Toyota OEM TRD Front Recovery Hooks
Discussion in '3rd Gen Tundras (2022+)' started by RatPanda, Nov 12, 2024.
  1. Nov 15, 2024 at 12:32 PM
    #61
    LB-1889
    LB-1889 New Member
    should be good, part in hand
  2. Nov 15, 2024 at 12:54 PM
    #62
    LB-1889
    LB-1889 New Member
    Clevises are fairly big when compared to a standard 3/4”’clevis.
    Total weight of the kit is right at 40 lbs.
  3. Nov 15, 2024 at 12:59 PM
    #63
    99ways2die
    99ways2die New Member
    NJ
    2022 Tundra Platinum
    I think I speak for everyone here: can't wait to see pics of your install!
    Dfrink, Yaboy, Ipaddick and 1 other person like this.
  4. Nov 15, 2024 at 1:35 PM
    #64
    Breathing Borla
    Northern Illinois
    again , stout kit
    worth 500 bucks for Toyota quality oem imo
    sudobash and Yaboy like this.
  5. Nov 15, 2024 at 5:51 PM
    #65
    MEGA VOL
    MEGA VOL New Member
    24 1794 limited edition
    I want to see some pictures before I order but I believe this is going to be nice.
    sudobash and Breathing Borla like this.
  6. Nov 16, 2024 at 7:22 AM
    #66
    LB-1889
    LB-1889 New Member
    You have to remove the lower sway bar bracket and replace it with the one shown below. This is the part I struggled with the most. You’re fighting the weight of the sway bar, plus the rubber isolator, and it needs to be pulled towards the front of the vehicle and up. I used a floor jack for help. Once I got the one side done the other side was a piece of cake. I started both bolts by hand and then went back and forth to cinch them up. The bottom purple bolt in the picture should have had a black washer behind it. Then once your ready on both sides you loosen the bolt in the bottom of the pic a half inch and can slide the clevis arm in place.
    Leicafish, KClav, VCheng and 7 others like this.
  7. Nov 16, 2024 at 7:28 AM
    #67
    LB-1889
    LB-1889 New Member
    New parts in yellow.
    Leicafish, KClav, Yaboy and 8 others like this.
  8. Nov 16, 2024 at 7:32 AM
    #68
    LB-1889
    LB-1889 New Member
    Overall pic, more to come when I get the rest put back together. Had to remove the entire front clip to install this.
  9. Nov 16, 2024 at 7:53 AM
    #69
    Breathing Borla
    Northern Illinois
    did you give it the obligatory “ that ain’t going anywhere “ after tightening the last bolt?
    critical last step in any project
    RAL749, astrength22, the4rdan and 6 others like this.
  10. Nov 16, 2024 at 8:01 AM
    #70
    az 3rdGen
    az 3rdGen New Member
    Arizona
    2022 Black Tundra SR5
    awesome man! great info! hows it look from the front??
  11. Nov 16, 2024 at 8:05 AM
    #71
    LB-1889
    LB-1889 New Member
    For sure!
    These are definitely a pull straight on during recovery. The two forward bolts go into a bracket that then gets bolted into the aluminum crash bar.
    Also got this from my local dealer for $530 and took two days from from order placed to parts in hand.
  12. Nov 16, 2024 at 8:12 AM
    #72
    G3ardnut
    G3ardnut Brushed Chrome is COOL
    Joe
    Canada
    2023 Limited TRD Offroad Crewmax Celestial Silver Metallic
    Reubenski, KClav, VCheng and 2 others like this.
  13. Nov 16, 2024 at 8:57 AM
    #73
    LB-1889
    LB-1889 New Member
  14. Nov 16, 2024 at 8:59 AM
    #74
    LB-1889
    LB-1889 New Member
    Supplied TRD Clevises
  15. Nov 16, 2024 at 9:02 AM
    #75
    LB-1889
    LB-1889 New Member
    TRD vs my cheap clevises.
