Fumoto Valve
Discussion in '2.5 Gen Tundras (2014-2021)' started by therealjonwick, Aug 18, 2023.
  1. Aug 21, 2023 at 6:32 AM
    #61
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    I planned on getting these for both the Sienna and the Tundra but on the Sienna, the access cover basically rubs on it. Too close to being damage if we high center something on the road so it's going on the Tundra next oil change. Love the design of it vs the Fumoto style.
  2. Aug 21, 2023 at 6:45 AM
    #62
    SwitchThrottle
    2021 Barcelona CrewMax
    Agreed. I bought a Toyota because of their build quality. If it grenades I'm sure they would make it right. Not worried about it. Only pan I've ever found anything to be worried about was my 450SMR when it was new, but it's basically a race bike with blinkers, and after it's initial self clearancing, has been clean for 16k miles while plenty of others just grenaded.
    I'm gonna valve my 5.7 when it's done with free dealer changes.
  3. Aug 21, 2023 at 7:51 AM
    #63
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I've seen a couple of ~20 y.o. very hot turbo engines pans. Nothing to see in there, only carbon deposits and cooked oil. Pans were fully functional.
    I drive front left wheel on a ramp, so more oil drains from Fumoto. The rest I don't care about. Engine has more than a quart of old oil in oil cooler and camshaft valleys anyways. But my Toyota oil changes are mostly drop-free now. I drain filter housing dry with a long steel pipe right into an empty bottle, most times there's nothing to clean afterwards.
  4. Aug 21, 2023 at 7:52 AM
    #64
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I use the EZ Valve version. Love it.
  5. Aug 21, 2023 at 8:07 AM
    #65
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    My point is that you have some crap and used oil in the bottom of the pan regardless of the Fumoto or not. I have done what I said above with both the fumoto and without, similar results.
  6. Aug 21, 2023 at 8:54 AM
    #66
    huntertn
    huntertn New Member
    Tennessee
    2008 White CrewMax Limited 4x4
    There is a slot in the weld-nut in the pan to let as much oil drain as possible when you drain the pan using the drain plug. Any kinda valve that you screw into the pan is gonna leave some residual. I am not sure how much of a difference it makes. I use a Fumoto valve.
    There is always some stuff left in the pan unless you remove the whole pan each time and wipe it out with a rag o_O
    AZBoatHauler likes this.
  7. Aug 21, 2023 at 9:46 AM
    #67
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    I love mine..Makes oil changes a breeze and I dont have to worry about something sticking out from the oil pan.
    farnsrocket likes this.
  8. Sep 3, 2024 at 12:01 PM
    #68
    dadtrucklife
    dadtrucklife New Member
    2021 SR5 TRDOR 4x4 (Army Green)
    Quick oil change is all about your system. Post pics of your oil pan or container. I’m thinking of attaching a hose directly to a container for easy disposal but not sure which container to go with. Previously I’ve drained oil into a large catch pan and funneled the old oil into empty containers. It’s a PITA.
  9. Sep 3, 2024 at 12:16 PM
    #69
    bucketlintels02
    bucketlintels02 Newish Member
    NW Georgia
    2021 Tundra TRD-Pro Crew
    RAS Road-Active Suspension System HD. 2" (estimated) Spacer and Block Lift . S&B CAI - closed VLED Footwell lighting MESO Customs Interior Lighting 285/65/18 KO2 Gator Hard Cover Tri-Fold AJT Designs interior trim CSU 9 - year ceramic coating Rigid Amber Fog Covers Full Tint (70% Windshield) 20% all others.
    I posted in another thread as well, but is there any concern about the Fumoto valve not being magnetic to collect metal shavings (small) ? I ordered mine but am now having second thoughts versus just using the standard magnetic drain bolt.
  10. Sep 3, 2024 at 12:54 PM
    #70
    AZBoatHauler
    So.Arizona
    No - I’m not concerned. I’ve been running a fumoto for about 75k miles and just did my first oil analysis at 100k miles. Everything looks perfect.
  11. Sep 3, 2024 at 3:42 PM
    #71
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    Are oil pan drain plugs magnetic??
    I know the one in my wife’s Buick isn’t
    Can’t find the one for the tundra it’s not where I put it 5 yrs ago :goingcrazy:
  12. Sep 3, 2024 at 3:57 PM
    #72
    AZBoatHauler
    So.Arizona
    I didn’t think they were - only the rear diff is my recollection.
    Leo's first[QUOTED] likes this.
  13. Sep 3, 2024 at 5:30 PM
    #73
    bfunke
    bfunke Tundra Curmudgeon
    Would have been nice if Toyota points the drain plug straight down. My starts drawing fine into my drain pan but then after 1-2 qts it come out so fast it splashes on the passenger side tire and wheel and makes a huge mess. Seriously considering a Fumoto.
