  1. Nov 22, 2024 at 6:41 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Ohhhhh.....I see what you are saying.
    Here (maybe a West coast kinda thing?) we usually have springs that go over a bar that spans the width of the door.
    I've heard it's kinda scary to tension the springs. Either use 2 pegs and twist it, or I've seen commercials of some companies have a drill powered thing that spins the springs.
    Edit: I see I'm late to the party and you guys already talked through it.
  2. Nov 22, 2024 at 6:46 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    If you split the post lengthwise and then router the center of it hollow and then glue it back together with good urethane glue and lots of clamps, that would prevent the issue of a wandering drill bit. The transition from the underground conduit could still be tricky and I’m not sure how you are anchoring the post itself though…
    when we run underground commercially, like Beau mentioned, we have a splice/junction box on either end and run the conduit to the box. At a light post, that conduit will come up through a concrete base and the light post is set over the box and anchored down to the concrete. Or the conduit will come up alongside the post and be surface routed up the face.
    TaquitoBandito likes this.
  3. Nov 23, 2024 at 11:26 AM
    PKFan
    2018 Inferno! DC SR5 4x4
  4. Nov 23, 2024 at 11:58 AM
    RainMan_PNW
    Casey
    Clark County, WA
    Hung up some stained glass that my wife and daughter have made recently
  5. Nov 23, 2024 at 3:49 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Wrapping up this master bath on Tuesday when the shower glass gets installed.
    Old bath had a 36” single vanity with toilet next to it, followed by a large tub.
    Tub got trashed, toilet moved to old shower location. Double bowl 72” vanity added, 60”x42” shower pan plus bench.
    Big 24”x 48” tiles were used. Niche is all mitered and grain matched where possible. Niche pic was in progress when grooves were cut for floating mitered tile shelf, 4 25 cent biscuits and silicone hold shelf in place.
    IMG_0125.jpg IMG_0123.jpg IMG_0122.jpg IMG_0120.jpg IMG_0119.jpg IMG_0116.jpg
  6. Nov 23, 2024 at 3:58 PM
    RainMan_PNW
    Casey
    Clark County, WA
    :101010:
    OldGuy03, TaquitoBandito and T-Rex266 like this.
  7. Nov 23, 2024 at 4:04 PM
    bmf4069 Captain wtf
    That's beautiful! I love those colors. I'd recommend changing those plugs and switches to gray. Might add to the fung shoeey.
  8. Nov 23, 2024 at 4:57 PM
    Beautiful work!!
  9. Nov 23, 2024 at 4:57 PM
    Nothing big today. Hung up some free floating shelves in the remodeled bathroom
  10. Nov 23, 2024 at 7:00 PM
    Xcumminsguy
    Xcumminsguy New Member
    NY
    2021 Tundra TRD Pro Crew Max
    Stock, with a few cosmetic mods.
    Leaves, and more leaves! Then went on the roof to run the drill powered brush through my dryer vent tube as the wife has been complaining that the dryer is taking longer than usual. Bit of a pita as the washer/dryer are on the second floor.
    j-utah, Blufin, OldGuy03 and 2 others like this.
  11. Nov 23, 2024 at 7:07 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Looks fantastic, wish I had that kind of skill.
  12. Nov 23, 2024 at 8:36 PM
    TaquitoBandito
    Joel (AKA Bif)
    I'm glad you posted the examples with the explanation because I'm pretty sure @Fotnot has no concept of what "flaccid" means.
    ACDC2ZZTop, bmf4069, j-utah and 4 others like this.
  13. Nov 24, 2024 at 5:26 AM
    Blufin
    Blufin Seasoned member
    Bob
    Cape Cod,MA.
    23 Capstone
    Leaves today & hopefully the last time,it has been the weekend ritual for the last 4 weeks:facepalm:
    Mow the lawn for the last time put down winter fertilizer, retire the mower and put the snowblower in que.
  14. Nov 24, 2024 at 7:46 AM
    ZPhilip
    Philip
    West Chester, PA
    I didn’t give them the option. Their only request was a dimmer for the shower light. White outlets and switches are probably at least half the cost if we found a gray that wasn’t too light or too dark, and a husband and wife can agree on.
  15. Nov 24, 2024 at 7:50 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Scooter butt prison :rofl:
    Lil sumn for me from the wifey <3
    Florida AF, bmf4069, Fotnot and 8 others like this.
  16. Nov 24, 2024 at 11:03 AM
    Got up- hit HD (for the one millionth time) and avoided the Milwaukee aisle.
    Picked up a new motion sensor switch - $40
    Knockdown texture - $28
    Sanding sponge - $3?
    A box of my favorite drywall anchors - ??
    $80 later.
