  1. Nov 10, 2024 at 3:28 PM
    IIRC from my recent hunt for a cheap set of OEM wheels, the backspace on those specific wheels and the similar T4R 6-spoke are both around 5.5" and therefore not very friendly for our 1st gens. You'd need to slap a 1" - 1½" spacer to keep from rubbing the upper half of your suspension.
    But if you have no intent to lift, or you plan on running mild non-AT/non-MT tires that are less than 31½" overall diameter and similar width to factory, they should be fine. Sounds like that's not the case though.
  2. Nov 10, 2024 at 4:19 PM
    Upshot Knothole
    Upshot Knothole New Member
    Thatchery
    PDX OR
    2003 SR5 V8 AC TRD 4x4
    Yeah I wasn't even thinking about the backspace on those wheels. I just prefer the polished/brushed wheels over black wheels with a silver truck.
    And I do need M+S tires where I live and am currently at about 31 1/2" diameter, but I'll see what I'm using the truck for when my current tires wear out. If I get another dirt bike before then, I'll probably consider lifting it slightly and maybe going with 275s. I've still gotta deal with LBJs and replacing the TB in the next month or two. It's just so easy to get sucked into looking at wheels on craigslist.
  3. Nov 10, 2024 at 5:24 PM
    I do it too. And FB Marketplace.
  4. Nov 10, 2024 at 5:42 PM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    Anyone know if the climate control backlight bulbs have the green rubber covers?
    I'm planning on replacing those bulbs and I'm sure I'll rip the covers during removal.
  5. Nov 10, 2024 at 5:56 PM
    Upshot Knothole
    Thatchery
    PDX OR
    I had to replace mine over the summer and I believe they did and the new ones didn't and I didn't notice any difference.
    FiatRunner[QUOTED] likes this.
  6. Nov 10, 2024 at 6:31 PM
    My 2006 did. And when you remove that and put in LED without them, it is BRIGHT.
  7. Nov 10, 2024 at 6:33 PM
    Upshot Knothole
    Thatchery
    PDX OR
    I used a box of regular bulbs I got off Amazon and they were fine without the green condoms, didn't want to deal with having to replace all of them with LEDs just yet.
    FiatRunner likes this.
  8. Nov 10, 2024 at 6:33 PM
    I put in Sylvain a Zevo lifetime bulbs and they are BRIGHT
    FiatRunner and Upshot Knothole like this.
  9. Nov 10, 2024 at 6:38 PM
    FiatRunner
    Jack
    Another bulb-related question:
    My low fuel light has stopped working. I'm assuming it's the bulb, but it's got a different socket type than all the other warning lights on the cluster. It even has a different part number than the other ones. However a 74/T5 fits that spot. Anyone had any issues after replacing it with a normal 74/T5?
  10. Nov 10, 2024 at 6:44 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    How hot do those little led bulbs get? Could you dip em in a translucent paint, or use a plastic cap?
  11. Nov 10, 2024 at 6:46 PM
    I believe you can only use an incandescent for the fuel light due to its resistivity being part of the circuit.
  12. Nov 10, 2024 at 6:49 PM
    FiatRunner
    Jack
    Sweet. Good to know. Thanks.
    Possible unpopular opinion: the green backlights on our trucks is cool. I like it a lot.
  13. Nov 10, 2024 at 6:58 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    The orange in the titan is pretty cool.
    okay nerds, if i wanted to keep my interior lights dimmable, but at max bright everything is white (for quick & easy cab lighting), then as you dim they cycle through colors so blue to red, so red is the bottom color at max dim. Like my gauges are brighter in pasadena, because of night brightness, so green, but around here, they're dimmer cause i'm looking for deer, so orange, and i turn em damn near off on long trips at night. But a dim red would be fine. Night vision is something to cherish as long as you can. Same with your hearing, so my stereo's always quiet.
  14. Nov 10, 2024 at 7:13 PM
    Definitely has a 1980s vibe to it. But I love @empty_lord’s cluster where he sanded the green away from the MPH arch of numbers and stuff. However, for us 2005-2006 guys, that’s the only way to change colors. Y’all with 2000-2004 are lucky like that.
    and yes, Bill is right. Can’t use LED on fuel light. And one other light I forget.
  15. Nov 10, 2024 at 7:41 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
  16. Nov 10, 2024 at 8:44 PM
    Upshot Knothole
    Thatchery
    PDX OR
    Reminds me, I still need to replace my D light, but kinda enjoying having one less light on the dash at night.
    Sirfive and FrenchToasty like this.
  17. Nov 10, 2024 at 9:16 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    I cant think of a good reason to replace mine.
    Upshot Knothole likes this.
  18. Nov 11, 2024 at 5:56 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    bmf4069, JakeJake and BroHon like this.
  19. Nov 11, 2024 at 6:02 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I wanna know if you're going to install a shift kit while your new trans is out.
  20. Nov 11, 2024 at 6:06 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Not on the Cali one. I'm keeping the original and might play with that in the future when I decide to tackle rebuilding it.
  21. Nov 11, 2024 at 6:07 AM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    Glad I got in at the beginning of the run on them! Sheeese
    Hahaha I think it was me who asked where you get them, and that got the ball rolling!:burp:
  22. Nov 11, 2024 at 6:16 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Has anyone gotten a high milage club card?
    455h0le_dachshund likes this.
  23. Nov 11, 2024 at 6:42 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I see you saw that supercharger thread.
    I'm rusty AF on the topic, but I think I nailed it. :D
    Good for though.
  24. Nov 11, 2024 at 6:42 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Nope. Is it like a credit card?
  25. Nov 11, 2024 at 8:42 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Swapped my caps shock today and tested it's new keys. One key hole was stubborn but works. They other is fine.
    Once I got one of the old shocks off I could finally see the wording that was on the backside blending in with the rust. It's 28lbs and I got 35lbs. So I only replaced one side. Will keep the other as a spare. I'll probably get the weather stripping situated this Thursday, Friday, or Saturday.
    @Sirfive my u-bolts and center pins arrive tomorrow. You order yours yet? We can have a bastard leaf pack party soon.
    oscardog86 likes this.
  26. Nov 11, 2024 at 9:36 AM
    Neo
    Neo New Member
    Alabama
    Yes, they do. I just replaced mine with LEDs.
  27. Nov 11, 2024 at 9:38 AM
    Neo
    Neo New Member
    Alabama
    I chose the green LED from superbrightleds.com (194-GHP5), which mitigates it a little, but they are bright.
  28. Nov 11, 2024 at 2:19 PM
    Was feelin horny today after all. So I mounted and blew these. Impressed.
  29. Nov 11, 2024 at 2:52 PM
    TXTundraGuy23
    Dallas
    2004 DC 4.7L 4WD
    Well I didn't actually do anything to the truck but I finally ordered a bunch of stuff. 6112/5160s, rear leaf springs, Suspension Maxx sway bar links, JBA UCAs. Still need to order CV axle boots and my wheelers AAL. Wheeler's seems like the kind of place that may have a decent Black Friday sale, so I may wait on those. Felt good to order it and quit thinking about it. Had a good October at work too, so that helped...
  30. Nov 11, 2024 at 2:52 PM
    Hutcheson
    Hutcheson New Member
    Caleb
    2004 DC Limited
    Phase 2 of my exterior lighting upgrades are complete. Fog lights are in and operable, I may try and modify the old plastic shrouds that fit inside to “finish” it off but I don’t hate the look as is. Still need to properly test them out so not 100% sure if they’ll still where they are or if I’ll have to mount them to stick out further.
