Nov 23, 2024 at 4:53 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2023 Tundra Platinum Hybrid
    Dobinsons IMS 2"/1", BMS 1" Wheel spacers with OEM Platinum Wheels. Icon Sway Bar Spacer. 285/65/20 Firestone Destination XT Tires.
    Have you considered taking them to a local shop to have them media blasted? Powder coaters usually offer this.
    That service isn't expensive, typically less than $100 for a set of wheels. That would absolutely get rid of any messed up paint.
  3. Nov 23, 2024 at 4:58 PM
    tjacob95
    because im poor lol jk id rather save a few bucks and do it myself
    PVT Pablo and 1lowlife like this.
  4. Nov 23, 2024 at 7:40 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Not sure about sandblasting but my local powder coater wants $1K to do my 10-year-old faded TSS wheels.
    I'll buy new wheels for that much money..:eek2:
    But so far I'm just living with the faded old wheels...:thumbsup:
  5. Nov 24, 2024 at 12:06 PM
    tjacob95
    I'm spraying mine gloss black maybe I can sell them and use the money to get the rims I really want so far, they look pretty good they aint perfect but they look pretty good I'll try to post pics when I'm done maybe i can inspire you to tackle it and spray yours as well luckily mine aren't on the truck ore on rims so its a little easier to spray
  6. Nov 24, 2024 at 12:18 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    I did a polish on my wheels years ago and they looked great.
    I did another polish a few months ago and they look like shit..:eek2:
    In my 10 years of owning this truck I haven't found one aftermarket wheel I like.
    Maybe next tire change if I can find some TRD Pro wheels I'll go for it..
    I'll be going from 20" tires to 18s..
    RobertD and Shanet421 like this.
  7. Nov 24, 2024 at 12:21 PM
    tjacob95
    hell them look good what polish did you use?
  8. Nov 24, 2024 at 12:21 PM
    tjacob95
    mine have never looked that good lol
  9. Nov 24, 2024 at 12:24 PM
    tjacob95
    mine looked all chalky and stripped thats why i chose to paint them i never thought to polish em ive never had any luck with polishing wheels in the past... maybe mine will turn out good though they look pretty good for now i havent finished spraying them all but i will in the next few days hopefully they turn out good
  10. Nov 24, 2024 at 1:39 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    Same question. I just picked up some black rims. They are ind decent shape but could use a polish.
  11. Nov 24, 2024 at 2:19 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    I used Flitz polish and a buffer ball on a drill on the first polish.
    As well as a lot of elbow grease to get in the crevices.
    For the second one I used Chemical Guys 38.
    But they are 10 years old now..
    JMB[QUOTED] likes this.
  12. Nov 25, 2024 at 2:39 PM
    JMB
    Chesapeake, VA
    Another question. When you say elbow grease, what did you use for an applicator, rag? Also, did you put a sealant on after?
  13. Nov 25, 2024 at 2:45 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    Just rags, a lot of rags.
    I probably put CG Jet Seal on them on the first polish.
    I don't remember, that was back in 2021..
    Jet Seal Durable Sealant And Paint Protectant | Chemical Guys
  14. Nov 25, 2024 at 2:48 PM
    JMB
    Chesapeake, VA
  15. Nov 25, 2024 at 4:28 PM
    1lowlife
    DADA
    2014 MGM DC SR5
  16. Nov 25, 2024 at 4:45 PM
    JMB
    Chesapeake, VA
  17. Nov 25, 2024 at 4:50 PM
    tjacob95
    could just paint em lol mine turned out pretty good will post pics tonight when i get off work
    1lowlife and JMB like this.
  18. Nov 25, 2024 at 5:10 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    Note: I used Amazon.com: CERAKOTE® Ceramic Trim Coat Kit - Quick Plastic Trim Restorer - Ceramic Coating Black Trim Restoration to Last Over 200 Washes – A Ceramic Coating, Not a Dressing : Automotive
    on my plastic center caps.
