  1. Nov 21, 2024 at 7:38 AM
    You know, that's kind of interesting. I'm pretty sure my sticker says 245/70/16, but it's always had 265/70/16s since I got it. 245s didn't come on patricks, did they?
    Dook55[QUOTED] likes this.
  2. Nov 21, 2024 at 7:38 AM
    They did on non-TRD OR models
  3. Nov 21, 2024 at 7:38 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    You ever run race gas?
  4. Nov 21, 2024 at 7:39 AM
    $$$ with no appreciable benefit
  5. Nov 21, 2024 at 7:41 AM
    Nah, cause the math doesn't add up.
    oscardog86 likes this.
  6. Nov 21, 2024 at 7:41 AM
    Neo
    Neo New Member
    Alabama
    @shifty` You made me go back and check my math! Top arrow is the trip odo reading for the last leg of interstate home. Next arrow is total miles on the truck. Third is (obviously) the gallons to top it off. Fourth was the total trip odo. 130.1 mi / 7.241 ga = 17.96 MPG.
    The 02 AC is running 265/70-16 Michelin LTX A/T 2s (need to be replaced soon). The truck is being garaged while I have it, so I set the tires to 32 PSI at 70 F temperature inside the garage. (I would have to park it outside with 50 F overnight temps for the duration of the trip. The interstate was moderately hilly. The only other possible advantage is that I installed that Truxedo tonneau. With this truck, I really tried to set the cruise on 70 MPH as much as possible, but traffic was not always cooperative.
  7. Nov 21, 2024 at 7:43 AM
    Not yet. I need to get the tune figured out first. plus 450hp is about the max for the 4.6 so I don't wanna push it much further. However, Haltech is an Australian company, so I've been chatting with some Aussies on the bookface about doing a remote tune.
    KNABORES likes this.
  8. Nov 21, 2024 at 7:43 AM
  9. Nov 21, 2024 at 7:44 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    I honestly think that inclines and declines also play a big role when you get low on gas. I've driven my toyotas to damn near empty a few times. The only time I got a p0171 that I suspect was the fuel pump was when I drove my taco in the hills with the gas light on. I had to go up a big hill to get to the gas station and the truck almost stalled as I pulled up to the pump. The CEL came on a few weeks later on a road trip.
    MT-Tundra[QUOTED] likes this.
  10. Nov 21, 2024 at 7:52 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    But he's got a supercharged racecar
    bmf4069 likes this.
  11. Nov 21, 2024 at 7:52 AM
    Neo
    Neo New Member
    Alabama
    @KNABORES you might be on to something! Jut saw that the service manual has a wattage specification (below) for the bulb used to test the Fuel Level Warning Switch.
    The Sylvania replacement bulb I got from AutoZone is only rated at 1.4 watts. I wonder if the same is true for the Wiper Fluid Warning light?
  12. Nov 21, 2024 at 7:55 AM
    "racecar"
  13. Nov 21, 2024 at 7:56 AM
    I use Road Trip LE on my phone. The LE or Lite Edition lets you track one vehicle for free. I swore I updated to the pay version at one point to track both vehicles, but ... when I checked again in my purchase history, shit wasn't there. Either they pulled the app, or I'm losing my mind.
    Tlar25[QUOTED] likes this.
  14. Nov 21, 2024 at 7:58 AM
    Unless it requires 107 or whatever flavor you can get there, there’s no benefit to run it. If 93 will do, you’ll get the same results on 107 as you do on 93. Now, if it’s pulling timing on 93, upping the octane may give a little more power.
  15. Nov 21, 2024 at 8:02 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    If the 03 is a racetruck with its slushbox and what-nots, your Vic is a racecar with its SC and 6 speed
    Thems the rules.
    Tlar25 and KNABORES like this.
  16. Nov 21, 2024 at 8:08 AM
    Dook55
    Dook55 RCLB Guy
    Montana
    Thanks, it never occurred to me that the door sticker would have the original tire size. My 2004 RCLB with tow package originally came with 265/70R16's
    KNABORES[QUOTED] likes this.
  17. Nov 21, 2024 at 9:25 AM
    Upshot Knothole
    Upshot Knothole New Member
    Thatchery
    Outside of PDX OR
    2003 SR5 V8 AC TRD 4x4
    I've been driving back and forth between Portland and my parent's place out towards the coast in Oregon all year. Once I'm off the interstate and driving primarily on flat, rural two lane highways, I'm lucky if I get above 55 MPH. I routinely see about 16-17 MPG with 265/75/16s, even occasionally 18 MPG if I can avoid driving in town. Now when I spend time driving in Portland, it's back down to like 14-15 MPG because of stop and go traffic. But driving in the country, especially if there's traffic, the engine is usually sitting right about 2K RPM. Great for fuel mileage, but damn do I get bored spending all day driving 45-55 MPH.
  18. Nov 21, 2024 at 9:36 AM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    I bought my truck in Boise and drove it back to Montana. Between the two there's a stretch of wide open, sagebrush & volcanic rock terrain through Craters of Moon National Monument with a 55 or 60mph speed limit. Miles and miles of open country, and at least if you're concerned with getting pulled over, 55/60mph. It's brutal in a modern vehicle. Especially when you can see miles in every direction.
    Tlar25, bmf4069 and 455h0le_dachshund like this.
  19. Nov 21, 2024 at 10:18 AM
    Bed Tundy
    Bed Tundy Like changing a tire, the 1st time you're careful
    Neature Gary
    Moscow, ID
    (W) 2005 AC 4.7 4x4 with VSC, (G)2005 AC 4.7 TRD Sport RWD
    See Signature or my Photo Album
    My bikstein B8 5160 rear shocks came in the mail today. Anyone else running these and also the 90-221HD rear leaf springs? I’m considering installing both at the same time. I just want to make sure the two are compatible. The 5160s say 0-1.5” of lift compatible, I won’t get more than 1.5” out of the HD leafs will I?
