Question about universal seat heaters…..
Discussion in '2.5 Gen Tundras (2014-2021)' started by shawn474, Oct 19, 2024.
  1. Oct 19, 2024 at 4:30 PM
    shawn474
    shawn474 [OP] Lego connoisseur
    MoCo, Maryland
    I bought these Dorman universal seat heaters about 2 or 3 years ago.
    https://www.jegs.com/i/Dorman-Produ...X2aVQ-1n4NdpjP9AHgpS2EqAOGOHGs72hL2KguY3fi_dT
    Had some time today and decide to install them. I have Clazzio covers over my factory cloth seats. I installed these directly onto my cloth seats and reinstalled the clazzios.
    My question is regarding the wiring harness…..do I have to wire these directly to the battery? It has a fuse tap so I am wondering if I need to to both. Or. An I just tap into an accessory wire somewhere in the truck? The instructions are below. I am not an electrical whiz so please forgive my ignorance……
  2. Oct 20, 2024 at 6:04 AM
    Glockman2018
    Glockman2018 New Member
    When I installed mine, I just wired them to the usb in the center console.
  3. Oct 20, 2024 at 6:14 AM
    shawn474
    MoCo, Maryland
    ok thanks - so simply tap into the red wire of the usb with the red wire of the seat heater and ground the brown wire to chassis?
    Jaypown likes this.
  4. Oct 20, 2024 at 6:17 AM
    Glockman2018
    Correct. Though I used a ground somewhere near the shifter to the left. I also mounted my switches up towards the front of the console near the upper most cup holder.
  5. Oct 20, 2024 at 9:26 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Same here, I tapped into the 12volt plug in the console.
    They are all on the same circuit, but front and rear powered by separate 15A fuses..
    Except the USB has it's own 7.5 amp fuse.
    I also put the switches forward on the console.
  6. Oct 28, 2024 at 10:53 AM
    shawn474
    MoCo, Maryland
    @Glockman2018 and @1lowlife , am I understanding correctly that you clipped the red power wire on the seat heater harness and tied directly to the 12 v outlet red wire? Obviously have to ground them as well but am I understanding the power part correctly? No need for the fuse tap????? I assume that’s correct since there will still be an inline fuse and relay
  7. Oct 28, 2024 at 11:29 AM
    Glockman2018
    Correct. I didn't use a fuse tap. Red wire to red 12v wire and I grounded it to a bolt underneath shifter area. Inline fuse and relay are zip tied to the shifter area. If I have time today I'll take a couple pictures.
    shawn474[OP] likes this.
  8. Oct 28, 2024 at 11:34 AM
    shawn474
    MoCo, Maryland
    Awesome thanks so much.....last question. CAn you tie both heaters to the same 12v outlet or should I do one heater to the front 12v outlet and one heater to the rear console 12v outlet? I am guessing one to each so as to not overload the circuit if both are in use??????
  9. Oct 28, 2024 at 11:52 AM
    Glockman2018
    I just quickly pulled it apart and took some pictures. I tied both heaters to same 12v wire in center console. Never had any issues when both heaters were on.
  10. Oct 28, 2024 at 11:54 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Mine are also tied to the same 12v wire. No issues.
  11. Oct 28, 2024 at 12:15 PM
    shawn474
    MoCo, Maryland
    Are you still able to use the 12v socket to charge your phone, etc while using the heaters?
  12. Oct 28, 2024 at 12:18 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Honestly never tried since there's a few USB ports under the HVAC controls. The seat heaters don't pull that much power so I can't imagine it being a problem.
    shawn474[QUOTED][OP] likes this.
  13. Oct 28, 2024 at 5:00 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    As you can see in the wiring diagram I posted above, the dash and rear 12volt plugs are on separate fuses on your 2019..
    I tapped into the rear 12volt plugs with a POSITAP (positive and negative) and left the existing fuses that were on the seat heater wiring harness.
    On my 2014 all the plugs are on the same circuit, I don't use them anyway.
    I use a wireless console charger to charge the phone, which also runs off that circuit..
    You'll be fine, don't overthink it..:thumbsup:
  14. Oct 28, 2024 at 5:59 PM
    shawn474
    MoCo, Maryland
    Thanks all; got them wired up this evening and they are toasty. Just in time for the cold mornings
    Jaypown and Patch999 like this.
  15. Oct 28, 2024 at 6:55 PM
    TundraWA2017
    TundraWA2017 Red Lobster anyone?
    WA State
    2017 Silver Sky SR5 TRD OR CM
    Good to know, thanks.
  16. Oct 29, 2024 at 12:47 PM
    Glockman2018
    Have you added a remote start to make the seat heaters already warm when you get in it?
  17. Oct 29, 2024 at 12:56 PM
    shawn474
    MoCo, Maryland
    Yes that was one of the first mods when I got the truck
  18. Nov 20, 2024 at 11:30 AM
    shawn474
    MoCo, Maryland
    Forgot that I never updated with pictures….took other members suggestions and installed on the console. They work really well.
    Jaypown and Glockman2018 like this.
  19. Nov 20, 2024 at 6:51 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Looks good!
  20. Nov 20, 2024 at 7:18 PM
    shawn474
    MoCo, Maryland
    The wife asked “where did you take that to get done; looks professional….” I immediately side eyed her and walked away before I said something stupid
    TOYOTARIG likes this.
