Rebuilt 2005 GX470 Project - From CO to TX and Back (soon)
Discussion in 'Lexus GX Builds' started by M3Tundra-JK, Oct 23, 2023.
  1. Nov 7, 2024 at 1:16 PM
    #631
    M3Tundra-JK
    M3Tundra-JK [OP] New Member
    Scott
    2005 GX470
    All but 6 spot weld holes punched. There's a section I'll have to drill out because the metal bends and I can get the punch around the lip, bottom left section of QP
    e30cabrio, Busa, Black@Blue19 and 2 others like this.
  2. Nov 8, 2024 at 11:34 AM
    #632
    M3Tundra-JK
    Scott
    2005 GX470
    Welding has begun! Cut out a part of the old QP as a gap filler up top. Then got about 1/3 of the spot welds done. Break and then back to finish
  3. Nov 8, 2024 at 2:34 PM
    #633
    M3Tundra-JK
    Scott
    2005 GX470
    Mostly welded in, and ground down. Not perfect but will do the job. Need to do the seams and roof next.
  4. Nov 8, 2024 at 4:25 PM
    #634
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Verry cool!!
    Black@Blue19 and M3Tundra-JK[OP] like this.
  5. Nov 8, 2024 at 7:32 PM
    #635
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    ^^^^ Holy Moly! I second that. Very cool indeed!
    It Has Begun! :)
  6. Nov 9, 2024 at 1:23 PM
    #636
    M3Tundra-JK
    Scott
    2005 GX470
    It's not body shop good, but I'll take it. Drove it around the area for a bit and it's all solid. Have to find the taillight wiring, lost somewhere.
    Will be researching bondo and body filler or whatever to buy next paycheck and start getting the whole thing ready to paint. Also need to get it registered so it's legal. That's a whole other thing I need to figure out for TX.
    All in all, I definitely could have spent the money more wisely and gotten a good deal on a GX470 in much better condition. And a normal person should do that! I'm far from normal though lol. I've learned a lot about body work in this process. Things I know to do differently in the future.
    Long term plans for the GX is to be a supercharged street focused weekend overlander. The Jeep is the streetable rock crawler. And the M3 is the car meet cruiser. Probably that's is until I buy a house in a few years.
  7. Nov 9, 2024 at 1:28 PM
    #637
    e30cabrio
    Awesome!
    M3Tundra-JK[OP] likes this.
  8. Nov 9, 2024 at 1:36 PM
    #638
    M3Tundra-JK
    Scott
    2005 GX470
    Things it needs next besides paint:
    Either learn PDR or body filler on various hail dings.
    265/70/17 Tires to mount on thr TRD 4RUNNER wheels sitting in storage. Currently on stock rims and 265/65/17 tires.
    Alignment
    Replace the cracked windshield
    Replace old and yellowed headlight housings, passenger side headlight is out.
    Finish removing rust i didn't get to early on in the build
    Drive it enough to let the suspension break in. Then adjust the stance. It's currently a little squatted in the rear. The front coilovers and the rear springs are height adjustable
    Black@Blue19, e30cabrio and KNABORES like this.
  9. Nov 16, 2024 at 11:12 AM
    #639
    M3Tundra-JK
    Scott
    2005 GX470
    Grrrr. Went to replace the headlight turn signal bulb and the glass part of the bulb came out without the metal base. Was stuck in pretty good. Grabbed the needle nose pliers to remove the rest and a bunch of plastic inside the housing crumbled getting it out. New bulb won't stay in now. Ordered a headlight wiring harness from the local Lexus dealership.
    I called to check availability. They have it in stock. $78 over the phone...I was like, it says $44 online. "That's the online only price" wtf?! Said I can place it online and still pick it up today. That's some price gouging right there!
    + $48
    Busa and Black@Blue19 like this.
  10. Nov 16, 2024 at 12:35 PM
    #640
    M3Tundra-JK
    Scott
    2005 GX470
  11. Nov 16, 2024 at 12:38 PM
    #641
    M3Tundra-JK
    Scott
    2005 GX470
    Also saw this while at the dealership. I'm gonna see if I can find it in black. I've got a 35lbs mini lab mix that would fit in it
    e30cabrio and RobertD like this.
  12. Nov 16, 2024 at 2:11 PM
    #642
    Black@Blue19
    Ken
    SE Texas
    Lookin good!:)
  13. Nov 16, 2024 at 2:44 PM
    #643
    bfunke
    bfunke Tundra Curmudgeon
    My local dealer doesn’t participate in online parts ordering so I have to either pay shipping or drive an hour.
  14. Nov 17, 2024 at 9:20 AM
    #644
    M3Tundra-JK
    Scott
    2005 GX470
    Did a parts swap with @nags. My extra rear hd sway bar for his old tesla style head unit, and a couple of 3d printed trim caps (for when you remove the side steps).
  15. Nov 17, 2024 at 9:28 AM
    #645
    Black@Blue19
    Ken
    SE Texas
    That'll do. Both look good. :thumbsup:
    e30cabrio and M3Tundra-JK[OP] like this.