  20. Nov 21, 2024 at 10:22 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    You'll be fine. I've been running the 5160's on my OEM leafs with wheelers AAL and also with my Alcan leafs.
    Bed Tundy[QUOTED] and bmf4069 like this.
  21. Nov 21, 2024 at 10:37 AM
    Pro tip: If not already going that way, I'd recommend removing the shock on one side, swapping the leaf pack, then installing the shock once the leaf pack is bolted in. You need to unbolt the bottom shock mount anyway in order to swap the new leaf pack in successfully anyway. Also, frankly, it's easier just to cut or split the top nut on the shock than whing it off normally. Likewise, your OEM bottle jack that came with the truck comes in clutch as a 2nd pair of hands to raise/lower the axle and raise/lower the leaf pack when bolting it up.
    Ratcheting wrenches are your friend for the shock top nut. If I had a dollar for every person who ever forgot the top of the shaft on the Bilsteins had a allenhead provision, I'd be loaded :rofl:
    Aside from that, I take it you got longer u-bolts for the new leaf packs? So you don't get stick
    oscardog86 and Bed Tundy[QUOTED] like this.
  22. Nov 21, 2024 at 11:28 AM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    Doing another one of my 900 mile round trips to visit the GF this weekend. Gonna be cold and windy. We'll see what the MPGs will be.
    I was hoping to get some good accurate info last time I went but the coil going bad really goofed up my data. I also think the scangauge estimate is more optimistic than it was before now that I've got the new tires. Maybe someday I'll go with 4.10s.
    bmf4069 and Bed Tundy like this.
  23. Nov 21, 2024 at 11:39 AM
    Desert Dog
    2001 SR5 AC 2WD 4.7l
    Got around to putting a new sticker on it
    @dirtydeeds :hattip:
    BroHon, bmf4069 and Bed Tundy like this.
  24. Nov 21, 2024 at 11:41 AM
    Bed Tundy
    Neature Gary
    Moscow, ID
    Parts I have not on order include 5160s, 90-221HD springs, longer U-bolts, new bump stops, and new eye bolts for the oem shackles in case I have to sawzall them out.
    *Is it worth $180 to get new shackles?
    *I am interested in Archive Garage U-bolt flip kit for less drag in the snow ($180) but I don’t want to pay an additional $200 for their special bump stops. It looks like the OEM bumps are not compatible with this kit.
    *Please tell me about this allenhead provision!? My shock tops look like this. IMG_4330.jpg
    oscardog86 and bmf4069 like this.
  25. Nov 21, 2024 at 11:50 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    My 01 TRD shows 245/70 so not sure what decided on tire size.
  26. Nov 21, 2024 at 12:23 PM
    TXTundraGuy23
    Dallas
    2004 DC 4.7L 4WD
    I need to look up yellowbox. Never heard of it, but I'll definitely be doing that when I upsize the tires.
    Yeah I keep on going back and forth between the 275/70/17 and 255/80/17, but need to make a call by Black Friday. I've been watching endless first gen videos and looking at google images. Saw this one on youtube and it just hit the spot. Those are the wheels I think I'm gonna get too. This is on 255/80/17s. But dang, 255 just seems skinny!
    oscardog86, Tlar25 and Filthyphil like this.
  27. Nov 21, 2024 at 12:30 PM
    Desert Dog
    255 seems skinny because of cultural phenomena and little regard for application. I've seen a few I really dug with 255's and have considered it myself. You do what works for you and moves you inside. Or, as I sometimes put it, people's opinions don't pay my bills, so I don't care what one may think.
    oscardog86, shifty` and Dook55 like this.
  28. Nov 21, 2024 at 12:34 PM
    Mustanley
    Mustanley Two time totaler
    Hendersonville, NC
    2004 Limited TRD 4x4 DC
    Eibach Shocks/Coils|Doug Thorley Headers|Spintech 3000XL Muffler
    Here something to compare to... I'm only running 255/75/17 so a bit smaller diameter but I think they fit these 7" wide wheel s a little better than a wider tire would anyway.
    Voss, oscardog86, Desert Dog and 4 others like this.
  29. Nov 21, 2024 at 12:45 PM
    Here's a couple pics of my 255s/85/r16s. I love them.
    They're not the best shots, but it's what I got.
  30. Nov 21, 2024 at 12:59 PM
    https://www.tundras.com/threads/yellow-box-speedo-calibrator.31996/
    Who do I need to stab in the neck to get that C10 in the bg? :rofl:
    Looks ballpark the same color as my '68 stepstide.
    Skinny isn't evil, you'll get better slippery traction and it'll handle better and track better on the road. Less strain on suspension too, I believe.
    But both diameter and width will fuck you on rubbing. I think the 275/70r17 give you the best of both worlds. It'll be ¾" wider than the 255/80r17, and ½" - ¾" less diameter, should look beefier minus the woes that come with 285/70r17. Just remember, if you get A/T tires, they'll almost certainly be 0.1 - 0.4" taller than tire calculator in many cases... it seems like all-terrain are nearly always ¼" larger than calculator spec, maybe it's the added gnarly tread? So your 33.1" tire (the 255) will probably be closer to 33.5". More aggressive tread means more knob protrustion means more significant rub. It looks like the only tires I see that are close to true-to-size are C-rated, almost all E-rated are oversize, though some brands just run everything oversize. For example, Nitto Ridge Grapplers, you're at 33.3" which puts you in hammer-the-fuck-outta-pinchweld-city :