  14. Sep 3, 2024 at 5:43 PM
    #74
    Leo's first
    Groton ma
    I use a 5 gal bucket
    Finish oil change cover bucket take to hardware store .5 mi return home check stick and for leaks wipe bucket replace oil change kit cover done #
  15. Sep 3, 2024 at 6:02 PM
    #75
    ejes
    ejes New Member
    2020 1794 Tundra / 2023 4Runner TRD PRO
    THIS is why I got one. I got the one with the nipple to put hose on it to direct the drain down into the pan. First time I drained the oil in my 2020 it got all over the tire, wheel, ramp, floor, etc. The Fumoto totally solved that. A 5 gal bucket under there is a pain if you use ramps or a jack IMO. Still have to tip it and worm it around jack stands, etc. to get it out. This way I can still use a flat pan, leave it under there and move to catch any drips while I'm filling, etc. and then drive off the ramps with it still sitting there.
    I had one on my 2004 Ram before that with no problems, but wasn't going to install on on the Tundra until that first oil change. Get one and you'll be happy with it. Used them for 20 years now and never had a problem with them. Even put them on my ZTR mowers.
    Leo's first likes this.
  16. Sep 3, 2024 at 6:41 PM
    #76
    It is not. Most auto manufacturers got rid of them due to the amount of people freaking out when they see them during an oil change.
  17. Sep 4, 2024 at 4:26 AM
    #77
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I drain directly into the empty 1 gal oil jug left from a previous oil change. No jacking, just the driver's wheel on the ramp, for better pan flow. The filter housing is also drained directly to the bottle, I use a stainless steel tube of appropriate OD that goes into the plastic drain tool that comes with a new filter.
    ejes[QUOTED] likes this.
  18. Sep 4, 2024 at 4:39 AM
    #78
    farnsrocket
    farnsrocket New Member
    I've been using this ValvoMax quick drain plug that @TXTundra2722 recommended....its really nice and built like a tank. You screw on the big threaded knob with a hose attached and it pushes up a ball bearing to release the oil. Really easy and pretty quick to drain. No mess afterwards and the cap to cover it is solid.
    I also use this oil drain tool for my oil filter to clear it out before I take it off
    https://a.co/d/4kjqsMO
    https://imgur.com/NAzoeKy
  19. Sep 4, 2024 at 6:40 AM
    #79
    SnrDisregardo
    Wade
    IL
    I got one of these too. I drain it right into a 2 gallon oil jug. No mess what-so-ever.
    Ebrperk likes this.
  20. Sep 4, 2024 at 7:15 AM
    #80
    ejes
    ejes New Member
    I'm too large to fit under there without ramps, lol.
  21. Sep 4, 2024 at 7:40 AM
    #81
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    You meant to say your truck has insufficient lift?
  22. Sep 4, 2024 at 10:11 AM
    #82
    dadtrucklife
    The Valvomax product looks very solid but I don’t think it’s been around very long relative to Fumoto so I question its long term reliability. I like the design of the Valvomax over the Fumoto though so I’m torn.
  23. Sep 4, 2024 at 3:40 PM
    #83
    farnsrocket
    Trust me, this thing will outlive me……..everything about it solid and stout.
  24. Sep 7, 2024 at 11:31 AM
    #84
    TXTundra2722
    2015 Black Tundra
    What's nice is if you want to go a step further.... they sell their own plastic jugs that attaches to the drain tube and other than lying the oil filter off.... you have no open/exposed oil to make a mess.
  25. Nov 20, 2024 at 3:58 PM
    #85
    bflooks
    bflooks New Member
    Metrowest MA
  26. Nov 20, 2024 at 6:25 PM
    #86
    CasperTheFriendlyTundra
    CasperTheFriendlyTundra New Member
    Stick the magnet to thr bottom of the oil pan, remove thr magnet before you drain the oil.
  27. Nov 20, 2024 at 6:51 PM
    #87
    seydou
    seydou Distinguished Member
    I only have experience with Fumoto but there is also the Stahlbus and the EZ Oil Drain Valve.
    https://www.stahlbus-us.com/oil-drain-valve/oil-drain-valves-with-retainer/
    https://www.ezoilchangevalve.com/store/p12/EZ-108_[Thread_size_:_16mm-1.5].html
  28. Nov 20, 2024 at 7:00 PM
    #88
    Rc23
    Rc23 New Member
    Ross
    Chesapeake
    '16 Super White CrewMax
    The valvomax/stahlbus style has been around forever. I had a votex valve on a cadillac CTS back in 2013 and put one on my Tundra after I bought it. I'm not a huge fan of the fumoto lever although I know it's reliable I just like this style better.
    https://votex-us.com/SMQDP006
    Made in the USA
