  1. Nov 8, 2024 at 3:13 PM
    #7651
    snogirl
    snogirl New Member
    judy
    Vermont
    2024 TRD Sport Premium Crew
    New Snow Tires Cooper Discoverer Snow Claw LT265/60/R20 E
    I'm in Northeastern Vermont. Bring on the Snow!
    Yaboy and RatPanda like this.
  2. Nov 8, 2024 at 3:40 PM
    #7652
    machd08
    machd08 New Member
    CLARENCE
    Sumter, South Carolina
    2025 Land Cruiser/Land Cruiser
    Just added a badge this evening
    RadixRyder and 23MAXBlue like this.
  3. Nov 8, 2024 at 5:46 PM
    #7653
    Savagesawyer
    Savagesawyer New Member
    Beaverton, OR
    I had no idea the newer 1794s had 1794 stamped on the tailgate!
    machd08[QUOTED] likes this.
  4. Nov 8, 2024 at 5:48 PM
    #7654
    thomez
    thomez New Member
    NE Ohio
    Silver ‘24 Tundra Platinum
    I think it's a 1794 limited edition thing
    Yaboy, machd08, Blufin and 1 other person like this.
  5. Nov 8, 2024 at 5:49 PM
    #7655
    Savagesawyer
    Beaverton, OR
    Figured that as well, but just looked. Looks like the 1794 is smaller than yours and in the same location yours says, "Limited edition."
    machd08 likes this.
  6. Nov 8, 2024 at 6:55 PM
    #7656
    egreen91
    egreen91 New Member
    Ethan
    2024 tundra sr5
    3 in Eibach lift on 35s
    Before and after Eibach stage 2 pro truck lift, 20in trd wheels and 35 nittos
    Blackout badges, trd pro grill (thoughts?) and will bed line the steps
  7. Nov 8, 2024 at 7:03 PM
    #7657
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    Definitely grille change, I did mine & it's well worth it, looks much more rugged.
  8. Nov 8, 2024 at 7:10 PM
    #7658
    Foster1
    Foster1 New Member
    2023 TRD Off Road
    Just my opinion, but Off Road Grill > Pro Grill.
    mikev25 likes this.
  9. Nov 9, 2024 at 7:55 AM
    #7659
    vichmr
    vichmr New Member
    Scott
    Suwanee, GA & Highlands, NC
    '25 MGM Platinum TRD OR 6.5 w/ factory lift
    Go Rhino Dominator D6, Diamondback HD
    Wheel/tire mods make a huge difference! Looks awesome. Blackout badges will be a nice touch.
  10. Nov 9, 2024 at 7:59 AM
    #7660
    SoCal_Erik
    SoCal_Erik New Member
    2023 SR5 Sport 4x4, 2016 4Runner
    Looks great! Remove the steps!
  11. Nov 9, 2024 at 8:26 AM
    #7661
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    Agree that it looks great!
    Now that he's lifted it and taller tires maybe they're kinda necessary?
    He did say he's gonna do bed liner on them so they'll be blacked out.
  12. Nov 9, 2024 at 9:07 AM
    #7662
    ColumbiaGorge
    ColumbiaGorge New Member
    Joe
    Columbia Gorge
    24 Limited
    Had a 3 mile downhill where I didn’t have to hit the gas once. Reset the MPG and found out the max it’ll show.
  13. Nov 9, 2024 at 9:42 AM
    #7663
    matth66
    matth66 New Member
    matt
    Nor cal
    2023 Black Tundra Trd Pro
    Did you use any wheel spacers?
  14. Nov 9, 2024 at 9:48 AM
    #7664
    Soflo
    Soflo New Member
    Tom
    Miami, FL
    2022 Tundra TRD off road
    What’s wrong with stock?
    Sisu87TRDOR, Kap1, Yaboy and 10 others like this.
  15. Nov 9, 2024 at 10:17 AM
    #7665
    thomez
    thomez New Member
    NE Ohio
    5k mile service + oil change today
    Tundrastruck91, Raven67 and VCheng like this.
  16. Nov 9, 2024 at 12:09 PM
    #7666
    VCheng
    VCheng New Member
    Upstate NY
    Factory installed self-destruct device :D
    So did I.
    thomez[QUOTED] and Raven67 like this.
  17. Nov 9, 2024 at 12:36 PM
    #7667
    Timmy23
    Timmy23 New Member
    OR
    25 1794 MGM Tundra
    None
    Did the same yesterday. Great fit and easy to install. Hope they come out with some front ones soon.
