New member
Discussion in 'New Member Introductions' started by sandyt1969, Oct 31, 2024.
  1. Oct 31, 2024 at 10:41 AM
    sandyt1969
    sandyt1969 [OP] New Member
    Sandra
    Hello my name is Sandra I have had a 2007 Toyota Tundra that recently was totalled in an accident and I knew that truck inside out and backwards . The 2007 was a great truck no problems I always maintained my maintenance and in 15 years of owning the vehicle I only put on two sets of brakes and rotors and 3 sets of tires and1 O2 sensor. Now I am the owner of a 2014 Toyota crewmax and I am lost when it comes to even diagnosing this truck . Is there anything anyone can tell me to look for. I did recently have the problem with the blinking 4wheel hi and low and the ABS light on but it all went away when I changed out the ABS sensors it blew the code PO500. So I am just worried that I am overlooking something it was such an easy fix
    Cruiserpilot likes this.
  2. Oct 31, 2024 at 12:40 PM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    Do you have your own diagnostics reader? I only have an Autel for my 2010 Tundra. Friend recommended it
    for me. I'm not home so can't tell which one.
    Open this same in the 2.5 Generation Forum. I'm sure someone there will be more informed than I am.
    2.5 Gen Tundras (2014-2021) | Toyota Tundra Forum
  3. Oct 31, 2024 at 1:32 PM
    Welcome from NY.
  4. Nov 1, 2024 at 5:09 AM
    sandyt1969
    Sandra
    Thank you . Well does anyone know how to reset the abs . I changed the sensors and my lights are still blinking off and on with the abs light and now the 4hi and 4lo.
  5. Nov 1, 2024 at 6:25 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  6. Nov 1, 2024 at 6:42 AM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    Have you disconnected the Neg battery cable yet? I know on some vehicles you could use a paperclip and jump 2 pins in the OBD port to clear codes/lights.
  7. Nov 2, 2024 at 2:52 PM
    sandyt1969
    Sandra
    I replaced all four ABS sensors took the negative off for an entire afternoon . Reconnected the battery drove out of my driveway now the abs sensors back on my tractor control back on now my check engine light came on and my brake light is on as well as the 4hi and 4low. I can’t win. Any ideas
    Yepyep likes this.
  8. Nov 11, 2024 at 4:06 PM
    Yepyep
    Yepyep New Member
    2014 platinum
    Same for me. Not sure where to go from here
