  1. Nov 9, 2024 at 9:36 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    All good info to digest as I tinker with what's best. Thanks again for the feedback.
    Trident[QUOTED] likes this.
  2. Nov 10, 2024 at 6:23 PM
    LILTRD
    LILTRD New Member
    East Bay, California
    2013 Tundra RCSB
    Hidden Winch Lighting Suspension/Air bags Wheels/Tires Audio Center Console swap
    Worked on the front brakes as I thought I may have had a sticking caliper, the squealing I believe was the Z36 pads being slightly too tall and a shelf of pad material was formed as the pads were wearing down hovering over the rotor. Filed them down, never been impressed with the Z36 kit.
    Also, found 2 valve cover bolts completely loose from when I had a shop take care of the leaking spark plug gaskets. Tightened them up, funny thing is the other side of the motor is seeping from the vc's.
    Have had a front end noise(hard stops on a decline/certain turning angles causing the noise)recently as well and everything looked/felt tight. Only the sway bar links had a bit of rubber deterioration.
    Any ideas? Was going to do the inner tie rods, but they seemed tight, no movement.
    Mdl likes this.
  3. Nov 11, 2024 at 5:20 PM
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
    To complement the USB ports I added to the bed, I got a hook & loop pouch to store USB cables.
    To be clear, this is a tactical hook & loop storage, NOT a Velcro fanny pack.
  4. Nov 14, 2024 at 1:48 PM
    zcarpenter92
    zcarpenter92 Yotas and Yellow Jackets
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Anybody have a link for these? Cant seem to find them anywhere.
  5. Nov 15, 2024 at 7:23 AM
    Blang805
    Blang805 New Member
    Central Coast California
    2010 CrewMax Platinum 4x4
    Build in Signature
    Tundra: PT271-340CL
    Link to thread where PN was found
    Apparently they apart of some package offered when bought new?
  6. Nov 19, 2024 at 5:53 AM
    Northwoods22
    Northwoods22 New Member
    MN
    2013 tundra grade
    Picked up a well used but 100% functional Decked crossover tool box recently. Looks good on the truck. Lost some bed space but will help clear out my backseat and hopefully make things simpler.
  7. Nov 19, 2024 at 9:27 PM
    IIonPilgrimg
    IIonPilgrimg New Member
    2008 Tundra Limited Double Cab 4x4 5.7 6-speed Red Rock
    (LOL over here)
    I was baffled with the insanity of it all when rebuilding the leaf springs and U/L Arms on my 1970 Nova with Poly bushings.
    Everything had to be torched and air-hammered -- practically whittled out -- and pressing the new stuff in was nearly as troublesome.
    Then there's the trouble of compressing the springs to reinstall them while pressing balls on spindles at the same time...
    Only to realize later my fancy new QA1 adjustable shocks will not go through the hole in the lower arm :angrygirl: !
    joseph_womack[QUOTED] likes this.
  8. Nov 19, 2024 at 9:52 PM
    IIonPilgrimg
    It wasn't exactly today...
    In August, I hitched-up, fueled-up, drove to the beach, dumped the dory, motored out to a very secret spot, caught #7 Albacore tuna, and Ate-Up!
    (First and only time I've dipped the Tundra in saltwater. Can't decide if that's good or bad.)
    Hitched...
    Fueled...
    Motored...
    Secret Spot (bloody decks!)...
    Ate-Up!...
  9. Nov 20, 2024 at 7:59 PM
    10 Bears
    10 Bears New Member
    11 CREW 5.7
    None at the moment
    Bought a nice quality Fel-Pro 12 hole transmission pan gasket.
    The one that came with the strainer from Glamazon is a paper thin rubber unit that looks like heat can deteriorate break up and fall in the pan causing catastrophic transmission damage or Kaboom-Ski. The Japanese made
    Fel-Pro I doubt it feels as good as a OEM Toyota unit.... Feels of very good quality very sturdy with metal insert in the eyelets not sure* but it feels metal impregnated. Idk feels every bit worth 32$
    While the OEM was a bargain at 96.99$ before tax. Nothing against OEM parts but O'Reilly is literally across the Rd from my house. The dealer is 19 miles.
    Now when I replaced the starter oooh boy you bet I payed up for the OEM unit.
    I got a great price on it I think I gave 239$ otd....down from 360$ I believe?
    My coworkers brother works the parts Dpt at the Porsche dealership Wich is inside the big Toyota Land lot and they buy parts from each other all day so he gave me the contact info and I just showed up to pick up. It was actually 11$ less than the Oreily house brand haaaaaa. I got lucky.
    Either way I still would have bought the Toyota starter. As hard as it is to access plus the OEM from the truck made it
    237k miles can't complain about that VS off brands with "one year warranty" that go out exactly a 13 months later...
  10. Nov 22, 2024 at 3:09 PM
    07 Tundie
    07 Tundie Shadowfax
    SC
    2007 DC 4.7L 4x2 SR5 Super White
    I had to search for longer than I would like to admit to find this post. My wife has started using that glovebox as "her" area when driving, so I just ordered a USB plug, the lights, and the switch to do this mod myself.
