  1. Nov 17, 2024 at 9:26 AM
    RobertD
    Robert
    DFW, Texas
    Yeah, I couldn't believe it.... especially since i was going to have it done while they were already working on my vehicle and doing a tire rotation.
    But whatever, I enjoyed learning and have now done it again since then :rofl: Haven't done UCA's but I can't imagine that is worth another 600 in labor since they would have already removed the shocks anyways....
    I wish you luck!
  2. Nov 17, 2024 at 10:16 AM
    FireFinder44
    FireFinder44 New Member
    Albany, OR
    2019 Super White Tundra TRD Pro
    Mostly stock TRD Pro
    Is that from Revesol-USA or someplace else? Does it just get power from the clock spring, or something different? I have the Revesol-USA Carbon Fiber/black leather and would vastly prefer a heated wheel with full leather.
  3. Nov 17, 2024 at 10:19 AM
    Dave8699
    Dave8699 Trackrat
    NJ
    04 Tundra AC, 2014 Tundra 1794 Crew Max
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    If you decide to sell your carbon fiber let me know.
    FireFinder44[QUOTED] likes this.
  4. Nov 17, 2024 at 11:01 AM
    Wallygator
    No way UCA's are worth that. I did them once and they are not bad. I think the hardest thing was clearing stuff out of the way to get the bolt in and out. Thanks!
  5. Nov 17, 2024 at 1:14 PM
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    IMG_7044.jpg IMG_7042.jpg Installed my air spring cradles today. Pics of normal sit and lifted to the point the back tires are off the ground. As I was looking at the pictures , I noticed the driver side bag slide down a little. I never noticed that before. I’ll have to check the passenger side tomorrow to see if it does the same thing. They still hold air.
  6. Nov 17, 2024 at 1:35 PM
    2014 Black tundra
    2014 tundra sr5
    I couldn’t wait till tomorrow. I had to check it. It’s the same on the passenger side. I’m thinking it’s designed that way so it doesn’t rip the airbag as easy.
    woods and HulkSmurf14 like this.
  7. Nov 17, 2024 at 5:59 PM
    250000yota
    250000yota New Member
    Russ
    Berthoud, CO
    White 2015 SR5 Crewmax
    S&B intake, Dirty Deeds 8", Airlift airbags with Daystar contact cups, LED's everywhere including Diode Dynamics stealth front LED bar, Baja Design Squadron II's on CBI ditch light brackets, completed Diode Dynamics interior LED's. Full RCI skids with cat guards and sliders, Transfer flow 46 gallon tank. Radflo 2.5 IFP coilovers, Coachbuilder shackles, TRD rear sway bar. 295/70R18 Nitto RG's. Dobinson snorkel, softopper.
    Another slow day at work meant another little project on the truck. I’ve had a Overland Equipped fuse block and mount that I’ve been sitting on for about a month, and I want to try and install my bed lighting here in the next few weeks so I had to get it in. Install was 15 minutes tops, but I need to do some reworking of the wiring to eliminate one of the fuse holders for the wiring I’ve already routed to it. I also need to secure the power cables a little better as well but so far I’m pretty happy with it.
  8. Nov 17, 2024 at 6:25 PM
    JC21Tundra
    JC21Tundra If I'm not here, I'm somewhere else...
    Jeff
    St L Missouri
    2021 MGM Tundra Crew Cab TRD Sport 4x4
    Cartrimhome The steering wheel came with new clock spring, if you follow the link in the original post you can see the kit I purchased from Amazon, but they also sell on eBay.
  9. Nov 17, 2024 at 6:59 PM
    Explorer
    Explorer New Member
    Battle Ground WA
    2019 Silver Tundra SR5 TRD Offroad
    Looks clean
  10. Nov 17, 2024 at 7:57 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Did you get the heated wheel?
  11. Nov 17, 2024 at 11:02 PM
    Leedaar
    Leedaar New Member
    2016 Tundra CM
    Remove the recovery hooks (use an impact gun). There are 4x nuts on each side. All are 14mm. You definitely need a set of flex-head combination wrench. I used a cheap workpro set from Amazon. Loosen up 4 bolts on each side… then remove 3 on each side and leave 1 nut a few threads in. When you’re ready with your mod, take the last nut off the driver side, wedge the bumper off that side and place your bumper extension in. I was able to wedge my bumper about half an inch from the bolts. Loosely reattach the nuts on the driver side. Now do the same to the passanger side. Tighten everything up and you’re set.
    Space is limited, wear gloves and a long sleeve to prevent scratches. You’ll know what i mean when you’re fighting off the nuts holding onto the bumper.
    I lubed the threads about 30 mins before starting.. would have been easier if I let it sit for a while.
    Good luck. I found the instructions on this forum.
    bulldog93 and woods like this.
  12. Nov 18, 2024 at 2:32 AM
    ThatGuyTheCooler
    ThatGuyTheCooler New Member
    I could not sell the Tundra privately, so had to trade it in. We had been waiting on the GHH since it arrived in port back in June. I was finally fixed from the recall and sent to the dealer this past weekend. I am now driving the wife's '23 4runner, she has a long commute so she is in the GHH.
