Automatic Headlights Activation Adjustments
Discussion in '3rd Gen Tundras (2022+)' started by akira, Nov 21, 2024.
  1. Nov 21, 2024 at 8:29 AM
    akira
    akira [OP] 25 Tundra Limited TRD OffRoad
    San Diego
    I have a Limited with the automatic headlight option. In the multimedia settings, you can select Brightest, Bright, Normal, Dark, Darker as options for when the headlights come on.
    Looked through the manual and not seeing description of what the above settings impact.
    The goal is for my headlights not to come on when it is still fairly light out because my screen dims to the point where it's difficult to see.
    Let me know if you you can clarify should I go to the Bright or Dark setting.
  2. Nov 21, 2024 at 8:31 AM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    Adjust to darker. Meaning, it will be darker before they come on.
    I had the same question until I did some actual testing.
    akira[OP] likes this.
  3. Nov 21, 2024 at 8:34 AM
    akira
    San Diego
    Thank you! Think I confused myself on what setting to use. I tried to adjust setting yesterday and only have so much light before running out of time to test.
  4. Nov 21, 2024 at 8:51 AM
    nodak67
    nodak67 New Member
    JR
    correct me if i am wrong but the MID brightness is independent of the headunit setting. as least for our tundra. had to turn it down during night time since it was so bright vs the center console.
  5. Nov 21, 2024 at 9:07 AM
    DRP
    DRP Old Member
    Dave
    I believe you are correct there is a separate setting for the screen brightness at night, but I think he was referring to when the screen goes into night mode.
  6. Nov 21, 2024 at 9:08 AM
    Raven67
    Kentucky
    True, when the headlights come on (as per your setting) the dash lights & screen dim, so then you can make your adjustment seperate from the headlight setting.
  7. Nov 21, 2024 at 9:08 AM
    akira
    San Diego
    Yes, was referring to when the screen goes into night mode.
    Thanks all for the quick feedback.
    DRP[QUOTED] likes this.
  8. Nov 21, 2024 at 9:09 AM
    nodak67
    nodak67 New Member
    JR
    i have our headunit in dark mode all the time. i think it can be set to daytime, nighttime or auto
    DRP[QUOTED] and Raven67 like this.
  9. Nov 21, 2024 at 9:24 AM
    akira
    San Diego
    Same. I’m in dark mode all the time.
    nodak67[QUOTED] likes this.
