Inspection fail
Discussion in '1st Gen Tundras (2000-2006)' started by Otakutoaster, Nov 19, 2024.
  1. Nov 19, 2024 at 11:55 PM
    Otakutoaster
    Otakutoaster [OP] New Member
    WI
    2002 Tundra AC limited Black V8 4wd
    Radio, subwoofer & amplifier, Roll-N-Lock, Cabin air filter,
    I failed inspection twice no check engine light. He said o2k sensor but on the paper it says it's ready. Something is wrong with evap control and the catalytic converter. What's common stuff to look for. I got no codes when scanning the OBD2 at home.
  2. Nov 20, 2024 at 2:02 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Did you get a written Inspection Report detailing the failures? Post it up so we can have a look.
  3. Nov 20, 2024 at 4:02 AM
    Your drive cycles aren’t complete for testing, the evap one takes forever to make ready, the o2 readiness should go away or be ready after about 50 miles of driving(try to hit the interstate)
    Desert Dog likes this.
  4. Nov 20, 2024 at 6:37 AM
    My thought exactly, you haven't hit readiness on all required emissions items yet ^^
    Every state has its readiness requirements, you may not have met all the requirements for your state, as in, you recently cleared codes and haven't driven enough to get to the required readiness. It's possible the truck will pop another CEL when it finally reaches the state of readiness required. This is why you can't, for example, drive up to the emissions place with bluetooth dongle installed, step out of the car for them to test, reset the codes over bluetooth as they're starting the test.
    EVAP needs to be complete, and if you weren't tossing any EVAP codes prior, that should happen soon enough. Go do 10-15 miles of interstate, 5-10 miles of normal stop-and-go traffic, then 10-15 miles of interstate. That has typically done it for other vehicles for me.
    Note that some tools supporting scanning also support deeper diagnostics and instant readiness testing. For example, Tech2 for GM and VAG-COM/VCDS for VW, both of which I've owned/used, let you immediately perform all required readiness checks. It appears Techstream for Toyota does support it, but I've never used either for that. My OBDLink MX+ dongle supports readiness reporting at state-by-state level, but I don't think it operates as aforementioned diag tools do, I don't know of a way to trigger specific readiness tests via their app.
  5. Nov 20, 2024 at 8:12 AM
    Otakutoaster
    WI
    I did a hour of driving prior to the second one and still failed. Both highway and city. I'll try again today. Also on the paper the guy gave me it said my O2 was ready. But he said it wasn't. So why's that?
  6. Nov 20, 2024 at 8:24 AM
    There are two o2 monitors, one is a heater circuit and the other is catalyst efficiency
    Mater likes this.
  7. Nov 20, 2024 at 8:30 AM
    Otakutoaster
    WI
    On the paper both were stated as ready.
  8. Nov 20, 2024 at 8:30 AM
    FYI, you have no engine type in your truck info, aka the "One Line Vehicle Description" HERE ... It's answered, but just saying, why tell us your truck is black?! But not if it's a V8, V6, 2WD, 4WD?!!!! We want to help! That helps us help!!!
    Can you show us the scan, with whatever info you need to redact, redacted?
    Bprose likes this.
  9. Nov 20, 2024 at 8:31 AM
    Otakutoaster
    WI
    Sorry I forgot to add that thought I did.
  10. Nov 20, 2024 at 8:33 AM
    Otakutoaster
    WI
    I put it on. I have the 4wd v8
  11. Nov 20, 2024 at 9:56 AM
    Ok, so, looking at YOUR FSM HERE, which you should download a copy of, I searched for the word "readiness", I came up with the following for your V8 / 2UZ-FE engine. It's important to always look at the title of the page you're on in the FSM to ensure it matches your engine.
    In there, it references the drive cycle you need to follow, which is "LA-4" also known as "FTP-75" when I consulted Wikipedia on the subject.
  12. Nov 20, 2024 at 10:01 AM
    Oh and @Otakutoaster, from the Wiki article, I may be misinterpreting this, but ... it appears LA-4 requires at least one cold start, at least one hot start, and at least 10-¼ non-stop miles of travel not going higher than 60mph, where the average speed is around of 48mph or greater. But that's not the only thing in the test? The method I mentioned of 10-15 miles interstate, 5-10 miles of stop-and-go in traffic, followed by 10-15 miles of interstate has almost always worked for me, without fail, in most (not all) cars I've owned.
  13. Nov 20, 2024 at 10:33 AM
    Otakutoaster
    WI
    So I should drive home then to the emissions place but before that get a cold start in then a hot start?
  14. Nov 20, 2024 at 10:37 AM
    I think we're all having a difficult time answering that w/o seeing the contents of the report.
    I'd like to say, "heck yeah, that's the ticket!" but without seeing the actual report, I don't fully know what's failing. Like, you have a V8, and it has two banks. Is it bank 1 is OK, but bank 2 is NOT READY? There has to be something in the 2nd report that shows the current status, I would hope, to a granular level, and not just a top level PASS / FAIL.
  15. Nov 20, 2024 at 10:40 AM
    Otakutoaster
    WI
    When I'm done getting my tires on I'll go and try again. Who knows maybe I'll pass and if I fail again I'll send a picture of the paper.
  16. Nov 20, 2024 at 10:42 AM
    Otakutoaster
    WI
    Sorry about wasting your time. I was just wondering what it could be.
  17. Nov 20, 2024 at 1:21 PM
    I mean, no time wasted, we're all curious to see. Every problem is a learning experience in disguise.
    jpink and Bprose like this.
  18. Nov 20, 2024 at 1:26 PM
    Otakutoaster
    WI
    I can't go today I'll try tomorrow they were closed.
  19. Nov 20, 2024 at 2:16 PM
    One cool thing about having a decent quality OBDII tool/scanner is it literally shows you readiness and any tests waiting to complete, or already completed. Here’s an example from my truck. I cleared codes on Sun/Mon and I’m good to go already. (There are about 20 more tests in the list below the 5 showing)
    G_unit3000 and FrenchToasty like this.
  20. Nov 20, 2024 at 6:52 PM
    Otakutoaster
    WI
    Yeah I know and plan on buying one in a few weeks.
  21. Dec 6, 2024 at 8:20 PM
    Otakutoaster
    WI
    I put on another 300 miles and passed. I didn't need to drive extra before going. I just checked with my OBD2 scanner and it said good so I took it to emissions and passed.
    tvpierce, FiatRunner, abcinv and 3 others like this.
