2007 Tundra 4x2 Crew Max Limited valve spring issues?
Discussion in 'General Tundra Discussion' started by Grayfox7, Oct 13, 2023.
  1. Oct 13, 2023 at 8:13 AM
    Grayfox7
    Grayfox7 [OP] New Member
    Chase
    2007 Tundra Limited CrewMax
    Suddenly coming across a lot of unfortunate stories of valve springs breaking in 07-10 models and completely killing the engine. I cant seem to find much info on this other than the sad stories. Not sure how to know if mine is at risk and should just replace now? I came across one comment that said it was one the machines making the springs in a certain Toyota factory that were defective. Not sure if that is accurate. Any help on this on how much to repair or how to know if it is a concern or not would be greatly appreciated. Thank you!
  2. Oct 13, 2023 at 8:16 AM
    Where did you read all of these stories? Can’t say I’ve seen much about this. Only saw one tear down of a 5.7 on YouTube and it was for a valve spring issue.
    blackdemon_tt likes this.
  3. Oct 13, 2023 at 8:19 AM
    Grayfox7
    Chase
    Just doing some google searches on common issues with the Tundras and came across that same Youtube video I think you are talking about and starting searching more specifically to valve spring issues. It was odd because it was the first I have heard of this issue but once I started digging I found more and more stories.
  4. Oct 13, 2023 at 8:20 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Never heard of that issue, and I would not worry about it. Unless you plan to arbitrarily replace all your valve springs (and no guarantee those replacements are any better) then there's no point in worrying about it.
  5. Oct 13, 2023 at 8:55 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    There is a saying, that if you're seeking for issues, you will find them. Most of those issues are few and far between, odds are a drunk driver will make short work of your parked Tundra before it really encounters an issue. I'm at 280k+ 07 5.7L.. My encounter was with broken snow chains that redesigned my bed sides.
    Larly5000 and KNABORES like this.
  6. Oct 18, 2023 at 2:30 AM
    Larly5000
    Larly5000 Local Scumbag
    NV
    07 Crewmax
    Wouldn’t lose a wink of sleep over it. Leave er alone.
  7. Oct 18, 2023 at 7:14 AM
    G Man
    G Man New Member
    I'm familiar with the issue but from what I understand, it wasn't widespread. Don't know if they ever figured it out, but it would occur early in the life of the engine. If it hasn't happened by now, your probably good to go.
  8. Dec 8, 2023 at 2:07 PM
    wauto
    wauto New Member
    mike
    My 2010 just had a valve spring break. It didn't drop the valve. I caught it because of a misfire followed up by a sad compression test. Pulled the valve cover off and the number 7 intake valve spring is broken. Anybody try to fix this without pulling the head?
  9. Dec 8, 2023 at 2:38 PM
    AZBoatHauler
    So.Arizona
    Sorry for the shit luck but at least you didn’t kill the engine.
    @ViktorG @Ruggybuggy - is this possible?
  10. Dec 8, 2023 at 3:29 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Might be a tough job in the truck since you'll need to remove the camshaft and deal with timing, but I think it can be done. You'll need to find a universal valve spring compressor that can attach to the head. Use a compression test hose with the Schrader valve removed to keep the cylinder pressurized with air and that will keep the valve in place while you reinstall the new spring. Make sure you find all the pieces of the old spring before putting it all back together.
  11. Dec 9, 2023 at 3:02 PM
    wauto
    wauto New Member
    mike
    Ok, I'm going to dive in and give it a try. Wishing it wasn't the very rear spring.
  12. Dec 9, 2023 at 4:02 PM
    Bergmen
    Bergmen New Member
    Ukiah, California
    If you study this situation very carefully, there may be a way to remove the broken spring and replace it with the new spring without having to remove the camshaft. Take a look at this sectional view:
    The roller rocker arm is free to be removed since it simply rides on the hydraulic lash adjuster. Once that is done (camshaft needs to be in position similar as shown with lobe away from the valve). With cylinder at TDC compression, pressurize the combustion chamber to hold valve in place. Slide the new spring in place and use whatever spring compressor that exists for installing retainer and keepers. The valve can be lowered slightly to replace the roller rocker arm.
    This is just an educated guess on my part and there may be interferences that might prevent this but it may be worth a try. If successful, it is a heck of a lot better than removing the camshaft.
    Good luck and keep us posted.
  13. Dec 23, 2023 at 1:33 PM
    wauto
    wauto New Member
    mike
    Update...bought a $7.65 intake valve spring. Took the valve covers and DS timing chains out. Removed cam tower assy. Held valve up with compressed air and removed and replaced valve spring. Had to make my own spring compressor tool. The job isn't for the faint of heart. A spring retainer clip went shooting across the shop at one point. Thankfully Toyota dealer keeps a handful in stock. Buttoned it all up and she runs like a million dollars. Changed the oil and cleaned up the shop.:thumbsup:
    Terndrerrr, Jowett and armyoffoo like this.
  14. Dec 23, 2023 at 1:35 PM
    wauto
    wauto New Member
    mike
    Thank you for you help everybody!!!!!!!
  15. Feb 7, 2024 at 5:11 PM
    14CRWMX
    14CRWMX New Member
    Tampa Bay
    2014 SR5
    Did you have to open front of the engine and remove main timing chains to remove camshaft?
    My cylinder 5 valve spring broke, but looks like it's the only damaged part, so thinking to tackle it myself.
  16. Feb 7, 2024 at 6:11 PM
    wauto
    wauto New Member
    mike
    Yup. Took the front off. Plenty of ytube's and such on this job. Only thing that I recomend, would be to use ziplock bags and a sharpie. Also took a bunch of pictures. Number 5 is pretty easy to access. If you need any pointers feel free to PM me.
  17. Feb 7, 2024 at 6:27 PM
    14CRWMX
    14CRWMX New Member
    Tampa Bay
    2014 SR5
    Appreciate your help sir. Thank you
  18. Nov 11, 2024 at 12:16 PM
    Mkoger7
    Mkoger7 New Member
    2008 Tundra limited
    IMG20241111131116.jpgso i cant find the tool that allows you to compress a spring and put it in without having to remove the cam. Is there something you know of that would go in offset under the cam?
  19. Nov 16, 2024 at 6:56 PM
    14CRWMX
    14CRWMX New Member
    Tampa Bay
    2014 SR5
    You'll have to remove the cam, not enough clearance otherwise. I did all the research :). You will have to open timing cover and remove the chains. If you'll be working on driver side, it will be easier. When you'll get to the the spring compression, put it in vice, get 3 thick zip ties, soak them in 0w-20 oil, compress the spring tighten the zip ties, and you'll have enough room to put valve keepers without any compression tool. Then get needle nose pliers and slowly remove them. Let me know if you'll have more questions. It will be pain in the ass but it's doable. Also get Haynes manual, you'll need it.
