  1. Nov 19, 2024 at 10:49 AM
    j-utah
    j-utah performance warrantied member
    Utah
    Fortress of Solitude, CO
    2024 Tundra SR5
    Dice valve stem caps (black)
    Yep!
    TaquitoBandito likes this.
  2. Nov 19, 2024 at 10:50 AM
    j-utah
    Utah
    2024 Tundra SR5
    Foam board then drywall
    Blufin and TaquitoBandito like this.
  3. Nov 19, 2024 at 11:16 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    I put up some Govee Pro Permanent Christmas Lights on the house. No more grabbing the ladder out for (hopefully) 10 or so years. Bottom was easy to put up, tops were a bit of a challenge, but had my dad come over and help hold the ladder for me.
    I went with the Pro's so that i could just set them as white light on the corners and side yards for the other 10 months.
    I think the install came out pretty clean
    PBNB, ACDC2ZZTop, 07 Tundie and 10 others like this.
  4. Nov 19, 2024 at 11:16 AM
    j-utah
    Utah
    2024 Tundra SR5
    If it was a smooth finish like on the east coast, I’d do it. But this textured stuff, I don’t think it’s worth it. I’m pretty good at texturing, but it’s still hard to do without the line telegraphing through and catching your eye. Plus, I’d have to paint over that, and the paint job in this part of the house is so old, any new paint won’t match, so I’d have to paint quite a bit. Maybe someday! For now I’m good with the conduit.
    I could put a fake plant in front of it :anonymous:
  5. Nov 19, 2024 at 11:29 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    Got a link to the ones you used? I was just asking about these yesterday. Our neighbor uses Govee.
  6. Nov 19, 2024 at 11:43 AM
    Danimal86
    Daniel
    Sacramento, CA
    I paid $519 for 200' of the Pro's.
    Just FYI, i thought i was going to be slightly under the 150' kit length, but i could have gotten away with just the 150' kit. I might run them up the side of the house, or just keep a spare and sell the rest.
    https://www.amazon.com/dp/B0CGJ3NF5D?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
    (edit: linked the wrong item, its right now)
  7. Nov 19, 2024 at 12:21 PM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    perfect! thanks for link
    hard wired? or plugged?
    how was splicing them together and the app to run them?
  8. Nov 19, 2024 at 12:34 PM
    Danimal86
    Daniel
    Sacramento, CA
    Our house has a Christmas light outlet on the side of the house up under the eves (on the right side of the gif). So i plugged the power source and controller over there, ran the lights from right to left, then up to the second story and then left to right.
    The pro's come with a bunch of splices and extension. I dont think that the non-pro ones are supposed to be spliced, but people figured out how to do it. Splicing was a little bit of a pain for the first one (getting the sheath off without stripping wires), but the connector is kinda like a Wago connector so it was easy enough. App is pretty good, wish there were more Christmas presets for the Pro's but what i've read, most people make their own color combinations since they are individually addressable. There's also a spot where people create scenes and you can copy them to your house. Pretty cool.
  9. Nov 19, 2024 at 1:02 PM
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    2020 Tundra Limited on 35's
    I've been sidelined with a full distal bicep tear and the surgery required to reattach it. Not entirely fun, but not the worst injury I have ever had. That means no lifting anything over 2 lbs with my right arm. At least I can burn some of the stuff from my yard. Trying to get things cleaned up before winter hits.
    Leo's first, j-utah, Blufin and 2 others like this.
  10. Nov 19, 2024 at 1:50 PM
    Ebrperk
    Ebrperk Old member
    South Central Kansas
    2018 1794 MGM
    Tinted windows, go rhino D6 side steps and shorty antenna, Bilstein 5100's rears, 6112's fonts set to 2.5" Rocktrix RT111 18x9 -12offset NItto Terra Grapplers G3's 275/70 R18's. Amp from James @ Tech12volts FRAC Harness
    I got the same dishwasher and the same Coffee maker
  11. Nov 19, 2024 at 5:03 PM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    That's great to hear. We have a plug underneath our eave in the front with a switch inside to turn them on and off. But if they're programmable, then I'll just leave that switch on and program it. Good to know you can splice them together without issue. Hoping I can do it with about 300-400' of lights....maybe more. Our house bottom floor is around 3500 ft² including the garage it'd go around, so I'm hoping that isn't an issue.
    I seen they're about to have their black Friday sale....so hoping to get it then
  12. Nov 19, 2024 at 5:21 PM
    @Cfincke and @Ebrperk what size is the portafilter basket on that machine, do you know?
    If it's 58mm - 58.5mm, what are you each using for a tamper?
    There's a reason I'm asking. Need to find someone that has an espresso machine that uses ~58mm pf basket and is still using an oldschool tamper.
  13. Nov 19, 2024 at 5:24 PM
    Danimal86
    Daniel
    Sacramento, CA
    Yes they are programmable. I have them turn on 20m before sunset and off at midnight.
    I think you would need to buy multiple kits but Ive read its easy to link multiple kits together in the app.
