Fixed abs to turn around and disconnect it
Discussion in '1st Gen Tundras (2000-2006)' started by USERidiculousNAME, Nov 21, 2024.
  1. Nov 21, 2024 at 6:36 AM
    USERidiculousNAME
    USERidiculousNAME [OP] ToyTurd
    Josh
    New Orleans
    250K on Early 2004 tundra DC 4.7 v8, SR5, RWD, A/T, LSD, w/ABS,TOW, OFF ROAD, ZERO RUST FRAME, BILSTIEN 5100, AAL, 17" 265/70
    Backup camera, camper shell, double din stereo, amp, sub, blind spot cameras, modest lift, newer Tacoma rims, large AT tires, interior lighting upgrades, in bed, under hood, as well as leds in cab, blue foot well strips (night driving)or bright white strips if need to see, 3 additional white leds on ceiling front L/ R and center, toggle switch's and added accessory fuse box.
    [​IMG] not sure about this20241117_203747.jpg 20241117_203747.jpg 20241117_203821.jpg
  2. Nov 21, 2024 at 6:37 AM
    ATBAV8
    ATBAV8 Mr. Bentley-He builds fast trucks.~Ettore Bugatti
    Tempe, AZ
    Bilstein 5100s with OME 2884 springs, Firestone RideRite airbags.
    What is your question?
    87warrior and KNABORES like this.
  3. Nov 21, 2024 at 3:58 PM
    USERidiculousNAME
    Josh
    New Orleans
    I have no question, making a statement about common ABS issue talked about on here. With no real solution posted. I don't know how much time I spent trying to fix this Pic 3 is saying its normal operation! Thats crazy to me. I did an entire rear axle/ diff swap on truck shortly after getting it. Due to previous owner backing boat into lake/swamp/gulf, the abs wasnt working after this but it never bothered me. While doing tune up and concidering trading it in for a 4runner, i knew abs light would be a problem. So while fixing abs and brakes. I ran into same issue so many people on here were never able to figure out and ended up disconnecting it. Stumbled across this in my manual saying ABS acting that way to normal! I find it hard to believe but there it is in black and white and yellow. Still can't believe that its functioning correctly. Glad I spent all that money and time to end up pulling a fuse.
  4. Nov 21, 2024 at 4:10 PM
    You still haven’t said what it’s doing that’s normal but that you don’t like
  5. Nov 21, 2024 at 4:32 PM
    Is it randomly engaging? We have a thread dedicated to ABS solutions. Typically the problem is bad O-ring, improperly seated sensor, someone pressed the tone ring on wrong/tone ring alignment is bad, or there’s shit on the sensor (or sensor is bad/aftermarket).
    Radix likes this.
  6. Nov 21, 2024 at 4:38 PM
    ATBAV8
    Tempe, AZ
    So, if you determined that it's "fixed", what necessitates pulling the fuse?
  7. Nov 21, 2024 at 4:53 PM
    Man I wish @Pucks18 was here. He’d solve this shit faster than fast. That kid was a goddamn autistic genius.
  8. Nov 21, 2024 at 5:39 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    instead of brushing my teeth last night i decided to simply pull out a tooth instead. Hindsight a day later, i should have just brushed my teeth. No idea that bruxing was such a problem.
    des2mtn, ATBAV8 and shifty` like this.
  9. Nov 21, 2024 at 5:48 PM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    The manual describes how the ABS is designed to operate, yes, but the common ABS issue people experience isn't normal operation of the ABS system. I say this as someone who's dealt with fully functioning ABS which eventually began to act up and engage incorrectly.
    The ABS sensors are a magnetic sensor that works off a tone ring on the axle shaft.
    The sensor reads the teeth of this tone ring and there is a voltage fluctuation every time a tooth on the gear passes. If the sensor is dirty or not seated correctly, the sensor will read the teeth incorrectly. The main solution for many people is to clean the sensors and re-seat them properly, and change the o-ring on them if it looks damaged. A damaged wiring harness could also be a culprit.