  13. Nov 18, 2024 at 3:22 AM
    Bergy24
    Bergy24 New Member
    You must trust her a lot!
    Voda48[QUOTED] likes this.
  14. Nov 18, 2024 at 3:29 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    how did the trade work. Nice color on the new DD
    Tundrastruck91 likes this.
  15. Nov 18, 2024 at 6:28 AM
    ThatGuyTheCooler
    2020 SR5 DC, some mods, 34k miles, CarShop(carsense) offered 36k, dealer matched at 34200 (plus factor in the $2k tax savings). I was at 37k via private sale, no one came through
    Tundrastruck91 and HulkSmurf14 like this.
  16. Nov 18, 2024 at 7:25 AM
    Tundra family
    Tundra family New Member
    Welded the tabs onto the frame, and got handy with some angle iron. Now I can get in and out without busting my stuff.
    Don't make fun of the stupid boot :(
  17. Nov 18, 2024 at 7:35 AM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Not the Tundra, but I did have time to do my wife’s ROF tire carrier yesterday.
    Tundra-XP, Ted4311, FISHN43 and 24 others like this.
  18. Nov 18, 2024 at 7:52 AM
    JrJrOffroad
    JrJrOffroad Somewhere in the west
    Anthony
    Monument, CO // Cave Creek, AZ
    Oh lordy thats nice
  19. Nov 18, 2024 at 8:01 AM
    Tundra family
    That looks strong. Hopefully it's real good.
    Reminds me of a "just rolled in" I saw. "Customer states spare tire is missing" as he's looking under the carpet in the cargo hold on a jeep. :rofl:
  20. Nov 18, 2024 at 8:11 AM
    reneaux
    reneaux I've been around
    2017 SR5 CM 4x4
    Friday AM - quail, pheasant, chukar hunt in Navasota, TX area. Drove home around noon, scooped the 4 yr old and headed south to Surfside Beach to take him camping. Weather was perfect. Great weekend.
    20241115_095748.jpg 20241115_190127.jpg 20241116_070938.jpg 20241116_063414.jpg
  21. Nov 18, 2024 at 8:27 AM
    CaptRussia253
    Ruslan
    Thanks! Install was easy, other than the seal. Definitely clean and not too bulky like the rest on the market.
    HulkSmurf14 and bulldog93 like this.
  22. Nov 18, 2024 at 8:45 AM
    Tundra family
    The birds, the grill, the beach and the family. Living the dream!! I'm only mildly jealous.
    BR73, rdiddy5, Florida AF and 2 others like this.
  23. Nov 18, 2024 at 11:46 AM
    AthenaOffroad
    AthenaOffroad YouTube wannabe
    Niko
    2014 Blue Ribbon Metallic Tundra DC SR5
    Added some of the older TRD pro headlights over the weekend. They are the halogen ones with the older amber drl which is what i wanted. Lasfit sent me some of there Led bulbs to try out and damn are they so much brighter but I probably wouldn't have upgraded to leds had they not sent me them as I hardly ever drive at night and never had a problem with the original halogens that came with it. Absolutely love the way it looks now with the darker blacked out housing
  24. Nov 18, 2024 at 2:37 PM
    ewxlt66
    ewxlt66 New Member
    Erik
    Southern California
    I leveled it, did cab mount chop, ripped off the stock 20"s, and put on some Marketplace wheels/tires, 315/70/17" on Method 314s. IMG_0736.jpg
  25. Nov 18, 2024 at 3:54 PM
    seydou
    seydou Distinguished Member
    Please do your fellow motorists a favor and make sure they are focused properly. Many times installing LED bulbs in a housing designed for halogens, instead of changing housings, doesn't work well and results in light that is blinding to other drivers.
  26. Nov 18, 2024 at 5:00 PM
    AthenaOffroad
    Niko
    Thankfully these that they sent me are super nice they have a pretty defined cut off line and i spent about an hour last night driving testing them and adjusting them. no one flashed me so i think im good. i also have the leveling motors and i have it set so i can lower them down to about 15ft in font of my truck if the need arises.
  27. Nov 18, 2024 at 5:13 PM
    Tundra family
    It's like Genesis over here y'all. I can see, that the light is good.
    mgm16trdpro, ATV25 and AthenaOffroad like this.
  28. Nov 18, 2024 at 5:55 PM
    Any update on your CEL?
  29. Nov 18, 2024 at 6:06 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Oh yeah, took it to my mechanic buddy who's got a real high end scan tool and codes came back that had something to do with the MAF sensor. Don't really know what could have caused it but he reset it for me and CEL never came back. That same day was when I decided to pull the trigger on the SGIII and so now i'm keepin a close eye on things.
    Been meaning to ask you(or anyone with the SGIII)...What are you monitoring? Can you send picture of your 3 screens? I've been trying to learn about all the different options for gauges and differences like Ambient vs. Intake temps which I'm pretty sure I found out, then AT Oil1 vs. AT Oil2 which I found out 1 is pan and 2 is TC but which is best to keep on screen? I'd assume 2, right? Just things like that is what i'm trying to figure out.
    bulldog93 likes this.
  30. Nov 18, 2024 at 7:42 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Not too much happening here. Just a little vinyl here and there.
