  1. Nov 21, 2024 at 6:53 PM
    shifty` You can call 1 (800) PP5-1-DooDoo
    And that’s ultimately why I paid ballpark $200ish to buy used so I could try out some 33s for figment and whatnot. I don’t need to spend $1,200 to test a larger size if I can take someone else’s reasonably alright castoffs.
    It’s entirely possible I’ll get to half tread on my mickeys and be annoyed af about the noise. Well hafta see.
    TXTundraGuy23 likes this.
  2. Nov 21, 2024 at 6:56 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    I’ve got AT4’s on my 2500 Silverado and they are very quiet and smooth. But I prefer the Toyo Mt’s.
    Bed Tundy likes this.
  3. Nov 21, 2024 at 7:21 PM
    Bed Tundy
    Bed Tundy Like changing a tire, the 1st time you're careful
    Neature Gary
    Moscow, ID
    (W) 2005 AC 4.7 4x4 with VSC, (G)2005 AC 4.7 TRD Sport RWD
    See Signature or my Photo Album
    I have Toyo M/Ts, trade ya? Great in deep powder and mud, but the AT4's have better road manners.
    Filthyphil[QUOTED] likes this.
  4. Nov 21, 2024 at 7:32 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Those are nice wheels. Never seen those before on the bottom
  5. Nov 21, 2024 at 7:38 PM
    Bed Tundy
    Neature Gary
    Moscow, ID
    They're pretty neat, $100 on facebook. They came optional on the 05-06 tundra/sequoia but weren't super common. look really good cleaned up, but I'm missing 2 center caps and none of the other caps fit them. people want way too much money for them so they will be capless as my winter tire set until I can find cheap caps.
    oscardog86 and 455h0le_dachshund like this.
  6. Nov 21, 2024 at 7:39 PM
    Filthyphil
    Phil
    If they weren’t on my work truck I would be game.
    Bed Tundy[QUOTED] likes this.
  7. Nov 21, 2024 at 8:15 PM
    Transmission is shifting butter smooth after the drain and fill + lubegaurd. Pleased.
    Hutcheson, Tlar25, oscardog86 and 4 others like this.
  8. Nov 21, 2024 at 8:58 PM
    bmf4069 Captain wtf
    That's the toytec ultimate kit. They're pretty good. I'd recommend them for a basic lift and some light offroading. I coulda sworn it used to be called the boss kit.
  9. Nov 21, 2024 at 9:13 PM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    So they're toytecs... with Bilstein stickers? I'm confused.
  10. Nov 21, 2024 at 9:17 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Bilsteins that are made for Toytec and they have a threaded body unlike other Bilsteins with perches.
  11. Nov 21, 2024 at 9:20 PM
    bmf4069 Captain wtf
    Those are Cooper st maxx on mine. Highly recommend if you do any offroad activities.
  12. Nov 21, 2024 at 9:21 PM
    FiatRunner
    Jack
    Interesting. Wonder how they compare to 6112s tuning-wise.
    oscardog86 likes this.
  13. Nov 21, 2024 at 9:22 PM
    bmf4069 Captain wtf
    What he said. They're just threaded 5100s. I didn't realize that so I got the aluma rear shocks. It was overkill at the time, but now I need to upgrade the front to alumas as well.
  14. Nov 21, 2024 at 9:25 PM
    bmf4069 Captain wtf
    Iirc, the 6112s are digressive, whereas the 5100s are more linear. I could be completley fucked off on that though.
    FiatRunner[QUOTED] likes this.
  15. Nov 21, 2024 at 9:26 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    https://youtu.be/TE1dFHmFCRk?si=fU8rT2guI0Ol5JQT
  16. Nov 21, 2024 at 9:30 PM
    FiatRunner
    Jack
    I think that's correct if you flip that around.
  17. Nov 21, 2024 at 9:32 PM
    bmf4069 Captain wtf
    Very possible. I talked with @memario1214 about it, but it was months ago and, well, you know. I do remember he recommended alumas for me since I do more crawling than fast boi shit. ADD sucks.
  18. Nov 21, 2024 at 9:35 PM
    FiatRunner
    Jack
    I think that would make sense then. Linear is good for the slow stuff since it has soft damping at slow travel speeds. Digressive can be good for the fast stuff since it has firm damping at higher travel speeds.
    455h0le_dachshund likes this.
  19. Nov 21, 2024 at 9:50 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    So they're a 16" or 17"?
  20. Nov 21, 2024 at 10:21 PM
    Bed Tundy
    Neature Gary
    Moscow, ID
    16x7" +15mm offset. Part number 42611-AF100. Compared to stock 17x7.5", the Outside wheel edge on these moves in toward truck 3mm, but the inside edge moves away from truck and UCA 9mm. little bit more clearance and I think they look really neat.
  21. Nov 21, 2024 at 11:27 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I want to see em on the truck
  22. Nov 22, 2024 at 1:53 AM
    Bed Tundy
    Neature Gary
    Moscow, ID
    Gotta wait until my snow tires are done being on national back order haha. They might have got a shipment in recently. Nokian still make their snow tires in Finland, 265/75r16 D-load studded LT3 with 16.5/32 tread. 31.7” down from 33.4”, but oh well.
  23. Nov 22, 2024 at 5:57 AM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Have found Noco makes the felt discs too for $.99/set presoaked in oil that seem to work better than the dry felt. Probably like @shifty` is accomplishing by adding the grease. And the cleaner can remove corrosion where can't otherwise get to in the cables and connectors.
    oscardog86 and shifty`[QUOTED] like this.
  24. Nov 22, 2024 at 5:59 AM
    ToyotaDude
    ToyotaDude Member
    Leaking is not good. Costco has batteries.
    shifty` likes this.
  25. Nov 22, 2024 at 6:53 AM
    Desert Dog
    2001 SR5 AC 2WD 4.7l
    We think similarly on this. The current poke I have is good enough for me.
  26. Nov 22, 2024 at 6:56 AM
    Desert Dog
    I was given the option by Discount Tire to exchange the Cooper Discoverer AT3 LT's I'm running if I didn't like them when I purchased them.
  27. Nov 22, 2024 at 6:59 AM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    I got real lucky. Small, regional chain, small town with a lot of personal relationships. They didn't have the tire in my stock size, and the employees recommended 265 75 16. It was only after being out on the highway and driving a few dirt roads that I finally backed out of a parking spot and had the wheel at full lock and heard/felt rubbing. I nicely made my case, the owner took a look at the tires and decided if she found the right person, she could sell them as new. So they took them back. But generally, unless it's their screwup, I don't see them taking used tires back.
    I don't think they were happy with me.
  28. Nov 22, 2024 at 6:59 AM
    des2mtn
    SW
    Tonto cover
    They've offered that to us on various vehicles as well, but never needed to do it. I imagine they give you a prorated amount if you do return them.
  29. Nov 22, 2024 at 8:34 AM
    oscardog86
    oscardog86 New Member
    Southern California
    Toquerville Falls! Love that spot!
    Tlar25[QUOTED] and Desert Dog like this.
  30. Nov 22, 2024 at 8:42 AM
    Desert Dog
    The whole state is incredibly beautiful, IMHO, but I can only go during certain times of the year because, you know...cold :D
    oscardog86[QUOTED] likes this.