    They look brand new..
    The wheels not so much on my last wheel polish...
    [​IMG][​IMG]
    Did the bumper plastic too.
    It's holding up very well..
    It took a couple of boxes and you need to exactly follow the instructions.
    [​IMG][​IMG]
    JMB and RobertD like this.
  19. Nov 25, 2024 at 6:37 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Can be tricky on irregular shaped surface but might be able to use 150 or 220 on a small block, feather to 400 then primer and topcoat. They make nib files and razor blocks too but for this project maybe us a little wooden block or a semi flexible pad with sandpaper.
    https://www.amazon.com/Steck-Manufacturing-35260-Spec-Out-Paint/dp/B000RI9GF0
    https://www.oreillyauto.com/detail/...69d12/steck-manufacturing-nib-file/ste0/35260
  20. Nov 25, 2024 at 7:34 PM
    JMB
    Chesapeake, VA
    I've used the Cerakote on several things. It looks great, but it doesn't last for 200 washes like it says on the box.
  21. Nov 25, 2024 at 7:58 PM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    Your powdercoater didn't want the job so he quoted it to the moon. Wheels are a PITA to powdercoat, but not $1k pain.
    Should be closer to half that.
    On a different note: Your S&W polished up nice!
    1lowlife[QUOTED] likes this.
  22. Nov 25, 2024 at 8:19 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    Thank you..
    Their quote was to remove the wheels, tires, and powder coat them, and put it all back together.
    I would lose the milling on the wheel as well.
    For a little more than $1K surely I could find some new wheels with a letter offset than these stock wheels....:eek2::thumbsup:
    BlackNBlu[QUOTED] likes this.
  23. Nov 27, 2024 at 3:16 PM
    tjacob95
    IMG_7806.jpgThis is how mine turned out, sprayed them with gloss black paint and then with clear coat think they came out alright
    ToyotaDude, AthenaOffroad and RobertD like this.
  24. Nov 27, 2024 at 3:18 PM
    tjacob95
    IMG_7797.jpgAnother shot of them again not a professional i figured id try this if it doesnt hold up i might get them powdercoated as well, the only local guy quoted me $650 dollars to do mine and mine are already off wheels i felt like that was outrageous but hey what do i know..
    ToyotaDude and JMB like this.
  25. Nov 27, 2024 at 3:44 PM
    AthenaOffroad
    AthenaOffroad YouTube wannabe
    Niko
    2014 Blue Ribbon Metallic Tundra DC SR5
    Same price i was quoted as well. im spraying mine, but i did have them sand blast them for me first. I aint about all that sanding lol
  26. Nov 27, 2024 at 3:53 PM
    tjacob95
    Kinda wished i wouldve had mine sand blasted i messed up on one and have redone it 3 times i just sanded and resprayed today if it comes out bad this time it is what it is lol im done fooling with it sometimes my ocd can cause me way more headache than what its worth lol
    ToyotaDude likes this.
  27. Nov 27, 2024 at 4:19 PM
    AthenaOffroad
    Niko
    I completly understand, sandblasting was nice but it also caused me to use a lot of primer more than i anticipated. I have some runs and some small specks and i even made a big booth. Eventually my wife and friend came to look at them and said all these imperfections that i see no one else will ever see and that im just being to picky. i live on a dirt road so they will be dirty in a day lol i have one more small sand and recoat and then im done lol
    ToyotaDude and RobertD like this.
  28. Nov 27, 2024 at 4:22 PM
    JMB
    Chesapeake, VA
    For $650 you're not too far from buying new.
  29. Nov 27, 2024 at 4:24 PM
    AthenaOffroad
    Niko
    yea i already had a set picked out for around 800 or so. i said no to the powedercoating and just went with hvlp priming and painting im about $400 in right now hopefully dont have to spend much more
    JMB[QUOTED] and RobertD like this.
  30. Nov 27, 2024 at 5:45 PM
    tjacob95
    How are you 400 in im 50 bucks in…