  18. Nov 9, 2024 at 1:03 PM
    #7668
    vichmr
    vichmr New Member
    Scott
    But then you don’t get to see that fine TRD suspension.:)
    EDITED: Oh, thought those were the fronts. My bad. ;)
  19. Nov 9, 2024 at 2:05 PM
    #7669
    thomez
    thomez New Member
    NE Ohio
    I can’t decide if the wheel well liners would be better or worse when it comes to wintry slush and salt. Might keep it away from things, might also make it harder to get rid of.
    Tundrastruck91 and Soflo like this.
  20. Nov 9, 2024 at 2:14 PM
    #7670
    Zudrick
    Zudrick New Member
    2024 Tundra Lunar Rock Limited
    None….so far
    What a odd thing to do……here is mine
  21. Nov 9, 2024 at 2:17 PM
    #7671
    Zudrick
    Zudrick New Member
    None….so far
    Went to put on a Toyota bed cover and found the Q/C is not what it use to be. The mounts were not correctly drilled on one side and the clip came broken. So it’s on while I wait for a replacement from Toyota.
  22. Nov 9, 2024 at 7:51 PM
    #7672
    aaen
    aaen New Member
    Parts unknown aka Northern AB
    Installed the Toyota hood deflector yesterday and had the comfort plus system installed, aka Toyota branded defa. Kit includes, block heater, trickle charger and an incab 1000w heater. Tested it out the last couple nights wow, it’s nice to wake up get in the truck and not have to idle the truck for 20-30mins. Luxury expense I know, but. Not having to idle the truck on those -30celsius mornings is going to be amazing , plus it’s significantly cheaper to run then idling. Pays for itself if I recall from my math in 2 years.
    vichmr and Tundrastruck91 like this.
  23. Nov 9, 2024 at 9:26 PM
    #7673
    egreen91
    egreen91 New Member
    Ethan
    2024 tundra sr5
    No spacers!
  24. Nov 10, 2024 at 4:39 AM
    #7674
    Ipaddick
    Ipaddick New Member
    Canada
    Platinum hybrid w/advanced package
    Do they replace the oem ones go in top?
  25. Nov 10, 2024 at 7:03 AM
    #7675
    Soflo
    Soflo New Member
    Tom
    Miami, FL
    No, yo remove the two clips on top i fits over the small liner. Then you put two new clips back on top, a two 10 mm bolts, one fryont and rear. There are already grommets for the screws. It’s almost like if Toyota knew there would be aftermarket parts and prepped for them. image.jpg image.jpg image.jpg
  26. Nov 10, 2024 at 8:07 AM
    #7676
    Timmy23
    Timmy23 New Member
    OR
    25 1794 MGM Tundra
    None
    Most time consuming part of the job was getting the white sticky platic of the plastic bag holding the parts and install instructions off the inside of one of the liners. Otherwise it is a 10 minute installation.
    Soflo likes this.
  27. Nov 10, 2024 at 2:04 PM
    #7677
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Had NH Oil Undercoating done a couple months ago and will do yearly so not too worried. The cost of these trucks makes this a must do for those in snow country/rust belt.
    Ausfahrt, RatPanda and thomez[QUOTED] like this.
  28. Nov 10, 2024 at 2:57 PM
    #7678
    thomez
    thomez New Member
    NE Ohio
    I have an appointment for flluid film in a couple weeks
    I just mean that the liners may 'trap' things into spots where they are harder to spray away. Or they may not do that at all. I'm not sure.
  29. Nov 10, 2024 at 5:52 PM
    #7679
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Today I was busy:
    Took my RCI skid plate set off
    Took my custom made longer (To reach into the bed) SS running boards off
    Took my bedrug off
    Took my Diamondback cover off
    Took my Uptop and truck tent rack off
    Took my Diode Dynamics SS18 Light bar and SS6 Yellow fogs off
    Took my TRD Pro Flares off
    Took my Heritage Grille off
    I did put my TRD grille back on and my old fog lights.
    I ran out of daylight so tomorrow the old flares go back on.
    I will take my Blackvue dashcam out as well.
    And give it a clean up.
    I am debating taking the wheels and tires off and putting on some TRD 18" wheels with the crappy Michelins. I would have to go out and find a set and buy them. It is probably worth it as the ones on the Tundra are pretty nice wheels with Toyo tires.
    Putting it back to stock in case anyone was wondering.
    I am looking for some of the 18" wheels with the Michelin tires now to really make it stock! I gave my Michelin tires to my nephew and sold the rims for next to nothing!
  30. Nov 10, 2024 at 6:04 PM
    #7680
    earlwright239
    earlwright239 New Member
    2022 Army Green Tundra SR5 TRD Sport
    PBNB
    I'll bite. And why are you going back to stock?
