A/T overheat engine warning light after washing 2012 tundra truck and engine turns off. What to do?
Discussion in 'General Tundra Discussion' started by Thokie, Nov 6, 2024.
  1. Nov 6, 2024 at 2:20 PM
    Thokie
    Thokie [OP] New Member
    Tom
    2012 tundra
    A /T overheat check engine light comes on and engine stops. This started after washing the truck. What to do to get truck to run? Help please.
  2. Nov 6, 2024 at 3:40 PM
    Like, washing inside the engine bay?
  3. Nov 6, 2024 at 5:34 PM
    Thokie
    Tom
    2012 tundra
    No, just washed outside, sprayed wheel wells and undercarriage with garden hose
  4. Nov 6, 2024 at 6:15 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Any CELs - read even if not lit - may have a pending code for a clue as to what shorted out. Of course - its not really overheating - correct?
  5. Nov 7, 2024 at 4:01 AM
    Thokie
    Tom
    2012 tundra
    I think it’s just the warning light and then it turns engine off. Only runs for 10-15 seconds before shutting down. Hard to believe it actually overheated that quickly
  6. Nov 7, 2024 at 4:33 AM
    Johnsonman
    Austin
    Sequoia
    Then its a temp sensor that shorted - might dry out and work again or not
  7. Nov 14, 2024 at 11:58 AM
    Thokie
    Tom
    2012 tundra
    Took it to Toyota shop. They said it was a fault in the fuel pump ecu which caused numerous faults which is why the a/t oil temp overheating warning light was activated and that nothing was wrong with the transmission or it’s oil temp sensor. They charged $435 for the part. It works fine now. I have a couple follow up questions for the forum here.
    1. Where is the fuel pump ecu physically located?
    2. Is it possible to get it wet and cause it to short out when washing dirt off the wheel wheels and undercarriage with a garden hose?
    3. Or was it unrelated that the problem occurred after I washed the truck?
    4. Can I never wash the truck again?
    Thanks for any thoughts
  8. Nov 14, 2024 at 1:34 PM
    Johnsonman
    Austin
    Sequoia
    Got a part num? When I look it up on a toyo parts list I don't find "fuel pump ECU" or any variation of it. Anybody else find it?
  9. Nov 14, 2024 at 2:25 PM
    Thokie
    Tom
    2012 tundra
    Toyota 89571-34070 Computer, fuel pump control.
    Tunrod likes this.
  10. Nov 14, 2024 at 2:37 PM
    Thokie
    Tom
    2012 tundra
    I found diagram and location on autoparts.Toyota.com. It’s located by the rear wheel on the inside of the frame . Past the gas filler port. Its full name is Fuel Pump Control Computer. Another article said it’s more likely the wiring got corroded over time from road salt, etc. That didn’t seem to be my problem as it wasn’t replaced by the shop. I’m still wondering if water from washing the underside of wheel wells and frame cause the old part to short out. I hope it doesn’t happen again as it was $680 total repair bill.
    DoublePro likes this.
