General Supercharger Thread
  1. Nov 10, 2024 at 2:42 PM
    st8rocks1
    st8rocks1 New Member
    2007 Tundra
    I’m on OEM belt #2 that squeals when it’s cold. Extremely annoying. Both purchased in early 2023. TRD SC, stock pulley.
    Mdl likes this.
  2. Nov 10, 2024 at 2:49 PM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    ive got the mag 2650 and 76mm pulley so im running the green belt and have started getting a lite squeal
    Mdl likes this.
  3. Nov 10, 2024 at 4:21 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Well, the stock intake manifold gaskets don't stay put in the Harrop 2650's machined grooves, so I'll call Harrop tomorrow to see if I can get an O-ring the same size, or if I need to special-order the SC gaskets.
    Also, during mock-up I found that the Harrop body doesn't allow for a longer screw to be fit in the back holes, so I'm going to try studs back there as well.
    pursuit2550 and Mdl[QUOTED] like this.
  4. Nov 10, 2024 at 5:00 PM
    pursuit2550
    pursuit2550 New Member
    That's sucks. Would figure they would just machine it to fit the OEM gasket like Magnuson.
  5. Nov 10, 2024 at 5:26 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Yeah, even the spacers are machined for the OEM gasket. I was tempted to use some FIPG between the spacers and the SC, but I know that'll be a pain to clean up later. I emailed Harrop, they're pretty quick to respond so I should have an answer tomorrow.
  6. Nov 10, 2024 at 5:36 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I wonder if some Red N tacky grease would hold them in there well enough for installation. Could be a bit risky I guess.
  7. Nov 10, 2024 at 6:02 PM
    Tundras.com Forum Santa
    Tundras.com Forum Santa Milk and Cookies
    Santa
    3" Lifted Sleigh. sPOD lights on each reindeer. HeftyFab sliders
    Tripleconpanna and Saltyhero13 like this.
  8. Nov 10, 2024 at 6:29 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    lol negative it was spinning the tires and I pedaled it a bit
    e30cabrio, Tripleconpanna and Mdl like this.
  9. Nov 10, 2024 at 6:52 PM
    Santa
    I think you got scared and your foot slipped :boink:
  10. Nov 10, 2024 at 8:31 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    It was the fancy golden driving loafers he is rumored to wear.
  11. Nov 10, 2024 at 11:29 PM
    Santa
    No Italian driving shoes for that dude... probably a classic fur lined Croc w/charms :rofl:
  12. Nov 11, 2024 at 4:19 AM
    bflooks
    bflooks New Member
    Metrowest MA
    Needs more flair. We just want him to express himself.
    https://youtu.be/_ChQK8j6so8?feature=shared
  13. Nov 11, 2024 at 5:44 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
  14. Nov 11, 2024 at 6:17 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Is it squealing due to your tensioner? I've replaced mine twice but so far, it's been holding well three years later...
    st8rocks1[QUOTED] likes this.
  15. Nov 11, 2024 at 6:45 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Haha when wheelin hard I am wearing some Piloti’s
  16. Nov 11, 2024 at 7:01 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Of course you do...
    HA!
  17. Nov 11, 2024 at 7:13 AM
    st8rocks1
    2007 Tundra
    I’ll have my mechanic check! The belt was replaced when he did water pump and an idler pulley he noticed had some play.
    HulkSmurf14[QUOTED] likes this.
  18. Nov 11, 2024 at 7:54 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    For any Harrop owners, the replacement is a BS139 o-ring. I'm ordering 8 from Harrop for $33 shipped, but found these that I also ordered to see if they will work.
    https://www.amazon.com/dp/B000FMUQPW
    Mdl, Silver17, e30cabrio and 2 others like this.
  19. Nov 12, 2024 at 3:56 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Those o-rings fit perfectly, so I'll have spares. Reflective heat shielding cut and installed after cleaning.
    Here you can see the longer bolt that won't fit the rear passenger-side mounting hole, interferes with the Harrop intercooler end plate...could probably massage the hole with a carbide bit and make it fit, might only be an issue with the Harrop...I replaced the rear holts with studs and nuts, which helped with lining up the supercharger during reinstallation so I didn't muck up my o-rings again.
    I split the rotor pack from the SC base to make reinstallation easier. Here is the SC base reinstalled and torqued down, I can't even see the spacer.
    I wasn't able to get a socket over the rear passenger-side stud to torque the nut, but I was able to tighten with a wrench...really tough to get to with my fuel lines running back there.
    Saltyhero13, Mdl, e30cabrio and 10 others like this.
  20. Nov 12, 2024 at 4:17 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Nice work! Was that heat shield just the aluminum reflection type or the DEI heat shield stuff with the matting behind it?
  21. Nov 12, 2024 at 5:22 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    It has the fiberglass between the foil and sticky side
    bflooks[QUOTED] likes this.
  22. Nov 12, 2024 at 5:30 PM
    e30cabrio
    Like this?
    Mdl and armyoffoo like this.
  23. Nov 12, 2024 at 5:34 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Yep, same type of stuff
  24. Nov 12, 2024 at 6:04 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Sweet! Now for the road test before the weather turns...well its been pretty dry out east. Especially by @bflooks.
    armyoffoo[QUOTED] and bflooks like this.
  25. Nov 12, 2024 at 6:06 PM
    Silver17
    Eastern PA
    Anyone have a recommendation on where to buy good replacement Bosch LSU 4.9 wideband sensors? Looks like they’re 130-150 dollars. Not gonna lie, I’m tempted to try the cheap Chinese knockoffs that are 40 bucks with 4 star average reviews on Amazon. I can replace it 4 times for the price of one Bosch…
    snivilous[OP] likes this.
  26. Nov 12, 2024 at 6:10 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Just read an article that the state is currently at something like 215 wildfires so far this month. Typically around 15 for all of November. We did get 0.25" of rain yesterday though! First measurable amount in ~1 month. Governor is asking people to conserve water because they need it to fight the fires. Riches to rags type of year.
    Mdl[QUOTED] likes this.
  27. Nov 12, 2024 at 6:14 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Mdl, HulkSmurf14 and Silver17[QUOTED] like this.
  28. Nov 12, 2024 at 6:24 PM
    Silver17
    Eastern PA
  29. Nov 12, 2024 at 6:28 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I visually compared the new and the replacement in every way that I could think of, the connectors and the markings on the sensor itself, and the replacement looked identical.
    Silver17[QUOTED] likes this.
  30. Nov 12, 2024 at 6:39 PM
    Silver17
    Eastern PA
    Awesome! Ordered. So glad I don’t have to remove the front driveshaft to replace it now also.
    Mdl, HulkSmurf14 and Wynnded[QUOTED] like this.
