Fitcamx to plug in oem dashcam plug
Discussion in '3rd Gen Tundras (2022+)' started by Tundra341, Sep 12, 2024.
  1. Nov 14, 2024 at 1:11 PM
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
    I’m not sure how much it will drain the battery, I don’t use parking mode.
  2. Nov 14, 2024 at 2:57 PM
    RATUNDRA
    RATUNDRA New Member
    Thank you.
  3. Nov 14, 2024 at 3:01 PM
    TundBP
    TundBP New Member
    23 Blueprint Platinum
    Is there a good 3rd gen install video.. ie taking down upper console to plug Sienna wire? I heard you can break the red clips and to have backups.
  4. Nov 14, 2024 at 4:03 PM
    Pine_Cone67
    Pine_Cone67 New Member
    2024 Tundra Limited
    You should search YouTube for OEM Toyota dash cam install videos. Here is one: https://youtu.be/NOKswtbwxMI?si=eWf5mcyO3lcY8btD
  5. Nov 14, 2024 at 5:58 PM
    TundBP
    TundBP New Member
    Yes, great advice... I've watched three before the one you posted. Saw the one for Fitcam with a new Sequoia too.
  6. Nov 14, 2024 at 6:06 PM
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
    I have removed the upper console several times and the clips still hold.
    Here is a link for the red clips in case you want to order some extra. Someone else recommended them.
    https://www.amazon.com/dp/B07R1QTSQ1
    TundBP[QUOTED] likes this.
  7. Nov 15, 2024 at 5:35 AM
    Jeff_M
    Jeff_M New Member
  8. Nov 15, 2024 at 6:05 AM
    Breathing Borla
    Northern Illinois
    its the battery, HAHA:burp:
  9. Nov 15, 2024 at 6:30 PM
    Hella Krusty
    Hella Krusty New Member
    Always one in the crowd. :annoyed:
  10. Nov 28, 2024 at 10:09 AM
    riironman
    riironman New Member
    2024 blueprint platinum hybrid
    I just installed my fitcam with my sienna plug...2 issues when my truck turns on it knocks my connection off with the camera when my android auto kicks on and the camera loses power when I turn off the truck . So no parking mode . I didn't connect the y connector . What am I doing wrong? So I had to turn off bluetooth so it would connect while truck is on. OK damn thing made a liar out of me. I tapped the camera and the lights turned on. All good.
  11. Jan 18, 2025 at 2:19 PM
    619mattr
    619mattr New Member
    2024 Tundra HV Limited CrewMax TRD OR
    Fox 2.5 PES LT275/65R20 BFG KO3
    Thanks for the tip! I just installed my FITCAMX, with the 2” bracket. It’s a solid setup to not have the defroster line in video.
  12. Jan 18, 2025 at 3:31 PM
    gdisarray
    gdisarray Short term member
    2023 Tundra Limited HV
    Tint and wheels. Decked box in the bed. S and B Cold Air filters under the hood. Shiftpower throttle response controller.
    I placed my rear camera by the license plate. You can run the wire up the frame rail and then go into the cab in a small grommet under the front passenger seat.
    ABurhans, ScottieBones and G3ardnut like this.
  13. Jan 19, 2025 at 1:05 PM
    PhamKQ
    PhamKQ @PhamKQ
    Bay Area
    1794 Tundra
    FitcamX > Toyota OEM camera by far
  14. Mar 15, 2025 at 8:16 PM
    bailey bulldog
    bailey bulldog New Member
    I got mine installed using this plug and it works great for the FitcamX.
  15. Mar 24, 2025 at 6:53 PM
    riironman
    I am bringing back my truck to the dealer due to my camera views not working in my platinum. I wonder if I should disconnect the the fitcamx with the sienna adapter so they can't deny me and blame it for the causing the problem.
    4mm likes this.
  16. Apr 3, 2025 at 7:23 PM
    gdisarray
    The dashcam is a dumb cam. The truck is not aware the dashcam is even in the truck. Just a dumbed-down piece of shit camera that they installed in a case they designed. They put absolutely no thought whatsoever into the camera or its features. Enough on that... :santa2: The adapter allows the truck to get an accessory power feed and an 24/7 power feed without running two cables up there.
  17. Apr 3, 2025 at 11:16 PM
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    I’ve been looking at dash cams for our 3rd gen. Just happened on this thread today and looked at the FitCamX website. Besides the fit and easy connect, why is this so good? No real features that other cams have. It loops the video every 3 mins? (is that because of the 64G drive. So 256G would loop every 12 mins?) it doesn’t have the Starvis2 sensor everyone says to get. How is its night vision without it? Thanks for any input & review.
  18. Apr 4, 2025 at 9:06 AM
    g4waldo
    g4waldo Professional Looking CSM Owner
    2023 Celestial Silver Metallic Tundra Platinum 4x4
    I like the OEM look as it just blends in. When I say looks OEM, I mean how OEM should look, not how the actually OEM camera sticks out. The loop can be 1 or 3 minutes, which I believe was defaulted to 1 minute and lesser resolution. Doesn't matter what size SD car you have the loop duration will be the same. I changed it to higher resolution and 3 minute clips and bought a larger card to compensate for the larger storage needs. The only reason to run shorter clips or lower resolutions is smaller file size, so they don't take as long to save to the phone if needed and you can store more history on the card.
  19. Apr 4, 2025 at 7:12 PM
    gdisarray
    Looping every 3 minutes means all of the videos will be 3 minutes long. Most allow you to change that to other lengths. 3 minutes is a good recording size. It will record in 3 minute clips until the SD card fills up. Then it starts overwriting the oldest file. and so on and so on.
    With a 64 gig sd card it may only keep a few days of video before it starts overwriting. With a 256gig you may be able to hold a few weeks of video before it starts overwriting.
    As for the dashcam, I don't know why people are so gaga over the fitcam x. I bought a Tiger Cam from Amazon and it works fine. Great video.
  20. Apr 4, 2025 at 9:14 PM
    #50
    PNW Tundra Mike
    Southern Cal
    Thx for the clarification on the 3 min files. I’ve not had a dashcam yet but small file sizes makes total sense.
    gdisarray[QUOTED] likes this.
  21. Apr 5, 2025 at 5:34 AM
    #51
    ScottieBones
    ScottieBones New Member
    NC
    2025 Limited 4x4 TRD OR
    Frustrating to me that there isn't a way to link all the built-in cameras to a storage element and use it as a dash cam
  22. Apr 5, 2025 at 8:30 AM
    #52
    gdisarray
    Like I said before, Toyota put absolutely no thought into their dashcam. They just slapped some shit together and put it case that looks like it fits in the vehicle aesthetically. They may get their crap together and properly use the cameras when they go to market for the Gen4 in 2035. Until then, they ain't going to do shit. It is a GD shame.
    ScottieBones[QUOTED] likes this.
  23. Apr 10, 2025 at 12:29 PM
    #53
    Phillydude31
    Phillydude31 New Member
    Eric
    2024 Tundra Limited Crewmax
    Went ahead and ordered the FitcamX And the “Sienna cable”. I’m very gun shy about installing this stuff myself but gave it a shot,
    finished in 15 minutes. Easy to do, looks great, good quality.
    Thanks everyone!
    ScottieBones likes this.
