Transmission dipstick
Discussion in '1st Gen Tundras (2000-2006)' started by joeymoran, May 18, 2024.
  1. May 18, 2024 at 4:20 AM
    joeymoran
    joeymoran [OP] New Member
    2000 tundra sr5
    Greetings, has anyone had a transmission dipstick break off in the tube? All metal - the bottom 2-3 inches broke off in the tube somewhere, at the top, middle or bottom, not exactly sure where. Good Times... Any suggestions as to how to proceed?
  2. May 18, 2024 at 5:27 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    The dipstick tube comes apart, so you may luck out and be able to grab it that way. If not, I suspect you'll be dropping the pan.
  3. May 18, 2024 at 5:28 AM
    Both the tube and the pan can be removed. Those are your only options I think. I would start with the tube and see if it's blocked. Maybe you'll get lucky and be able pull it out. If not, drop the pan, find the broken end and then replace the transmission filter while you're in there. You'll need a new FIPG from Toyota .
  4. May 18, 2024 at 5:32 AM
    bfunke
    bfunke Tundra Curmudgeon
  5. May 18, 2024 at 6:12 AM
    What is that?
  6. May 18, 2024 at 6:15 AM
    bfunke
    Flexible grabber tool
  7. May 18, 2024 at 8:15 AM
    Kinky.
  8. May 22, 2024 at 9:57 PM
    qdjohn
    qdjohn New Member
    2003 AC SR5 V8
    Not to thread jack but I hate the transmission dipstick. I feel like I have to take it out and put in like 5 times before I can get a good read on it.
    JasonC. and joeymoran[OP] like this.
  9. May 22, 2024 at 10:05 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    At least you have one..:eek2:
    Count your blessings..:cool:
    bmf4069, 2mchfun and qdjohn[QUOTED] like this.
  10. May 22, 2024 at 10:06 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level Lift, DIY SAIS preventer, headers.
    Imagine… performing a complicated gear shift pattern then waiting for a special blinking light pattern to appear and then hurriedly climbing under the truck and removing the tranny plug, then waiting a very short time for the infamous “trickle” before reinstalling the plug, so you can pop back up to the cab and make sure the light didn’t change… just to check the fluid level.
    You would instantly fall in love with your dipstick.
  11. May 23, 2024 at 6:50 AM
    What @1lowlife said.
    2mchfun, 1lowlife and qdjohn[QUOTED] like this.
  12. May 23, 2024 at 8:11 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    These guys get it. No dipstick blows
    2mchfun, 1lowlife[QUOTED] and qdjohn like this.
  13. May 23, 2024 at 5:21 PM
    How so? It only takes me two. One to wipe it off and the other to get the read. Either front or back depending upon how the wind blows.
    Try not to rotate the dipstick when you re-insert it.
  14. May 23, 2024 at 6:31 PM
    qdjohn
    qdjohn New Member
    2003 AC SR5 V8
    Must be user error. My dipstick (which I am now grateful for) is pretty finnicky when I slide it back in
    Dalandshark likes this.
  15. May 23, 2024 at 6:34 PM
    It is finicky. Once you play around with it, you’ll find the optimal angle to re-insert it without twisting.
    bmf4069 and qdjohn[QUOTED] like this.
  16. May 23, 2024 at 8:34 PM
    FishNinja
    Lee
    06DC2wd
    Grizzld, bmf4069 and qdjohn like this.
  17. Nov 10, 2024 at 4:52 AM
    Grizzld
    Grizzld New Member
    '05 2wd DC Tundra, '07 2wd Sequoia
    Don't play around with it for too long or you may not be able to reinsert.
    :laser:
  18. Nov 10, 2024 at 6:06 AM
    What did you do? lol
  19. Nov 10, 2024 at 6:08 AM
    I can’t stand that New Kid on the Block has been. My BIL’s younger sis went out with his older brother Donnie. Another Dot Rat.
