Mechanic Mistake
Discussion in '1st Gen Tundras (2000-2006)' started by Pyreforge, Nov 15, 2024.
  1. Nov 15, 2024 at 7:03 PM
    Pyreforge
    Pyreforge [OP] New Member
    2005 Toyota Tundra
    Hey y'all, I recently had the valve cover gaskets and seals done on my 2005 4.7 and I noticed they accidentally clamped a ground wire into the valve cover. I already spoke to them and am bringing it back. I don't know what their solution is going to be, do you think that gasket should be replaced? I'm worried they are going to want to just loosen the cover and pull it out and tighten the bolts back down and it will eventually end up leaking sooner because the gasket could be damage. It's currently leaking oil, that's how I ended up noticing it. I've never had a shop screw something up, what would y'all do?
    It's hard to get a good photo because there's not much space but here are a couple pics.1-1.jpg 2.jpg
  2. Nov 15, 2024 at 7:22 PM
    Griff04
    Griff04 New Member
    Ralph
    Southwest Georgia
    2006 V6/2WD/AC
    None
    I may get a lot of push back on this but I believe it would be fine just loosening, pulling out the wire, and then retightening and torquing. I would then just keep a close eye on it for any leaks. Don’t forget to look at the ground wire for damage also. The mechanic shop may want to go all the way with the gasket replacement but I doubt it.
  3. Nov 15, 2024 at 7:28 PM
    Inspection of the gasket would be needed. I lean towards replacement without seeing it. Clamping down unevenly may have deformed the gasket in a manor that will cause premature failure. This is speaking for someone who PAID to have it done right and will have to PAY to have it down again when it fails. Me? I might just give it a whirl after removing the ground wire from it. But that’s because I’m the one that’s gonna fix it if it leaks.
  4. Nov 15, 2024 at 8:20 PM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    I did something similar once on a different vehicle except it was a little vacuum line.
    I took it apart, inspected, looked fine and reassembled, no leaks.
    That being said, if I’d paid someone to do it I’d want to see the gasket before reassembly (not just loosen, pull out wire and retighten), and some extended warranty or something on it if it should start to leak.
    Pyreforge[OP] and KNABORES like this.
  5. Nov 16, 2024 at 5:43 AM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    At the very least, don't let the shop simply loosen the area where the wire is clamped and then tighten it back down. There's a specific sequence for tightening the bolts on the valve covers, and it needs to be done in three or four equal steps, so it really needs to be removed completely. Once removed, a thorough inspection of the gasket should be done.
  6. Nov 16, 2024 at 6:31 AM
    If they refuse to replace it, make sure you get a warranty on it from leaks for a sufficient period of time.
    G_unit3000 likes this.
  7. Nov 16, 2024 at 6:33 AM
    Yeah, I would definitely point that out OP in the FSM if they’re not going to pull the whole cover off and retighten with a new gasket.
  8. Nov 16, 2024 at 7:03 AM
    bfunke
    bfunke Tundra Curmudgeon
    Most shops don’t know the nuances of FGTs. I firmly believe owners should learn to do basic maintenance. This is an easy home repair. Next time do it yourself and you’ll know it was done right.
    shifty` and KNABORES like this.
  9. Nov 16, 2024 at 7:04 AM
    My first piece of advice for those considering FGT ownership. Don’t buy one unless you’re loaded, or handy. They will need repairs and maintenance and the cost to pay someone will add up fast
  10. Nov 16, 2024 at 7:22 AM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    I would add that it's also a passion to some (me). I truly enjoy working on and making my FGT the best it can be. It's fun to develop a relationship. IYKYK.
  11. Nov 17, 2024 at 6:23 AM
    Pyreforge
    2005 Toyota Tundra
    Well next time the valve covers need to be done I'll do it myself :D
    Thanks those of y'all that were helpful, I'm going in Monday.
  12. Nov 17, 2024 at 9:35 AM
    Mr Badwrench
    Mr Badwrench New Member
    I was just about to say "you're nuts!" for saying this, but then I mentally added up all my receipts for the last two years of FGT ownership. My FGT is 24 years old now, but yeah, you are indeed correct on this.
  13. Nov 17, 2024 at 10:03 AM
    bfunke
    If you do it yourself it still beats a new truck payment. Plus there really isn’t any new truck like ours.
    HBTundra, G_unit3000 and ToyotaDude like this.
  14. Nov 17, 2024 at 10:27 AM
    I'd be shocked if they actually did this correctly.
  15. Nov 17, 2024 at 3:18 PM
    I’ve spent about $8-9000 over the life of my truck on mods and maintenance. I’ve owned it 19 years. Including the $16k I paid for it, I’ve paid $25k for 19 years of joyful ownership. I enjoy mods and maintenance, if it’s on a worthy vehicle. This one has been beyond worthy. I irrationally love this truck.
  16. Nov 17, 2024 at 3:28 PM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    I've only owned mine for less than two years, and I feel exactly what you're talking about.
