Auto stop (slam on the brakes)
Discussion in '3rd Gen Tundras (2022+)' started by tstex, Oct 17, 2024.
  1. Oct 17, 2024 at 1:51 PM
    tstex
    tstex [OP] New Member
    Houston & Colorado County TX
    2024 Silver Tundra TRD
    Hello to all,
    I was slowly coasting up to a traffic light and the cars already stopped at light. I certainly was not on too of the car in front of me, but all of a sudden the brakes slammed on and it's a real jolt.
    Question:
    is there either a way to turn off this "safety" feature or tone done the abruptness of the brakes slam?
    Also, I know when backing up, it will do the same thing. Just the other day, it slammed on the brakes while backing up out of my driveway, while nothing was near the back of the car. I believe what happened is after i went down my driveway into the street, there's a very sm dip. If the truck bounces down slightly, assuming the rear cameras caught glimpse of the ground and it slammed on the brakes Has anyone experienced this? If so, is there a way to adjust this?
    Thank you,
    tstex
    Taikowaza likes this.
  2. Oct 17, 2024 at 1:54 PM
    Breathing Borla
    Northern Illinois
    yes, you can do all of that in the menu on the dash, you can adjust the sensitivity , etc.
    PCS is what you're looking for, I suggest you read the manual as well. I have mine still on but a notch or two lower
  3. Oct 17, 2024 at 2:00 PM
    tstex
    Thank you very much Breathing! I've only had the truck for a couple of weeks & have traveled 80% of that time.
    I'm going back to dealership for new car orientation w a list of 20-30 questions. This will be one of them.
    thanks again
    Breathing Borla likes this.
  4. Oct 17, 2024 at 2:08 PM
    kamaaina1
    kamaaina1 New Member
    2024 Tundra TRD PRO
    Camburg 4-Link, Bed Molle panels, Pelican cargo bin, TRD drop-in Filters
    Most dealers will have no clue....
  5. Oct 17, 2024 at 3:01 PM
    tstex
    this dealership has a person (and it's all he does) that gives each car buyer a 30 min review on the cars operating system. I had to stop mine in first 5 mins bc of an emergency wk call, but have an invitation to return. I'll post back next week after I go thru my review.
    thanks
    CringyDad likes this.
  6. Oct 26, 2024 at 1:04 PM
    sbrews
    sbrews New Member
    2024 Tundra
    None... yet.
    PCS is extremely annoying. It has slammed on the brakes for me several times now. Each time I was nowhere near enough to the car in front of me for it to have done that/be justified. While it can be "turned off" via the dash menu, it resets right back to default once you turn the tundra off/on - very annoying. I will have to read thru the manual to see if it can be permanently turned off... if not, then I will have to look at how to "tone" it down... before the safety feature actually causes an accident. This is a good example of too much tech NOT helping.
    Tundra family and Raven67 like this.
  7. Oct 26, 2024 at 1:16 PM
    Breathing Borla
    Northern Illinois
    just turn it to the lowest setting but still on, I find this acceptable for 99% of the time , not perfect but fine. It did help me one time in a little bit of a o shit moment
    TexasCabledawg, CringyDad and Raven67 like this.
  8. Oct 26, 2024 at 4:19 PM
    Alex261
    Alex261 New Member
    Alex
    Boston, Ma
    2024 Tundra Platinum LR
    On the bottom panel of buttons (left of steering wheel) there is a button with a cone thing and that disables the automatic brake when reversing to close to something. Also you can navigate in the settings menu on your steering wheel and you can change the sensitivity of the PCS (pre collision safety)
  9. Oct 26, 2024 at 10:15 PM
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    Please read your entire Owners Manual
    Raven67 likes this.
  10. Oct 27, 2024 at 7:35 AM
    tstex
    Thank you for everyone's feedback and information on this matter. Greatly appreciated.
  11. Nov 18, 2024 at 8:56 AM
    tstex
    Well, went back to dealer and the car orientation guy knew everything, including where to go immediately in PCS to turn down the abruptness of the auto stop for forward. For backing up, there's a button to the lower left thst completely turns off the "back up auto-stop". That wks for me.
    as an FYI, my last truck had 125K and all of the program changes wee via hard buttons. It did not have a display screen for almost everything. I have to really focus & concentrate when driving to change the radio. I have found i better be real careful bc even going slow, other cars pop up fast.
  12. Nov 18, 2024 at 9:24 AM
    DRP
    DRP Old Member
    Dave
    I hear you on needing concentrate in order to change the radio. I learned you can use the speaking dude button on lowered left of the steering wheel to tell it what you want to do. Just push it and say "tune to 92.5 FM" and it will do it. No need to say "hey Toyota".
  13. Nov 18, 2024 at 9:30 AM
    tstex
    "....'hey Toyota, can you permenantly turnoff the engine stop at a stop, feature...?" Thsts what i would say.
    Thanks for the lead on the "call out mode".
    DRP[QUOTED] likes this.
  14. Nov 18, 2024 at 10:43 AM
    TexasCabledawg
    TexasCabledawg New Member
    2024 Land Cruiser (had a ‘22 Tundra)
    Same here. Bailed me out in a moment of lapsed spatial awareness once.
