  1. Nov 14, 2024 at 3:46 PM
    #7711
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I am hoping to reuse my DB cover, racks and tent. I have the other stuff and wheels in the local Craigslist so I will end up giving it away in the end!
    maldo012[QUOTED] likes this.
  2. Nov 14, 2024 at 4:10 PM
    #7712
    machd08
    machd08 New Member
    CLARENCE
    Sumter, South Carolina
    2025 Land Cruiser/Land Cruiser
    Might want to get this before the CP3/CP4 pump goes. https://ssdiesel.com/product/duramax-high-pressure-pumps/
    Raven67 likes this.
  3. Nov 14, 2024 at 4:11 PM
    #7713
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
  4. Nov 14, 2024 at 4:27 PM
    #7714
    vichmr
    vichmr New Member
    Scott
    Suwanee, GA & Highlands, NC
    '25 MGM Platinum TRD OR 6.5 w/ factory lift
    Go Rhino Dominator D6, Diamondback HD
    Glad to hear your experience and appreciate the warning about installation. I watched a video from TRD Jon on how to install and looks very doable though I will go slow to avoid a screw up!
  5. Nov 14, 2024 at 4:44 PM
    #7715
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Thanks, I will check out the pump situation! It sounds like something the extended warranty would cover.
    It also appears that the truck will have a Denso HP4 pump as the CP4 was replaced due to failures.
    Injection System Direct injection
    • High pressure common rail system
    • Denso GS4 Gen-III solenoid fuel injectors (up to 7 injection events per combustion sequence)
    • Denso HP4 injection pump
    • 29,000 psi max injection pressure
  6. Nov 14, 2024 at 5:18 PM
    #7716
    Duckinatruck
    Duckinatruck New Member
    Looking good. I want to buy tires in this size, but I can’t get a clear answer on if they will fit without rubbing. I have a 1 inch level and +18 offset wheels. Does your truck have any kind of lift/level?
  7. Nov 14, 2024 at 5:47 PM
    #7717
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    @Duckinatruck where abouts are you located. If you were close by, you could try mine to see if they rub on your setup. They did rub a bit on mine at +15 but my Toyos are pretty wide. The rubbing occurred on the mudflaps so I trimmed and pushed them back. Still a bit of touching on the steel stub.
    Some tire shops will bring in some tires for a test fit as well. Try reaching out to one you like and give that a try. It really seems that everyone has a different result with rubbing.
  8. Nov 14, 2024 at 6:55 PM
    #7718
    Duckinatruck
    In western Oregon, but I appreciate the offer and info. What kind of mileage hit did you take? I do a lot of short trips in a pretty hilly area, so I’m generally around 14 MPG. I have my eye on some Falken Wildpeak AT4Ws in 285/70/18 C load, but they are 68 pounds. Looks like yours are about 60. Being that you live in Vancouver, B.C., I’m thinking we drive in pretty similar terrain.
  9. Nov 14, 2024 at 7:09 PM
    #7719
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    1.75” RC level and TRD OR suspension.
  10. Nov 15, 2024 at 1:20 PM
    #7720
    Poolguy89
    Poolguy89 New Member
    2024 Black Limited iForce Max
    Any chance of sharing your installation steps and experience?
  11. Nov 15, 2024 at 7:05 PM
    #7721
    4x Taco Owner
    4x Taco Owner New Member
    North Idaho
    2025 limited offroad
    First mod. Added Rough Country running boards and ordered new tires and rims. And no its not some kind of twp tone. Just shitty lighting in my garage and some dirt from the north idaho rain 20241115_171636.jpg20241115_170916.jpg
    Miker24, BlackNBlu, vichmr and 3 others like this.
  12. Nov 15, 2024 at 10:49 PM
    #7722
    MAC25Tundra
    MAC25Tundra New Member
    2025 Limited Crew Max 4x4
    How was the install and what are your initial impressions? I’m very deep down the running board rabbit hole. Primary need is the ability to get the misses into the truck after installing 285/60r20 KO3 tires.
  13. Nov 16, 2024 at 5:57 AM
    #7723
    4x Taco Owner
    North Idaho
    Install was super easy and straight forward. I love the way they look and would highly recommend. i have the 3 inch factory lift so i was running into the same problem as you with the wife trying to get in. I wanted something that didnt hang too low like a predator step. I had predators on my tacoma and ended up smacking them on a rock. I dont plan to do any aggressive offroading so i didnt need to pay the premium for sliders. I think i paid $402 out the door. Good luck in your search and post pics when you get em on.
    vichmr likes this.
  14. Nov 16, 2024 at 6:28 AM
    #7724
    Hammertimerrrr
    Hammertimerrrr New Member
    2024 MGM Limited OR
    I have the same running boards. Love them, and the wide design really keeps rocks and mud off the truck plus, I hope, will save me from becoming a member of the cracked seat panel club.
