Intermittent start problem
Discussion in 'General Tundra Discussion' started by Randy taylor, Nov 18, 2024.
  1. Nov 18, 2024 at 7:07 PM
    Randy taylor
    Randy taylor [OP] New Member
    Randy
    09 5.7 4x4 180,0 miles
    2” leveling kit
    Intermittent problem when starting in morning starts up immediately dies have to wait 5 min then starts right up and runs perfect for a few more weeks. Replaced fuel pump thought that might be it but did it again also replaced battery in key fob dealer won’t say anything till it’s dead I’m at a loss
  2. Nov 18, 2024 at 7:28 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    If it immediately dies right after you turn it on. It's more than likely the battery. When I went through all my batteries, this was a common occurance. If it's something additional than just this. You may have to go down the path of testing the starter, via the relay. At 180k it may be more of a battery / starter issue.