  14. Nov 19, 2024 at 6:45 PM
    TaquitoBandito
    Joel (AKA Bif)
    Almost done with repainting the living room. One more coat of white paint will hopefully do it and then I can move the furniture back. I'm not sure why I do this to myself. :frusty:
  15. Nov 19, 2024 at 7:03 PM
    I don’t see a printer shelf on the wall, with an alarm system, that triggers gun shots built there.
  16. Nov 19, 2024 at 7:08 PM
    blackoutt
    blackoutt YEAH BUDDY!
    Indy
    07 DC Long Bed - Old Man Tan
    OEM+
    We must get the same adds on social media. I want govee "permanent" lights now. A neighbor has something like it and they're awesome looking but I'm concerned with longevity vs. the labor of a proper clean install.
  17. Nov 19, 2024 at 7:22 PM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    I'm starting to dig into the factory warranty and the 3 year warranty available to purchase for $70 or so through Bezo's mart
  18. Nov 19, 2024 at 7:33 PM
    TaquitoBandito
    Joel (AKA Bif)
    That's the room next to this one with the security camera and alarm system that shoots bean bags at crotch level. Blood is hard to get out of the crevices in the wood floor.
  19. Nov 19, 2024 at 7:45 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    I bought strands of multi-color LED lights from Walmart five plus years ago. I've only installed them once yet they light my house every holiday season. IMG_7484.jpg
    https://www.walmart.com/ip/100-Coun...hthosxZ0zUHWPGUq1NTDg0BWVjlOjqh8aAnIlEALw_wcB
  20. Nov 20, 2024 at 5:34 AM
    blackoutt
    Indy
    OEM+
    This is what I put up and take down every year. Even added some extra Walmart holiday time twinkling nets over the bushes this year! The HOA would NOT allow them to stay up more than 30 days past the "holiday season" which is set at their discretion. Solution? Move out of HOA neighborhood? lol
    j-utah and OldGuy03[QUOTED] like this.
  21. Nov 20, 2024 at 6:57 AM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    Hahaha. Funny you say this as I almost added this line in my post above.
    However, I do live in a street with only 4 other houses and no HOA.
    so to answer your question, yeah that HOA board sucks,and your long term solution is to get away from it.
    j-utah, Blufin and blackoutt[QUOTED] like this.
  22. Nov 20, 2024 at 9:05 AM
    j-utah
    Utah
    2024 Tundra SR5
    I can tell you have great painting skills. This looks really good. Finding people to do good work at a price that makes it worth it to let them loose in your house, that's what keeps me doing it myself.
  23. Nov 20, 2024 at 9:09 AM
    TaquitoBandito
    Joel (AKA Bif)
    It's all in the photography, my friend. :D
    Seriously though, thank you. It's not perfect but the amount of money saved is definitely worth it.
    OldGuy03 and j-utah[QUOTED] like this.
  24. Nov 20, 2024 at 9:18 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    whats the color name? Daughter might like it since shes ready to change from her current pink room. I spy a matryoshka doll
    I hate cutting in with such contrasting colors because dips are so obvious...cant see any here. :thumbsup:
  25. Nov 20, 2024 at 9:30 AM
    TaquitoBandito
    Joel (AKA Bif)
    Thanks!
    The color is called Ash Violet. My oldest stepdaughter who passed away from Huntington's loved purple and her middle name is "Ashley" - I found that color when we moved her so it was like bringing her with us.
    Here's the exact code from the can:
  26. Nov 20, 2024 at 9:32 AM
    eddiefromcali
    Eddie
    100% Stock
    Sorry to hear about Ashley. That color seems like the obvious choice
    j-utah, OldGuy03 and TaquitoBandito like this.
  27. Nov 20, 2024 at 9:42 AM
    TaquitoBandito
    Joel (AKA Bif)
    I want to say we had a similar color in her room at our old house but it was a different brand and when I took a sample to Lowe’s, that was the color name that popped up.
    j-utah and OldGuy03 like this.
  28. Nov 20, 2024 at 10:00 AM
    Kung
    KG, VA
    Legitimately LOL'd at this. Our bathroom has 3 switches in it - one for the fan, one for the light, and one for a ceiling-mounted heat lamp (to keep it warm in the dead of winter).
    My son *consistently* accidentally turns on the *heat lamp* instead of the fan when he takes a giant shit...who the hell wants to hotbox the bathroom after a giant shit? He does, evidently. :rolleyes:
    AZBaldy, RainMan_PNW, j-utah and 3 others like this.
  29. Nov 20, 2024 at 10:06 AM
    Kung
    KG, VA
    Just saw this, @IMXPLRN - my condolences (as someone who had this in 2014). Myself and some others have had that surgery done; if you need or want any recovery tips/tricks, let me know via PM.
  30. Nov 20, 2024 at 10:07 AM
    TaquitoBandito
    Joel (AKA Bif)
    That's pretty hardcore. Maybe he's training himself to become a Navy Seal or a Green Beret.