  15. Nov 16, 2024 at 9:33 AM
    #7725
    vichmr
    vichmr New Member
    Scott
    So grateful for your post! I have a Platinum TRD OR w/ factory lift coming next month and have been scouring the forums looking for the info you provided. Was trying to find out if the automatic steps from Toyota would work since they aren’t an option with the TRD package (the configurator tool won’t allow both.)
    So, you don’t find the step to the RC boards to be too high? My wife is 5’6” and don’t want to hear the complaints - “you paid this much for a truck and I can’t get into it without a running start?!” :rofl:
    4x Taco Owner[QUOTED] and thomez like this.
  16. Nov 16, 2024 at 1:12 PM
    #7726
    freaksavior
    freaksavior New Member
    Richmond, Tx
    '22 AG 1794
    Dechromed
  17. Nov 16, 2024 at 2:18 PM
    #7727
    Hye_Tundra
    Hye_Tundra Fortune Favors The Bold
    LEV
    Los Angeles, CA
    25’ CSM Limited TRD OR
    Hey bud,
    To be honest I didn’t document anything from the install, one of my flaws haha after dozens of car/truck builds. What I can say is all the wires were routed next to the factory harnesses to the engine bay under the step plates on the side. As far as the hose, I routed it through the exit from the cab hole that was connected to the JBL subwoofer. I trimmed the housing to pass the hose through. I routed the hose to bed above the rear bed liner, lots of spots to zip tie it to make it secure. I do recommend buying the clips that hold the fender liner in place as you break them all during removal, super cheap on Amazon. Cutting the bed to make the bracket hole is super easy too, when you buy the bracket it comes with a stencil. It was a very easy but extremely time consuming install. I know this may not be much help, but if you go this route feel free to message me during the process and I will provide all the help I can. Cheers
    Poolguy89[QUOTED] and thomez like this.
  18. Nov 16, 2024 at 2:37 PM
    #7728
    jaxadam
    jaxadam New Member
    Operation Dechrome Mustache complete.
    RadixRyder, Miker24, _yabai_ and 9 others like this.
  19. Nov 16, 2024 at 5:58 PM
    #7729
    MtTundra24
    MtTundra24 New Member
    Nathan
    2024 black tundra trd
    Got the new wheels and tires mounted and on the truck.
  20. Nov 16, 2024 at 7:18 PM
    #7730
    S2Ace
    S2Ace New Member
    Mounted new tires and Tacoma TRD wheels!
  21. Nov 17, 2024 at 7:14 AM
    #7731
    vichmr
    vichmr New Member
    Scott
    Looks really good. What engine cleaner did you use?
  22. Nov 17, 2024 at 7:18 AM
    #7732
    freaksavior
    Richmond, Tx
    '22 AG 1794
    Dechromed
  23. Nov 17, 2024 at 9:04 AM
    #7733
    lapoolboy
    lapoolboy New Member
    SoCal_Erik, dadrocz, thomez and 2 others like this.
  24. Nov 17, 2024 at 10:30 AM
    #7734
    4x Taco Owner
    North Idaho
    My wife is 5"3 and my daughter is 5' and they have no problem getting in. They dont drop down much which is what i wanted but they are down enough where they dont complain lol.
    vichmr[QUOTED] likes this.
  25. Nov 17, 2024 at 10:31 AM
    #7735
    vichmr
    vichmr New Member
    Scott
  26. Nov 17, 2024 at 10:32 AM
    #7736
    vichmr
    vichmr New Member
    Scott
    Thank you!
    4x Taco Owner[QUOTED] likes this.
  27. Nov 17, 2024 at 1:40 PM
    #7737
    dryhop
    dryhop New Member
    Pacific Northwest
    2024 Platinum 4x4 Crewmax
    Added second wireless phone charger for my '24 Platinum. 3D printed iPhone Magsafe charger "carrier". Quick and Dirty solution to charge my wife's phone on a roadtrip.
    Fits iphone 13 in a tech21 case. Inspired by Raylo's, Chavey2's and Goobox's (among others) efforts on this forum.
    Mr Rick and thomez like this.
  28. Nov 17, 2024 at 3:39 PM
    #7738
    Jeff_M
    Jeff_M New Member
    I cut a 61" long piece of 2x8 to fit in the slots of my pickup bed so I can put the groceries in the back without having them slide to the front. Took me ten minutes. This was after searching the net high and low for some sort of restraint system--I finally looked and saw the slots. Pretty exciting, eh? :)
  29. Nov 17, 2024 at 5:43 PM
    #7739
    Xfun
    Xfun New Member
    Martin
    TUNDRA DOUBLE CAB SR5 TRD OFF ROAD
    Stock
    Do you have the link of you compressor? is it for rear suspension ?
  30. Nov 17, 2024 at 5:51 PM
    #7740
    Raven67
    Kentucky
    I've got a couple of these that work well too.
