4lo, VSC, Check engine, traction control flashing.
Discussion in '2nd Gen Tundras (2007-2013)' started by Wesssy, Nov 24, 2024.
  1. Nov 24, 2024 at 3:12 PM
    Wesssy
    Wesssy [OP] New Member
    Needing answers/ advice on what to do. my truck occasionally gets fussy and turns on all of these lights listed above. when that happens. my truck shifts funny and runs at higher Rpms. When the lights are not on. my truck runs great. I have 220k miles and would like to put another 220k on it.
  2. Nov 24, 2024 at 7:05 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Sounds like the AIP valves stuck open/closed.
  3. Nov 25, 2024 at 4:58 AM
    Wesssy
    Thank you!
