  1. Nov 23, 2024 at 6:26 PM
    It’s 6.5 quarts with the filter change.
    Filthyphil likes this.
  2. Nov 23, 2024 at 6:47 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Yeah that’s fine the 5qt jug isn’t filled up to the top when you bought it. Should hold 6.5ish quarts so if you filled up the 5qt and had a little left over your fine.
    Hi06silver[QUOTED], Tlar25 and BroHon like this.
  3. Nov 23, 2024 at 8:03 PM
    I run the Mobil 1 M1-301 extra capacity filter and can get 7qts of oil in mine. I do annual oil changes. And it’s time. I’ve got lots of miles this last year compared to most and suspect I will be doing oil changes more often now that I’m dailying the FGT. I put 4900 miles on it this year.
    Hi06silver, des2mtn, abcinv and 2 others like this.
  4. Nov 24, 2024 at 9:33 AM
    Hi06silver
    Hi06silver Fat. Thumbs.
    2006 DC 4x4 Waltrip
    I was looking for the volume of the actual jug because that's all that basically came out. Thanks though.
    The original post may have been worded poorly, my bad. It's a weird question to begin with, I know.
  5. Nov 24, 2024 at 9:52 AM
    Probably as @shifty` mentioned, 6-6.25 qts. I remember it being the same since I dispose of my Mobil 1 in the same 5 qt container it came in when I bought it.
    I usually buy 3 - 5 qt jugs at a time and leave the remainder in the catch container until I’m ready to toss out two oil changes by bringing the 3 - 5 qt jugs back to Wally World.
  6. Nov 24, 2024 at 12:41 PM
    Neo
    Neo New Member
    Alabama
    You know, we hadn't considered that. He was going to leave off the cover pieces until he decided if he needed to add any more rear spacers. When he gets it fully dialed in, we'll try to reinstall them and I'll try to remember to comment on it.[/user]
    shifty`[QUOTED] likes this.
  7. Nov 24, 2024 at 6:01 PM
    Neo
    Neo New Member
    Alabama
    Discovered that a couple of bulbs were missing the Tundras.com master list! Somebody left off the vanity mirror lights. :rofl: OEM is a Koito 12V 1.5W "fuse" type bulb (30mm length). I ordered these LEDs from Amazon. They're a couple of mm short, but the OEM bulb is actually a little long for where it clips in. We'll see how they work.
    abcinv, oscardog86, bmf4069 and 3 others like this.
  8. Nov 24, 2024 at 6:18 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
  9. Nov 24, 2024 at 6:26 PM
    Bought2Pull
    Bought2Pull New Member
    Greg
    WV
    2006 Tundra 4 door
    Today I carried the Rock Auto supplied Denso radiator into the garage.
  10. Nov 25, 2024 at 10:25 AM
    To dip or remove, that is the question. Dipped them 10 years ago, one of my rear fender PPF thingys has peeled, one has not. Are these things removable? Easily? Mine are crusty AF
    I’ve plastidipped them before with pretty good results. About 10 years ago
    The one that’s still going strong today. Starting to fray around the edges. 10 years is a good run though.
    455h0le_dachshund likes this.
  11. Nov 25, 2024 at 10:37 AM
    Remove for sure. Heat gun and one of those magic erasers maybe?
    @shifty` didn't you remove yours.
    oscardog86 likes this.
  12. Nov 25, 2024 at 12:22 PM
    $3.53 + tax for a tranny drain crush gasket! That’s like 35x what it costs to make! SMH
    FrenchToasty and Filthyphil like this.
  13. Nov 25, 2024 at 12:47 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Shoot I think my dealer charged me $5.xx. Also, is that the same for the fill plug or does the fill plug not have anything. I need to do this soon
  14. Nov 25, 2024 at 12:54 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Dad took the brush guard off. The end of the line is coming soon for us, and the ole girl
  15. Nov 25, 2024 at 1:08 PM
    Gave her a bath.
  16. Nov 25, 2024 at 1:09 PM
    I did. I used a heat gun set to 450º, plastic flat razors, and sticker/adhesive remover. Turtle Wax brand, which may or may not temporarily soften clearcoats. I can link you with more details if helpful.
  17. Nov 25, 2024 at 1:13 PM
    That’s just the drain plug and it’s for the ones where you fill it via the dipstick.
  18. Nov 25, 2024 at 1:32 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    No dipstick for mine. They said both the fill and drain plugs use that same metal crush washer but I thought the fill used a black rubber washer.
  19. Nov 25, 2024 at 2:11 PM
    Entirely possible. You have the newer 5 speed transmission.
    CodyP[QUOTED] likes this.
  20. Nov 25, 2024 at 5:21 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Is it going on crackie next?
    Tundra2[QUOTED] likes this.
  21. Nov 25, 2024 at 5:47 PM
    What’s the beef?
  22. Nov 25, 2024 at 6:43 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    What works instead....
    Transfer & Differential Service Gasket Kit Compatible with Toyota Lexus 4Runner Land Cruiser Tundra Tacoma FJ Cruiser Highlander 3
    RAV4 Sequoia Sienna 1215710010 9043024003 90430A000
    https://www.amazon.com/dp/B0BFGB3GPM
  23. Nov 25, 2024 at 6:59 PM
    Those appear to be too big for the drain bolt on the transmission.
  24. Nov 25, 2024 at 7:11 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Yes, that $300 spent back in 2018(?) Was well worth it
  25. Nov 25, 2024 at 7:13 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    The square tube section of the frame is collapsing vertically in the front. I don't have the time, or the funding both due to youngins to do anything about it
    May look into seeing how the rear cross member looks :drevil:
  26. Nov 25, 2024 at 7:13 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    So what is your pops replacing his tundra with?
  27. Nov 25, 2024 at 7:14 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Maybe a lexus
  28. Nov 25, 2024 at 7:14 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    GX?
  29. Nov 25, 2024 at 7:25 PM
    You gonna rob parts before parting with it? Front bumper for example….
  30. Nov 25, 2024 at 7:27 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    The front bumper on the silver truck is fucked up too
    I'll eventually order a bumper from Amazon one day
    KNABORES[QUOTED] likes this.