  11. Nov 22, 2024 at 4:00 PM
    IIonPilgrimg
    Thanks for the effort! In my Tundra, this box houses a TPMS system defeat button and my winch controller with USB cord. Such organization would complete the form/function.
  12. Nov 22, 2024 at 9:21 PM
    08OffroadTN
    08OffroadTN New Member
    2008 TRD Offroad
    I installed the factory rail system and a black steering wheel overlay a few days ago, and I just now got around to posting about them.
  13. Nov 23, 2024 at 4:10 PM
    Tipsovr
    Tipsovr New Member
    2012 RW Crewmax
    Just ordered the Morimoto LED fog lights using Headlight Revolution's Black Friday sale. They will match perfectly with the Morimoto headlights I installed this time last year. Pretty psyched for the lighting upgrade!
    Medicineman, OldGuy03, Deaner and 3 others like this.
  14. Nov 24, 2024 at 5:52 PM
    Deaner
    Deaner New Member
    Dean
    The Mac
    2010 Rock Warrior
    Just put in some red bulbs. Easier on the eyes for me on early mornings.
  15. Nov 24, 2024 at 6:19 PM
    Randy Morton
    Randy
    Deepinahearta, Texas
    Standard bulbs, or LED?
    Deaner[QUOTED] likes this.
  16. Nov 24, 2024 at 7:08 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Nice, I only did the doors and led strips under dash. Does make it harder to see the wire colors. Haha
    OldGuy03 and Deaner[QUOTED] like this.
  17. Nov 24, 2024 at 7:25 PM
    Deaner
    Deaner New Member
    Dean
    The Mac
    2010 Rock Warrior
  18. Nov 24, 2024 at 10:17 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    sick, I wish Meso Customs made some for my style of headliner
  19. Nov 24, 2024 at 10:25 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
  20. Nov 24, 2024 at 10:33 PM
    joseph_womack
    Joe
    Louisiana
    yeah I know, he just reminded me of the meso ones but my overhead doesn't support it
    OldGuy03[QUOTED] likes this.
  21. Nov 24, 2024 at 10:51 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    Right on. The MeSo is pretty slick because you can change the colors between red and white. Bummer yours doesn't support it. I also didn't know that the RC trucks were that different when it came to center console lights/dome lights.
  22. Nov 25, 2024 at 12:36 AM
    SanDiegoSlovak
    SanDiegoSlovak Learning Thru Mods
    San Diego, CA
    2008 Double Cab SR5 4x4
    3" lift, 35" tires, hi-clearance bumpers + more!
    Pulled the trigger on installing larger tires after trying to hold off until "absolutely necessary." I went with Toyo Open Country RT Trail in 285/75/18. Going camping in Sedona this week, so will see how they perform on Soldiers Pass, Broken Arrow, etc. Previously I had Kenda Klever RTs in 275/65/18 for ~3 years and they got badly cupped and worn (by infrequent rotation or punishing offroading or both).
    The Dude, DbQC, COTundie and 6 others like this.
  23. Nov 25, 2024 at 4:02 AM
    joseph_womack
    Joe
    Louisiana
    I think it actually might depend on trim level and not cab size, I could be totally wrong but
  24. Nov 25, 2024 at 6:29 AM
    Deaner
    Deaner New Member
    Dean
    The Mac
    2010 Rock Warrior
    That was actually the reason I just went with new bulbs. They make the front map lights for mine, but not the rear dome. :facepalm:
  25. Nov 25, 2024 at 6:44 AM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    I have been wanting to get some MeSo lights in mine but after seeing yours I think I might save $100 and just get the lights you linked. I don't think I'll mind if they are red full time. I almost always have the lights turned in the off position anyway because I don't like the bright light when entering my truck at night or early mornings.
  26. Nov 25, 2024 at 3:42 PM
    Windsor
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    Pulled the radiator, shroud, fan, belt, tensioner and idler pulleys off. Found the fan mount needs to be replaced, so I ordered that.
    That was all my back could take, so I am done for the day. I'll install the new fan mount, idler/tensioner pulleys, water pump, thermostat, and alternator between wednesday and next week when the fan mount gets delivered.
    I washed the radiator fins out, and holy crap it was packed with dust.
    Edit: decided to go ahead and replace the power steering pump while I am there, so got that ordered from Olathe Toyota.
  27. Nov 25, 2024 at 6:06 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
  28. Nov 25, 2024 at 6:54 PM
    French Avocado
    Utah / Wyo
  29. Nov 25, 2024 at 6:56 PM
    rcsbguy
    rcsbguy New Member
    Few days ago but we made a front bed bracket to keep the bed from cracking.
    MTRock, The Dude, Half Assed and 9 others like this.
  30. Nov 25, 2024 at 8:52 PM
    joseph_womack
    Joe
    Louisiana
    Did a tune up and replaced two coil packs, removed my CAI, removed SDHQ wiper reservoir and put my oem airbox and washer reservoir back in; replaced rear brake caliper and added cruise control; now I just need to drop the trans pan one more time to replace the gasket and eventually get to finishing my bedrack rebuild for like the 5th time :facepalm:
    yeah I know no pics; I can get pics of the plugs if I'm not mistaken theyre original from factory with 260k on the clock and dont look terrible
