Auto Leveling
Discussion in '3rd Gen Tundras (2022+)' started by Csstundra, Nov 25, 2024.
  1. Nov 25, 2024 at 7:49 AM
    Csstundra
    Csstundra [OP] New Member
    Craig
    2022 Platinum
    I have a 2022 platinum with the advanced package which I believe also means that it has auto leveling. I have also installed a 3” lift kit. Does the lift kit affect the auto leveling feature. For some reason I do not believe the auto leveling is working since the lift kit was installed. Thanks in advance.
  2. Nov 25, 2024 at 7:50 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    What makes you think that?
    Who installed it?
    Post a pic of the rear axle where the air bags/coil springs are at
  3. Nov 25, 2024 at 7:58 AM
    Csstundra
    Craig
    2022 Platinum
    Because I hauled some lumber and the rear was lower than the front and normally it is not.
    eddiefromcali likes this.
  4. Nov 25, 2024 at 10:26 AM
    eddiefromcali
    Eddie
    100% Stock
    It looks like you're almost riding on the bump stops. Was this picture take with the truck running?
    Can you take a picture of the adjuster arms? You definitely have a lift kit but I don't see the adjuster levers that also would need modifying.