  16. Nov 16, 2024 at 9:02 AM
    #76
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    Looks great man. Thanks for the pictures
  17. Nov 16, 2024 at 9:08 AM
    #77
    LB-1889
    LB-1889 New Member
    Thanks, new trim piece has dimples to put a front license plate on which I still need to do. Think I will go with a black clevis same shape as the silver ones posted. The supplied TRD clevises are just to bulky IMO.
  18. Nov 16, 2024 at 9:14 AM
    #78
    Dabutcher
    Dabutcher New Member
    D
    Twin Cities
    2022 Tundra 1794 Supersonic Red
    Nitto Ridgegrapplers 175/60/20
    I love it. Next 25% off sale I am purchasing. Thanks for sharing. Looks Great! Peace. D
    Siblue likes this.
  19. Nov 16, 2024 at 12:59 PM
    #79
    Siblue
    Siblue Old member
    25 Tundra TRD pro
    Thanks for sharing. Nice to see mods again instead of the internet noise.
    Blufin likes this.
  20. Nov 16, 2024 at 2:04 PM
    #80
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    Looks really good. I think I like the standard, non-Toyota clevises better also. (In black.)
    Dfrink, 4mm and kirkb like this.
  21. Nov 16, 2024 at 2:56 PM
    #81
    kirkb
    kirkb Lurking Member
    DFW
    2024 Tundra Limited 4x4 WCP Nightshade
    @LB-1889 Thanks for the pics. The document says there's cutting involved. How difficult was that part?
  22. Nov 16, 2024 at 6:04 PM
    #82
    LB-1889
    LB-1889 New Member
    One thing I didn’t take a pic of…but basically a 6” x 1” piece of the inner plastic frame needed to be trimmed out where the trim is recessed around the clevises. I used my oscillating tool.
    I test fit the new lower trim piece and you can see on the bottom where it slightly contacts it. I would not recommend cutting the plastic with the new trim piece snapped in place.
    kirkb[QUOTED] likes this.
  23. Nov 16, 2024 at 7:01 PM
    #83
    lapoolboy
    lapoolboy New Member
    Well shit
  24. Nov 16, 2024 at 8:02 PM
    #84
    TundBP
    TundBP New Member
    23 Blueprint Platinum
    looks like i need this
  25. Nov 17, 2024 at 6:30 AM
    #85
    Blufin
    Blufin Seasoned member
    Bob
    Cape Cod,MA.
    23 Capstone
    Have you seen what you've done here!?
    Now I have to get one and have the valance painted....
    Thanks for helping me spend :spending:
    By the way it looks awesome and I'm sure better in person.
  26. Nov 17, 2024 at 7:35 AM
    #86
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    Thanks for jumping on this and getting us all what we needed to make a decision. :thumbsup:
    Assuming it also works for the Pro….I plan on getting this installed asap.
    astrength22 likes this.
  27. Nov 17, 2024 at 8:38 AM
    #87
    Breathing Borla
    Northern Illinois
    Geez Toyota lawyers , should have been that way from the start
    looks great
    22whatwedo likes this.
  28. Nov 17, 2024 at 9:59 AM
    #88
    mfa1981
    mfa1981 New Member
    Marcel
    2024 Nightshade Limited
    Came here to say I found pics on facebook! :) It looks really good, soon it will probably ~$500 upgrade if you don't plan on using a winch it looks really good and does the job better than AFE
    Blufin likes this.
  29. Nov 17, 2024 at 3:32 PM
    #89
    TundraDan723
    TundraDan723 Not as new as I used to be...
    2023 Celestial Silver Tundra 1794 TRD CM
    Thanks for sharing! Good to know.
  30. Nov 17, 2024 at 3:42 PM
    #90
    LB-1889
    LB-1889 New Member
    That would be the time to do it since you have to pull the front clip off.
    When I did it I bought an extra and had it painted rather then pulling the front clip off twice.
