Extremely Cheap! 5.29 gears. Motive gears OK?
Discussion in 'Performance and Tuning' started by Silver17, Oct 5, 2024.
  1. Nov 19, 2024 at 7:54 AM
    #331
    Silver17
    Silver17 [OP] Used, but returned and sold as new member
    Northeast
    2017 TRD 4x4 Harrop SC
    The real question is how do I get easy break in miles on the front diff? Just put it in 4Hi as often as I can on straight roads? I don’t have miles of dirt roads to drive on or anything to rack up miles.
  2. Nov 19, 2024 at 8:06 AM
    #332
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Highway or better yet wet highway in 4hi should do it.
    Silver17[QUOTED][OP] likes this.
  3. Nov 19, 2024 at 10:16 PM
    #333
    j_supra
    Manitoba, Canada
    2008 Tundra Limited
    20" Vision brawl, 33.5" Toyo at3s, Bilstein 5100s, LTH, custom exhaust, AEM filter, TRD intake pipe, Joying HU, hertz components and sub, Rokblokz XL, AVS visors
    4hi and drive in reverse :rofl:
  4. Nov 19, 2024 at 11:01 PM
    #334
    blenton
    blenton New Member
    I am considering having mine polished as well for the simple reason of break-in. It wouldn't be hard for me to get 500 miles on them quickly, but it would be hard for me to do that without pulling a trailer or putting it under a fairly heavy load.
  5. Nov 20, 2024 at 5:08 AM
    #335
    Silver17
    Northeast
    I’ll just have to put it on Jack stands in the garage lol.
    Same. I don’t daily drive it, and when I put more miles on in one trip it’s usually pulling a trailer.
    bflooks and FrenchToasty like this.
  6. Nov 20, 2024 at 5:33 AM
    #336
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    Go all out… REM then WPC Treatment.
  7. Nov 20, 2024 at 7:40 AM
    #337
    blenton
    blenton New Member
    Don’t forget about cryo treatment.
    Jowett[QUOTED] likes this.
  8. Nov 20, 2024 at 7:57 AM
    #338
    Silver17
    Northeast
    Don’t forget carburizing, nitriding, laser hardening, PVD coatings, and austempering. See if I can’t make these 175 dollar gears 2,000 dollars.
    :bananadead:
  9. Nov 20, 2024 at 9:30 AM
    #339
    DbQC
    DbQC New Member
    2009 tundra sr5
    Has anyone used the mini install kit and reused the bearings?
    Mdl likes this.
  10. Nov 20, 2024 at 10:52 AM
    #340
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I'll be looking at the mini for the fronts. It'll be based on my bearing inspection. I may pre-order or Amazon some rear bearings in case. So can return if not needed.
  11. Nov 20, 2024 at 4:59 PM
    #341
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    The pile continues to grow…
  12. Nov 20, 2024 at 5:00 PM
    #342
    ZPhilip
    Philip
    West Chester, PA
    That’s what I would do if I did the work myself. My diffs are sorta low mileage and taken care of. But any shop near me wants new bearings and compete kit to do the swap.
    Mdl likes this.
  13. Nov 21, 2024 at 5:53 PM
    #343
    kbahus
    kbahus New Member
    MI
    2015 MGM Tundra Limited Crewmax
    For the price I couldn’t say no, this site sure causes a lot of problems! I figure I already have low mileage front differential sitting on the shelf so why not. Hopefully I can get away with the basic install kit on that diff.
    Mdl and Silver17[OP] like this.
  14. Nov 21, 2024 at 6:23 PM
    #344
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I'm hoping to start the first week of December. Whenever that rear lsd shows up. Is it the day after turkey day yet?
    Silver17[OP] likes this.
  15. Nov 21, 2024 at 11:58 PM
    #345
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    So I got a killer deal on Timken bearings for the rear. No shims. I see that the Toyota Yukon and skf kits have pinion and diff shims labeled sk13, sk23, sk44, sk23 etc. In my search they state they are for Dana 44 and GM. Same part for Toyota 10.5 and front 9 ifs?
    I have an idea of what individual Toyota shims to order but am curious.
  16. Nov 22, 2024 at 12:07 AM
    #346
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I have 135k on my 2007, it was a stolen vehicle recovery that spent its first 5 years in the police yard and dealership manager transportation. I'm planning on using the mini kit and bearings from my front diff. I do have a backup plan if they don't pass the visual inspection.
    ARES35 likes this.
  17. Nov 23, 2024 at 12:17 PM
    #347
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Got the bearing puller. Thing is massive. I chose the sunex 5/8-8 inch one over the otc-1130. It was $100 shipped from ebay.
    All bearings/seals will be here on the 26th. Will only be waiting for the speedmaster...
    Mini kit for front arrived.
  18. Nov 24, 2024 at 4:59 AM
    #348
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    You gonna attempt this yourself?
    FrenchToasty and ARES35 like this.
  19. Nov 24, 2024 at 6:57 AM
    #349
    ZPhilip
    Philip
    West Chester, PA
    To all much smarter than I: Gasket or RTV or both where 3rd member bolts to axle?
    Mdl and ARES35 like this.
  20. Nov 24, 2024 at 7:25 AM
    #350
    FIPG
  21. Nov 24, 2024 at 7:43 AM
    #351
    ZPhilip
    Philip
    West Chester, PA
    Use the Yukon supplied stuff in their kits or toss it and get Toyota?
    FrenchToasty[QUOTED] and Mdl like this.
  22. Nov 24, 2024 at 7:44 AM
    #352
    I used Toyota but any flavor should work
    Mdl, Vizsla and ZPhilip[QUOTED] like this.
  23. Nov 24, 2024 at 7:47 AM
    #353
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    But which one tastes the best?
  24. Nov 24, 2024 at 7:50 AM
    #354
    For the price, definitely Toyota. They are very proud of that little tube. It even came with a church key like you’d use to open up canned meat/fish, to get every drop out
  25. Nov 24, 2024 at 8:02 AM
    #355
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    That makes it so much easier to put on crackers!
  26. Nov 24, 2024 at 8:19 AM
    #356
    Vizsla
    Vizsla pretend2send
    Gearinstalls.com (Zuk) recommended this FIPG. 4+ years later no leaks, and I am definitely that guy who could screw it up.
    https://www.permatex.com/products/g...ight-stuff-90-minute-black-gasket-maker-3-oz/
    Still have some, will taste it later and let you know.
  27. Nov 24, 2024 at 8:30 AM
    #357
    ZPhilip
    Philip
    West Chester, PA
    Mdl likes this.
  28. Nov 24, 2024 at 9:39 AM
    #358
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Yes. When I installed the Auburn in 2013 I used toyota fipg. No leaks. Get it on before it sets!
    pvn.beluga[QUOTED] likes this.
  29. Nov 24, 2024 at 10:56 AM
    #359
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
  30. Nov 25, 2024 at 11:31 AM
    #360
    kbahus
    kbahus New Member
    MI
    Well crap, gears came in but the rear ring gear has some minor damage. The styrofoam insert and ring gear was upside down in the box so it was subject to impact. Thinking I should probably return this one and get a different one, any thoughts from the pros? Not sure if the dings will cause any problems with wear or not.
    Mdl likes this.
