5.7 Oil Pan Removal
Discussion in '2.5 Gen Tundras (2014-2021)' started by TGBTG7701, Nov 9, 2024.
  1. Nov 9, 2024 at 4:29 PM
    TGBTG7701
    TGBTG7701 [OP] New Member
    Keith
    2016 SR5 4x4
    3" Lift 33/12.50- 20 tires
    I need to pull and replace my oil pan, I had a mishap while changing my oil. The drain plug is not tightening up, the fitting in the oil pan spins. I removed the bolts, but it won't budge, even a few good wacks with the dead-blow hammer didn't seem to break it loose. I have a new pan, so if I dent up the old it's not a big deal. Is there a trick to get the seam to break loose? :confused:
  2. Nov 9, 2024 at 4:53 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Had a similar issue with the transmission pan. I used a plastic interior removal too and wedged it in a corner. Used a soft hammer to penetrate further and worked it s8de to side from there.
  3. Nov 9, 2024 at 5:43 PM
    pursuit2550
    pursuit2550 New Member
    Also check to see if it has a gasket or if it uses FIPG sealant. If it's a sealant then I highly recommend the Toyota one. I have used it on other projects and it hands down the best FIPG I have used. And yes, you have to pry it off.
    bflooks likes this.
  4. Nov 9, 2024 at 7:23 PM
    WhiteSR5
    WhiteSR5 New Member
    SC
    2021 DC SR5 4x4 (guess the color)
    Flat tip screwdriver at the left rear corner of the pan to break the sealant. Go easy, it doesn’t take much to break the seal, then gently work around the perimeter.
    Clean mating surfaces well. Use Toyota FIPG to avoid having to reseal later.
    ETA: if you’re not comfortable using a screwdriver, a stiff putty/drywall knife will work. It just a little tight getting up in there
  5. Nov 9, 2024 at 7:58 PM
    bflooks
    bflooks New Member
    Metrowest MA
    I recently had to do this, twice. It's a pita, but take your time. Everyone has given great advice, both to break the seal and. To clean both surfaces.
    I found plastic scrapers works well as does an abrasive cleaner attachment for a drill. Toyota FIPG all the way. Plan on 1/3 - 1/2 tube to reseal.
    Jego likes this.
  6. Nov 10, 2024 at 9:53 AM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    Can you get the plug back out? Maybe just the plug is stripped and you can clean the threads in the pan so you won’t have to fully remove it.