    Put new sensor switch in
    Finished the small area of texture from when I had to hang new shelves in the bathroom. Once it dries, I’ll add touch-up paint over it and I’m freaking done with other bathroom.
    I have to install, and setup my daughter’s new desk with a built in vanity mirror, outlets in her desk etc.
    I still need to organize shit into thepackouts that have been sitting in my garage. Been a busy ass weekend
    bmf4069, Fotnot, Blufin and 2 others like this.
  17. Nov 24, 2024 at 3:28 PM
    This was a royal PITA to piece together. Finally, done. Once she’s home, and determines where she wants it, I’ll mount it against the wall.
  18. Nov 24, 2024 at 3:29 PM
    Just needs to be cleaned up now. Added the spackle, and touch up paint
  19. Nov 24, 2024 at 3:44 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Today, we re-homed the last of the 16 peafowl that were voluntarily living on our property. This means this coming weekend I can pressure wash my deck, take down temporary fencing around most of my flowers and plants in the yard, and get my wife’s car detailed…
  20. Nov 26, 2024 at 10:22 AM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Small project, made a frame for the tv. I saw this style were selling for 400-500$ or more and thought it was crazy. Used two pieces of 16$ picture frame trim and I think it really makes it look like a picture haha.
  21. Nov 26, 2024 at 10:28 AM
    Danimal86
    Daniel
    Sacramento, CA
    Those Frame tv's are super impressive. I setup my parents with one for the kitchen. Unfortunately the wall we mounted it on has a pocket door to it, so we couldn't do a recessed box for the controller unit.
    I actually really like the non-glare coating on them. I was thinking of getting one for our outdoor tv (under a patio cover)....watching tv outside can be a pain for glares.
  22. Nov 26, 2024 at 11:07 AM
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    whay year is your dump trailer ? imm looking for one just like that !
  23. Nov 26, 2024 at 12:19 PM
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    2020 Tundra Limited on 35's
    I've been sidelined with an injury for several months and the garage was driving me insane. We basically moved into the house and then a few weeks later I got hurt. Last weekend I put my daughters boyfriend to work helping me move stuff around so I can at least walk around in it. Now I just need to start putting things away and getting my cabinets mounted. Also need to figure out what I'm going to do to store all the bikes.
  24. Nov 26, 2024 at 12:24 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    the BF's face when he saw the mess....poor Reggie
    ATV25, Blufin, T-Rex266 and 5 others like this.
  25. Nov 26, 2024 at 3:13 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    I hang all my mtn bikes from the ceiling using a pulley system mounted to a beam. Your ceiling looks kinda low though? I've also seen racks that swing out from the wall so you can have them organized there as well. https://storeyourboard.com/products...b_rH_bavPuu1IelJKFku23SLKqhtfT5saAlwjEALw_wcB
    TaquitoBandito and FrenchToasty like this.
  26. Nov 26, 2024 at 3:17 PM
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    The picture might be deceiving. The ceilings are pretty high at 14-15'. Look at the freezer on the right side for reference.
    I had the hanging pulley systems for my bikes at the house I had before my last one. That might be the correct way to store them here as I have the height.
  27. Nov 26, 2024 at 4:48 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Does replacing burnt Christmas tree lights count?
    Last year I had to replace about 100 and I can only assume we got some power surge or something. Down side is a few things, I hate the look of LEDs on a tree so these are incandescent (I think?) so one dead light sometimes takes out a few lights and not always sure which one is actually dead. The other downside is I can’t find the correct bases to just plug and play so the ones I ordered I ended up having to pull the bulbs outta both bad base and new base and but the bulb back into the old base. Just more time but for now all lights work!
    Some of the bad bulbs
    new vs old base
    bmf4069, Fotnot, OldGuy03 and 2 others like this.
  28. Nov 26, 2024 at 7:23 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    I thought that was a mini fridge. :rofl:
    I guess I could've paid more attention to the shelving above the garage door for reference. :facepalm:
  29. Nov 26, 2024 at 7:36 PM
    ZPhilip
    Philip
    West Chester, PA
    Is it really 14’-15’? That’s wild. I was guessing it is 11-12’ high.
  30. Nov 26, 2024 at 7:38 PM
    shifty` You can call 1 (800) PP5-1-DooDoo
    I had originally been using the Racor B-1R for vertical hanging, started with one row of 5 spaced ~18" apart, then started a second row 12" lower on the wall. It doesn't look like Racor is making this product anymore, but this Leonardo rack is $7.92/ea on sale, with a 15% off coupon dropping it to around $7 and is nearly identical to the Racor in its form/function: https://www.amazon.com/dp/B000FGTTEW/
    Maybe it's just a Black Friday deal, MSRP is $20. So may not stay at that 3-for-1 pricing for long.
    TaquitoBandito and OldGuy03 like this.
