Rear seat (left side) fold latch release strap replacement?
Discussion in '1st Gen Tundras (2000-2006)' started by Tsgrav2011, Jan 30, 2021.
  1. Jan 30, 2021 at 10:38 AM
    Tsgrav2011
    Tsgrav2011 [OP] New Member
    Yuma
    2006 4D TRD 2WD
    Brush scratches and dents
    F7710684-8BC7-4762-BB44-76AD98D5CC35.jpg My 2006 4 door, the left rear seat folding pull tab is gone and fixing it has me stumped. I searched the forum and have not found this problem. Most likely I’m not asking the right question in the search. The problem is left side rear seat folding release pull tab/strap is not there. So I can’t fold up the left rear seat. I ordered a replacement pull strap from the Yuma Toyota dealership. I could use help on how to dig in to the seat bottom to get to the cables and fold up the seat. Item number 78920B. Then maybe remove the rear seat, take it out to fix it.
  2. Feb 16, 2021 at 6:44 AM
    Tsgrav2011
    Yuma
    2006 4D TRD 2WD
    Help? Anybody? It’s been a couple weeks and either I am missing something so obvious that it doesn’t need answered or maybe nobody has had this problem. Any help would be appreciated. Thanks.
  3. Feb 18, 2021 at 4:45 AM
    Professional Hand Model
    Fred
    Hand Protectors
    I’m not familiar with the DC, but from looking at the diagram you provided: Can you use some needle nose pliers to grab/pull the loose wire under the seat?
  4. Feb 18, 2021 at 10:28 AM
    Tsgrav2011
    Yuma
    2006 4D TRD 2WD
    Thanks for the reply. The back seat is slammed right to the floor. No way to get under it that I can see. The only option that I see is to remove the screws in the plastic bottom trim and pry it down. Maybe I can get to the cable mechanism that way. Thanks
  5. Feb 18, 2021 at 5:20 PM
    Fred
    Hand Protectors
    Post up pics of your success.
  6. Feb 18, 2021 at 6:12 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Perhaps use an right angle or hook shaped pick to grab the release mechanism the cables are attached to?
    If you can get the plastic off or there is room to sneak them by.
  7. Feb 20, 2021 at 9:37 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I'll flip mine up this afternoon and see if I can get a few pics for you.
  8. Feb 20, 2021 at 1:30 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    So I didn't end up taking any pics because there's not really anything to see.
    It looks like you could take out the two visible screws with the seat down and pull the panel down enough to get a pair of needle nose in to grab the cable.
    The strap itself is only about 3 inches until it connects to what looks like a pin.
    If it warms up tomorrow I'll pull the underseat panel off and get some pics.
  9. Feb 20, 2021 at 11:48 PM
    912 @best_gen_tundra
    Fulltime RV traveler
    2005 DC 4x4
    Hopefully these help. I recently had my seats out and all apart. I took a bunch of pictures. Hers a few from inside the drivers side rear seat.
    4E8FB9BA-A87D-4B73-B24B-9EE6007CE663.jpg 3AAAB2D9-940B-4615-A00C-14C2A5D0E4BE.jpg 4A0EFDCF-CA02-476A-94A5-C648EF156C5F.jpg
    hammeron and Festerw like this.
  10. Feb 21, 2021 at 6:13 AM
    Fred
    Hand Protectors
    Might have to do the ‘No Look’.
    912 and FrenchToasty like this.
  11. Nov 7, 2024 at 5:55 PM
    DarkMint
    DarkMint just gettin by
    Ben
    2004 Tundra DC SR5 4WD
    Resurrection. Im having this same issue on my rear seat passenger side. Seat removal and replacement is common for me, I'm sure there's supposed to be a tab there but now it looks like there isn't. It must've broken or something. I have removed as much of the plastic trim bottom panel as I can to reach inside but there's no cable or anything. Did you ever fix this? @Tsgrav2011
    @912 any tips?
  12. Nov 7, 2024 at 5:59 PM
    DarkMint
    Ben
    How I have it right now with a look underneath. No sign of a cable to grab and pull. Feels like I've lost my marbles
    F729407C-5B28-4B51-AA50-68B02B1D7B85.jpg BB6C5F19-BF5E-4557-AE6D-D5B44CB2AF6E.jpg9B2F4A3A-EA35-495A-AFEC-75A56DAC15A3.jpg
  13. Nov 7, 2024 at 6:33 PM
    Tsgrav2011
    Yuma
    2006 4D TRD 2WD
    My 2006 right side rear pax bottom has a lever to release the catches. Only the drivers side rear seat bottom has a cable.
    I don’t see a lever for the seat bottom in your photos. The 2004 might be different??
  14. Nov 8, 2024 at 7:23 PM
    DarkMint
    Ben
    i had a total dipshit moment. You are correct in that The lever to raise/collapse the seat back also disengages the rear bar latch like your pass side backseat too. Few years ago i was removing/reinstalling the backseats on the original seats the truck came with, with the pull tab as seen in a prior post of mine from years ago. Now my current backseat is a unit pulled off a junkyard Sequoia, and i guess the mechanism the same as the 05-06 tundras. Derp
    6FD725A8-A0B0-4AF7-8989-5310AAFA30A4.jpg EB989515-A03E-45C6-AF78-E8121B61D9A1.jpg 7C170E0F-BB45-40A3-B9F4-249D9D073E0C.jpg
    When the seat back moves (with the regular side lever, no pull tab), the bottom left red tab pushes up on the little roller pointed to by the red arrow. This causes downward force on the connector-bar-thing which pivots the seat latch mechanism, and thus, disengages the latch.
  15. Nov 11, 2024 at 4:22 PM
    Tsgrav2011
    Yuma
    2006 4D TRD 2WD
    I did finally get mine fixed after putting it off for a year. Using the parts illustration, I could see the cable was what to get after …so thats what I did. Removed as many of the screws that attach the plastic trim around the bottom of the seat then pried it down enough to get my hand into the void underneath to where I felt the cable. With the plastic trim trying to cut my forearm open I was able to pull the cable housing and the seat popped open. The replacement cable is not available new from Toyota, but after looking at the outboard section that connects to the pull tab to the rest of the assembly, it is the same cable as a bicycle shifter cable. Being a MTB rider I happen to have a couple of those cables so I replaced the outboard section with the shifter cable and for a handle I used a piece of wood handle sawed off a small wire brush. Drilled three holes in it and laced the cable through the holes and back to its self. Works like a champ.IMG_5921.jpg
    DarkMint likes this.
