Toyota OEM TRD Front Recovery Hooks
Discussion in '3rd Gen Tundras (2022+)' started by RatPanda, Nov 12, 2024.
  1. Nov 17, 2024 at 4:03 PM
    #91
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
  2. Nov 17, 2024 at 6:37 PM
    #92
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    Do they whistle like blowing across a beer bottle at speed? lol
  3. Nov 17, 2024 at 7:13 PM
    #93
    LB-1889
    LB-1889 New Member
    Hopefully like this!
  4. Nov 17, 2024 at 7:24 PM
    #94
    thomez
    thomez New Member
    NE Ohio
    Silver ‘24 Tundra Platinum
    I should buy that ….. :spending:
  5. Nov 17, 2024 at 7:38 PM
    #95
    PNW Tundra Mike
    Southern Cal
    Have these on my bike and have to say none have crossed in front of me thank God. It’s heads and ears up when I’ve seen them and passed.
  6. Nov 17, 2024 at 8:25 PM
    #96
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    And hopefully NOT like this:
  7. Nov 19, 2024 at 5:14 AM
    #97
    Rockpig
    Rockpig You did what?
    08 Limited
    How is the clevis pin held in? I see it uses a hitch type slide pin on the end but is that the only way it holds it in or does it screw in like a standard clevis? Either way I wouldn't leave them on the truck, just asking to be stolen especially with how cool they look.
    sudobash likes this.
  8. Nov 19, 2024 at 7:04 AM
    #98
    eddiefromcali
    Eddie
    100% Stock
    screw in
  9. Nov 19, 2024 at 7:19 AM
    #99
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    Looks better without the shackles on, I would buy them.
    Tundrastruck91 likes this.
  10. Nov 19, 2024 at 8:03 AM
    #100
    LB-1889
    LB-1889 New Member
    Also has a snap pin that keeps them from unscrewing themselves and falling out.
    eddiefromcali[QUOTED] likes this.
  11. Nov 19, 2024 at 8:10 AM
    #101
    SDHNTR
    SDHNTR New Member
    no one has answered the question… Will this become an option to have factory installed? Yes, of course, as it should have been all along!
  12. Nov 19, 2024 at 9:35 AM
    #102
    Rockpig
    08 Limited
    Any chance to see the pin out? Looks like the end is a 12 point and I'm not seeing a hole in it like a standard pin. Does it come with/use a special tool? Reason I ask is because 90% of people that buy this will tighten that pin down as hard as they can so it can't be stolen. Standard shackles have a flat with a through hole in it. That way if it gets tightened down you can use a screwdriver or pliers to get it off. This looks like there is no hole and would use a 12 point style socket to get it off if it was tightened down or rusts on. Using your standard leather man type tool isn't going to work, pin is too big, you'd need something like slip joint pliers with teeth, not something someone usually carries around.
  13. Nov 19, 2024 at 5:53 PM
    #103
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    This picture has a cotter pin on the end and looks to be thread less for that TRD shackle.
  14. Nov 19, 2024 at 6:02 PM
    #104
    sudobash
    sudobash New Member
    Correct. They DO screw in. Clevis pin with a cotter pin to keep the clevis pin from falling out.
  15. Nov 19, 2024 at 6:22 PM
    #105
    RatPanda
    RatPanda [OP] New Member
    2022 Tundra 4x4 CrewMax 5.5
    It screws in AND it has the cotter pin to keep it from unscrewing itself.
    sudobash, Vizsla, Yaboy and 1 other person like this.
  16. Nov 19, 2024 at 6:36 PM
    #106
    az 3rdGen
    az 3rdGen New Member
    Arizona
    2022 Black Tundra SR5
    It would be great if people only spoke to information that they were certain about. Like users that actually bought and installed the items... or very least, seen it in person.. straight up spreading false information.
    @LB-1889 installed it and his earlier comment confirms it is both threaded and pinned.
  17. Nov 19, 2024 at 8:16 PM
    #107
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    I like the look without any clevises.
    Agree and just having a tow point is enough.
    Blufin, sudobash and Yaboy[QUOTED] like this.
  18. Nov 19, 2024 at 8:58 PM
    #108
    LB-1889
    LB-1889 New Member
    I don’t have access to the clevises for pics right now but the side that appears to have the 12 point head the opposite side is threaded, and has the snap ring (similar to the one below) and a hole. This is for the supplied TRD clevises.
    sudobash and az 3rdGen like this.
  19. Nov 20, 2024 at 5:46 AM
    #109
    sudobash
    sudobash New Member
    Interesting.
  20. Nov 20, 2024 at 5:46 AM
    #110
    sudobash
    sudobash New Member
    The install instructions tell you store the clevises and not leave them installed until they are needed.
    Tundrastruck91[QUOTED] and Yaboy like this.
  21. Nov 20, 2024 at 2:42 PM
    #111
    H-10BTR
    H-10BTR New Member
    2023 Tundra TRD Pro
    Just got the kit today. Hope to install it tomorrow. Everything seems pretty stout but will probably end up with some different shackles too when finished.
  22. Nov 20, 2024 at 3:05 PM
    #112
    eddiefromcali
    Eddie
    100% Stock
    :duh:
    It'S nOt ThReAdEd
    Nm6300'asl, kirkb, sudobash and 4 others like this.
  23. Nov 20, 2024 at 3:17 PM
    #113
    99ways2die
    99ways2die New Member
    NJ
    Gotta hand it to Toyota - redesigns a truck with NO tow points/etc, then....2 years later....releases a kit with shackles big enough to kill an elephant, tow a nuclear submarine or serve as basketball hoops at NBA finals.
    No wonder they don't want you driving around with 'em attached - probably more solid than the rest of that truck put together!
    astrength22, AZBaldy, kirkb and 4 others like this.
  24. Nov 20, 2024 at 3:48 PM
    #114
    TundBP
    TundBP New Member
    23 Blueprint Platinum
    Or tow freighters and cruise ships through the Panama Canal!
    I like the shape and TRD letting, but I would take it for $150 less and gets normal looking ones. Maybe some nice matching TRD red hooks.
    astrength22 and sudobash like this.
  25. Nov 20, 2024 at 5:44 PM
    #115
    LB-1889
    LB-1889 New Member
    got mixed up on my sides of threading, thanks for the pics.
  26. Nov 20, 2024 at 8:11 PM
    #116
    H-10BTR
    H-10BTR New Member
    2023 Tundra TRD Pro
    LB-1889, did you use the template referenced in the install instructions for cutting the bumper? I didn’t get any templates in the box.
  27. Nov 20, 2024 at 8:16 PM
    #117
    sudobash
    sudobash New Member
    There are no templates in the install instructions including those available on TIS.
    H-10BTR[QUOTED] likes this.
  28. Nov 21, 2024 at 2:22 AM
    #118
    LB-1889
    LB-1889 New Member
    There were none that I could find. I just test fit it and you will be able to see where it is contacting on the bottom. Mark and and remove valance to trim inner structure. I removed approximately 6” wide by 1” deep of material.
  29. Nov 21, 2024 at 4:45 AM
    #119
    thomez
    thomez New Member
    NE Ohio
    So the kit includes a new valence but you still have to do some bumper cutting? Eek
  30. Nov 21, 2024 at 5:53 AM
    #120
    Frank_TRD23
    Frank_TRD23 New Member
    Frank
    2023 Tundra TRD Mag grey
    1.5 Wescott lift 20" wheels on 37s Stillen Trucontroller
    I hope the next tundra has a better frontr grill and bumper to where the first gen3 can do a swap.
    MAC25Tundra likes this.
