Need for alignment
Discussion in 'Suspension' started by RickPlatinum2020, Nov 15, 2024.
  1. Nov 15, 2024 at 9:04 AM
    RickPlatinum2020
    RickPlatinum2020 [OP] New Member
    Rick
    Eastern PA
    2020 Barcelona Red Platinum 4x4
    Front and rear TRD sway bars, 18" TRD OR wheels. ESP underseat storage
    Looking to install Bilstein 4600’s on my 2020 Platinum which would provide no lift. Do I need to get an alignment?
    Thanks in advance.
  2. Nov 15, 2024 at 9:06 AM
    crikeymike
    crikeymike ExitOffroad.com
    Jacksonville Beach, FL
    If you do it without touching the alignment cams, then the alignment shouldn't change at all.
  3. Nov 15, 2024 at 9:09 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    No.
  4. Nov 15, 2024 at 9:18 AM
    RickPlatinum2020
    Rick
    Eastern PA
    Excellent! Thought so, just wanted to make sure. Thanks guys!
    crikeymike likes this.
  5. Nov 15, 2024 at 10:55 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Good choice, btw. I liked stock 4600 on my TRD Offroad. 5100 - not so much.
  6. Nov 18, 2024 at 4:57 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Are you changing out all 4 corners?
    If you’re going to be popping out the uppers to get the 4600s in, then I would recommend it.
  7. Nov 18, 2024 at 5:26 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    No change in ride height = no alignment required. It does not hurt to check it from time to time, depending on where you live. Where I live they take $200 and make your non-perfect alignment only worse.
