Any truth to the RockAuto claim i need a specific AC Compressor
Discussion in '1st Gen Tundras (2000-2006)' started by Overlander5, Nov 12, 2024.
  1. Nov 12, 2024 at 7:34 AM
    Overlander5
    Overlander5 [OP] New Member
    2001 standard cab 1 owner
    Ive found the seals on my 200000 mile ac compressor are gone. Not gonna throw any more autozone recharge cans at it. About to change my timing belt and water pump so while im in there i figure Ill change it out. The rockauto listing for their Denso ac compresser says "Certain vehicles came with multiple compressor styles. You can only replace your current compressor with the same style compressor." How true is this, and if so how do I find it if i cant get to the back of the compressor?
  2. Nov 12, 2024 at 7:52 AM
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    I used to have a neighbor (wish he'd never moved) who was a master auto tech in a shop that specialized in Toyota/Lexus, and Nissan/Infiniti.
    He would do all our maintenance (and the very seldom repair) in his driveway, saved me TONS of money.
    I bought the parts, usually from Rock Auto, so he had no stake in whether I bought OEM or cheaper alternates.
    He would tell me once in a while "Just buy whatever's cheapest, doesn't matter." but 90% of the time he would strongly suggest that I get OEM, and 90% of the time that is Denso.
    He told me Toyota's are more picky about this than most other brands.
    Any way you can get a camera to the back of it?
  3. Nov 12, 2024 at 8:01 AM
    Overlander5
    potentially. Ill give it a shot when i get home.
  4. Nov 12, 2024 at 8:14 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    Wait, how do you know the seals on your compressor are bad? Did you UV dye test it?
    ATBAV8 likes this.
  5. Nov 12, 2024 at 8:27 AM
    Overlander5
    yes. ive had to constantly add freon and i finally dye tested it (also replaced everything else) and found a decent amount of it on the compressor.
    FishNinja likes this.
  6. Nov 12, 2024 at 8:32 AM
    You probably don’t need to replace the entire compressor, it’s usually the hoses or the manifold o rings that will leak
    shifty` likes this.
  7. Nov 12, 2024 at 8:40 AM
    Overlander5
    How difficult of a job would that be? I know there are oring kits, do i need to buy one specific to whatever model of compressor i have?
  8. Nov 12, 2024 at 8:43 AM
    FishNinja
    Lee
    06DC2wd
    toasty is correct. Where exactly where was this dye located? It could simply be the oring that seal the compressor manifold.
    unless you're 100% certain it's coming from the actual seals from the compressor housing.
    I used to work at my dad's AC and power window shop as a tech.
    I will tell you a repairing an AC system is not as easy as simply replacing the compressor. If that's your issue.
    leaks = contaminants = accelerating the failure of new parts
  9. Nov 12, 2024 at 8:45 AM
    FishNinja
    Lee
    06DC2wd
    the manifold should be a single bolt on top of the compressor which should have 2 orings. Or it will be 2 separate manifolds(hi and lo side). You MUST get the proper orings for this.
    Then get a professional to set a vaccuum to your system and check for leaks. If you're good, then have them recharge it with fresh oil and refrigerant. The amount is on a yellow sticker under your hood. Mine is on the passenger side.
    ATBAV8, FrenchToasty and SD Surfer like this.