  16. Nov 17, 2024 at 9:45 AM
    #646
    Slag_Dynamics
    Slag_Dynamics Cut. Weld. Repeat.
    Arizona
    Gone
    Good job man!
    Whats awesome about projects like this, is it helps you realize how capable you really are. The tools are an investment and the experience is invaluable!
  17. Nov 17, 2024 at 9:59 AM
    #647
    M3Tundra-JK
    Scott
    2005 GX470
    I'd change careers if I were able to make 6 figures doing things like this instead of IT work!
    nags likes this.
  18. Nov 17, 2024 at 10:53 AM
    #648
    nags
    nags New Member
    Damn.. I do IT and don't make 6 figures. I'm doing something wrong lol
  19. Nov 17, 2024 at 10:58 AM
    #649
    M3Tundra-JK
    Scott
    2005 GX470
    I only just got there after almost 20 years in "IT". 6 years doing desktop support, 6 years of data center tech (almost 3 years of that was overnights), then 7 more years of data center engineering. And now moving into Project management side of things nowadays. Less hands on, more meetings and headaches
    Black@Blue19 and e30cabrio like this.
  20. Nov 17, 2024 at 11:01 AM
    #650
    nags
    nags New Member
    I'm at about 20 years myself as a Network Engineer but I'm comfortable where I am and it would take a LOT of money for me to even consider a change. I'm full time remote and can go days without even talking to anyone else on Teams let alone a phone call.
  21. Nov 17, 2024 at 11:06 AM
    #651
    M3Tundra-JK
    Scott
    2005 GX470
    I used to have that and would love to go back to it! That was my day to day in CO, but then they closed down all the North American data centers and I had to find something else. My new job here in TX was like that to start, but they just closed down this dc also...but moving into Project mgmt will allowing me to go back to 100% remote, and back to CO
  22. Nov 17, 2024 at 11:07 AM
    #652
    nags
    nags New Member
    I work for a very small company so don't have to worry too much about stuff like that. And being a wannabe bodybuilder, working fully remote is just too good to ever give up.
  23. Nov 18, 2024 at 6:22 AM
    #653
    e30cabrio
    I'm IT too, coming up on 40 years, yup, I'm so old I went to Wang school in'82. That's 5k quickly in the toilet but got me networked into contacts I still have today. I'm 100% remote, manage a reasonable sized team, lots of meetings and not so much hands on but I pretty much do my job on autopilot. I miss actually figuring out odd issues and fixing things but hopefully will retire soon so it's OK.
    Also, great work! ;)
  24. Nov 18, 2024 at 7:26 AM
    #654
    Ghost Rider
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    All of a sudden @M3Tundra-JK got a bunch of IT showing up at his door....haha
    nags and e30cabrio like this.
  25. Nov 23, 2024 at 9:32 AM
    #655
    e30cabrio
    And he disappears, coincidence??????
    :p
  26. Nov 23, 2024 at 9:45 AM
    #656
    Slag_Dynamics
    Arizona
    Gone
    This is how this thread tends to go. I get my fix and then jones for an update. Lol
    Then I don’t get updated for some reason and binge a few pages. lol
  27. Nov 23, 2024 at 9:59 AM
    #657
    M3Tundra-JK
    Scott
    2005 GX470
    Lol ok ok here's some updates
    I was holding off on putting the taillight back in because i thought I was missing part of the wire harness. But not the case, it only uses one of the sockets and the other two are hard wired. So put it back in, but can't find the screws just yet. Used a random spare instead.
    Was putting the interior back together and it seems the rear third row seat belts were seized so I just removed them. Tbh all of the seat belts should be replaced. They're kinda slow, gummy feeling.
    The rear carpet was barely able to go back in all the way due to the thick layer of dynmat liner I used. It's pretty plush now..
    Will figure out what type of body filler I need next, and get a cheap sander to prep for paint.
    Also need to figure out how to swap the title to rebuilt and get it registered now that it's back together.
    Also the interior needs a good cleaning again. Hasn't been detailed since moving it down to TX.
  28. Nov 23, 2024 at 10:40 AM
    #658
    Slag_Dynamics
    Arizona
    Gone
  29. Nov 23, 2024 at 10:44 AM
    #659
    M3Tundra-JK
    Scott
    2005 GX470
    Oh, nice! I was wondering how I'd go about cleaning them! I think there's a trick to getting the seatbelts to unlock also. The middle seatbelt in the rear passenger row was also locked at one point, and then magically unlocked itself after I installed the seats.
  30. Nov 23, 2024 at 10:46 AM
    #660
    Slag_Dynamics
    Arizona
    Gone
    Yeah man it worked great. For the not so bad ones, I just left them attached in the car and pulled them out until they locked.
    Then sprayed the Simple Green directly and scrubbed. Normally there is only like a 2 ft. Section of gross exposed seatbelt, so it’s not too bad!
    My interior is the same color too.
