Don't change the oil every year?
Discussion in '2nd Gen Tundras (2007-2013)' started by PhotoNerd, Nov 6, 2024.
  1. Nov 6, 2024 at 5:13 AM
    PhotoNerd
    PhotoNerd [OP] New Member
    Tony
    Waterford, CT
    My 2008, with about 95k miles, only gets one or two thousand miles a year. I'm using Valvoline synthetic oil.
    It's been about a year since my last oil/filter change, but I read this:
    https://www.thedrive.com/news/motor-oil-age-doesnt-matter-as-much-as-mileage-study
    An oil change is easy, but I'd rather not be wasteful for both money and the environment.
    What do you think? If the oil is okay, should I still swap the filter out?
  2. Nov 6, 2024 at 5:44 AM
    The thing about an oil change, aside from refreshing the lubrication system in the truck, is the up close and intimate inspection time you get to spend with your truck. I honestly don't think the time makes as much of a difference as the mileage and the conditions you drove in, but would still probably do an annual oil change myself. If you choose not to, just don't skip the thorough inspection you would normally do for the oil change and risk missing other maintenance needs the truck may have.
    FrenchToasty and PhotoNerd[OP] like this.
  3. Nov 6, 2024 at 5:54 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    If the truck (and oil) is routinely brought up to temperature by a long drive, the two year interval is probably ok. If most of your annual mileage is short trips, then one year is reasonable.
    Fortunately, the engines in these trucks are port fuel injected and not known for fuel dilution.
  4. Nov 6, 2024 at 8:30 PM
    Rathesun
    Rathesun New Member
    Alaska
    2013 Tundra Double-cab 5.7L engine
    All depends on driving conditions. For example, while I don't drive my 2013 Tundra over 2,000 miles per year, I still replace the oil and filter every six months, regardless of miles driven. The reasons for this is because winters are long and cold in the interior of Alaska, and during the winter long idling times are the norm. During a cold engine start the ECU commands a high idle RPM plus a greater amount of fuel to reach the cylinders (much like pressing the gas pedal right after starting the engine). When very cold outside there is a possibility for some of the gasoline to eventually mix with or contaminate the oil. If I well remember, this condition is called "cylinder wash," which is when some of the gasoline washes-off some of the oil from the cylinder walls. Now, what I am telling about relates to a possibility where I live at (extremely cold temperatures). So I replace the oil and filter just before winter, and before summer the following year (2 times per year). I assume that one can get away replacing the oil 2 times per year, and the filter 1 time (perhaps before summer?). But since OM filters are so cheap, I replace it with each oil change.
    I would do the same if off-road or dusty driving, towing, and so on.
    PhotoNerd[QUOTED][OP] likes this.
  5. Nov 6, 2024 at 9:03 PM
    This is how I see it:
    - Who is paying for repairs or engine replacements? The end user.
    - I remember an episode of The Car Care Nut when he was replacing a 4 cylinder Camry motor due to excessive oil use. They did 10k mile oil changes and even tested the oil. Tests were good but something was still causing the cylinder walls to go oval and have failures.
    - An oil change is pretty cheap insurance.
  6. Nov 9, 2024 at 5:13 PM
    tmac58star
    tmac58star New Member
    Black 1st generation Tundra SR5 Access Cab
    Every 5K to 6K for me, 07 SR5 crewcab 4.7L auto tranny with 125K on the clock. Bob's yer uncle!
  7. Nov 9, 2024 at 5:50 PM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    My 08 has been sitting alot since I converted to full time working from home. I do 1x year oil changes in the fall. This year I just hit 4k miles. Last year was under 3k.
    It's an excuse for me to crawl under and inspect the truck before MN snow storms hit.
  8. Nov 9, 2024 at 5:55 PM
    Blue Thunder
    Washington
    Honestly, you'll have to decide what "experts" to believe. Oil and oil filters are where I nerd out on Youtube. I won't claim to be an expert, but I do recommend following this guy: https://www.youtube.com/@themotoroilgeek
    Generally speaking, everything I've seen on YT suggests 1 year is the absolute maximum. Not only because of moisture, but because oil turns corrosive (not sure that's the right technical term; I'm drinking...) with use.
    So you do you...as much as I hate the "oil is cheap; engines are expensive" argument the more I read about oil, filters and oil life the more I agree. Treat your Tundra right and it will return the favor.
    And for the love of God, always change the filter with the oil. It's fricken cheap. Don't mix old oil with new oil if you can prevent it.
