Leveling kit didn't level my truck...Update: Resolved!
Discussion in '3rd Gen Tundras (2022+)' started by 1Exyankee, Dec 6, 2022.
  1. Dec 6, 2022 at 2:07 PM
    1Exyankee
    1Exyankee [OP] New Member
    Plano, TX
    2024 Tundra Platinum Hybrid 4x4
    1.75" Rough Country leveling kit, LT285/60R20 Cooper Discoverer AT3 XLT All-season tires, BAK Revolver X4s roll up Tonneau cover
    I was looking around at leveling kits for my 2022 Platinum Tundra. Most all that I found were 2" leveling kits. Rough Country advertised a 1.75" kit. My assumption was that they really had the correct height dialed in. The last thing I wanted was for the front end to be higher than the rear. The pics on their web site showed the same image for Gen 2 and Gen 3. I asked, they said it was just a stock image. I received the kit, it had the correct SKU but the paper inside identified it as being for 2021 and down. I called. They assured me it was the correct kit. I had it installed. The front end is now a little over 1.5" higher than the rear. I logged back in to their web site and now the price for the Gen 3 kit was $59.00 less and it was a different image. I sent them a message and called. Their response was "its just made of different material. It's the same kit. Sorry, we can't do anything. I am paraphrasing a bit. Their response was non-existent until I gave them a one star review. Then they emailed but really didn't care and didn't respond to my last two messages. So, does anyone know of a Gen 3 leveling kit that will actually make the truck level? If not, I will just have the current kit removed and keep it stock. Thank you
    Durtywrench and iiawah808 like this.
  2. Dec 6, 2022 at 2:30 PM
    iiawah808
    iiawah808 New Member
    Oahu, HI
    2022 iForce Tundra Limited TRD Offroad
    Currently Searching....
    I assume you have rear air suspension?
    if so, that may be your problem and you can adjust your rear ride height at the bracket. I'm sure someone will chime in on how to do it. Refrain from taking the kit off at the moment and research the bracket adjustment.
    Search Button.....it is the way.
    1Exyankee[OP] likes this.
  3. Dec 6, 2022 at 2:43 PM
    veselik3
    veselik3 Member
    22’ Tundra Crewmax TRD OR Army Green
    If the rear bracket adjustment doesn’t fix, I installed a cornfed 1” spacer up front and like it. Still a slight rake, but leveled out for the most part nicely. As the reply above states though..pretty sure that bracket will be your ticket.
  4. Dec 6, 2022 at 3:18 PM
    brucega7x
    brucega7x New Member
    2022 Tundra SR5 CrewMax 4X4
    I have the RC 1.75" leveling kit and mine is perfectly level.
    Edit: Maybe it's my imagination, but the back of your truck looks lower than mine for some reason.
    Regardless, the RC 1.75" leveling kit is perfect for me.
    Raven67 and 1Exyankee[OP] like this.
  5. Dec 6, 2022 at 6:11 PM
    DimaA
    DimaA New Member
    Dmitriy
    WA
    2022 toyota tundra platinum
    K&N air filter. Front windows tint, RC front leveling kit.
    Same here installed RC 1.75 mine is AVS so I was able to adjust with levers, now it's perfect
  6. Dec 7, 2022 at 10:43 AM
    1Exyankee
    Plano, TX
    Thank you all. This is good information and I am pretty confident my Toyota service folks did not adjust the rear brackets. So for the folks who installed the 1.75" RC kit, in both cases your installers had to adjust the rear brackets to get your trucks level?
  7. Dec 7, 2022 at 11:56 AM
    1Exyankee
    Plano, TX
    Are the levers to adjust the rear brackets accessible if I crawl underneath? Is it something I can do or do I need to get it in to the shop?
  8. Dec 7, 2022 at 12:02 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
  9. Dec 7, 2022 at 12:10 PM
    1Exyankee
    Plano, TX
    Thank you Sir!
    mountainpete likes this.
  10. Dec 7, 2022 at 4:24 PM
    brucega7x
    I never adjusted anything on the rear of my truck. I was just saying that for some reason, your truck just looks lower in the rear than mine. Might just be the angle of the pic though.
  11. Dec 12, 2022 at 8:24 AM
    1Exyankee
    Plano, TX
    I want to thank everyone for your responses. I was able to show the Toyota store where the adjustment was for the air ride. We moved it all the way up and the truck now sits level. The Service folks were appreciative. They haven't had to do anything with the air ride yet so they were unaware of the ability to adjust the height manually. They have a couple other customers with the same issue who will benefit from that knowledge. Thanks again. That was frustrating but I wish all my problems were that easy to fix!
    Raven67, M3Tundra-JK, R2theD2 and 3 others like this.
  12. Dec 12, 2022 at 8:36 AM
    R2theD2
    R2theD2 New Member
    Seattle
    2022 Tundra 1794 TRD Off-Road Lifted - Midnight Black
    TRD Lift Kit TRD Skid Plate TRD Running Boards Nitto Ridge Grapplers (35x12.5) OEM Bed Step OEM Toyota Tonneau Cover (Quad-Fold) 3M Window Tint (matched factory rear) Spray-On Bedliner
    How is the ride compared to before you installed it?
  13. Dec 12, 2022 at 9:42 AM
    1Exyankee
    Plano, TX
    If there is a difference it is not measurable enough for me to notice.
    ryanwgregg likes this.
  14. Dec 12, 2022 at 3:40 PM
    Custommarineconcepts
    Custommarineconcepts New Member
    Eric
    2020 Tundra Off Road
    Truck looks amazing what size tires are you running?
  15. Dec 12, 2022 at 3:52 PM
    1Exyankee
    Plano, TX
    Thank you. It looks a lot better to me now that it's level. I have 285/60R20 Cooper Discoverer AT3 XLT All-Seasons
  16. Jan 5, 2023 at 7:44 PM
    Yota802
    Yota802 New Member
    2023 Tundra Hybrid Limited CM WP
    I had the RC 1.75 installed as well. Sometimes it looks level, and sometimes the front looks high… As we all know, the hood line is higher than the bed line, it can be tricky to the eye…but I haven’t actually measured yet. I’m thinking at the 3k service to remove break in oil I’ll measure in the shop on a level surface. I was looking at the Cornfed 1/2” or 1” rear spacer as a potential fix option.
    Raven67 and lamaquina11 like this.
  17. Jan 6, 2023 at 9:59 AM
    1Exyankee
    Plano, TX
    When I took my truck in for the oil change I showed them these pics of the levers that need to be adjusted. They were not aware the air ride had adjustment levers. On mine they moved them all the way up and the distance between the bottom of the wheel and the middle of the wheels is the same. No need to add lift to the rear if that works for you.
  18. Nov 14, 2024 at 6:05 PM
    Treyota
    Treyota New Member
    Same issues with my 2022 Platinum and couple try resulted in the Texas Tilt version but worked it out with rear air brackets (bracket up is a must). Final results what I was looking for. Great ride and nice job Toyota on the suspension tech.
  19. Nov 14, 2024 at 6:16 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I did the RC 1.75”. I have the TRD Offroad suspension. It sat nice and level but after adding the cover and tent etc… it was a bit lower. I put a 1” westcott in the rear and that makes it just a tad higher in the rear.
    When towing it drops about an inch but still looks okay.
    The ride was about the same with the RC kit but once I added the rear 1” the ride got a whole lot smoother. Not too sure why it changed but it is pretty good now.
  20. Nov 14, 2024 at 6:29 PM
    Treyota
    Treyota New Member
    Also RC 1.75 level kit like 1Xyankee
