1st Gen camper shell buying info
Discussion in 'Tonneau Covers, Caps and Shells' started by shifty`, Mar 26, 2021.
  1. Nov 4, 2024 at 8:53 AM
    #1861
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    I just checked mine as well. ARE MX mid high rise topper 38lb struts.
    window stays open if I'm hauling anything long. Wind will push it down to level with the topper, but it won't close. Even if I'm on the freeway it doesn't close.
    455h0le_dachshund and KNABORES like this.
  2. Nov 4, 2024 at 9:59 AM
    #1862
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Mine are 45lb.
    Tlar25 and OldGuy03 like this.
  3. Nov 4, 2024 at 10:00 AM
    #1863
    You got the bigger hatch
    Sirfive[QUOTED] and OldGuy03 like this.
  4. Nov 4, 2024 at 11:19 AM
    #1864
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Made me curious so I looked mine up, same here 45lb on hi-rise cap
    OldGuy03 and Sirfive[QUOTED] like this.
  5. Nov 4, 2024 at 7:36 PM
    #1865
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Any of y'all carpet your inside of cap yourself? Or any other variation of lining the inside of the cap?
  6. Nov 4, 2024 at 7:44 PM
    #1866
    shifty` [OP] You can call 1 (800) PP5-1-DooDoo
    PO did mine. Great job on the roof. Piss poor job on the side walls. Same method required for headliner. 3M Super 77 or my fave 08090 Super Yellow. You’ll start from center, spray a strip of the carpet, and a matching strip of the cap roof. Let set for 10min. Install the two sprayed sides together and rub center out to bond. Fold one half over, spray your next section and the cap where it’ll bond, let flash 10min, work center outward, stretching a tiny bit as you go. Obviously it’d be easier to do this with the cap off and upside down on a moving blanket so you can work with gravity in your favor.
  7. Nov 4, 2024 at 8:04 PM
    #1867
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    What is yours lined with? Carpet? Is it like the carpet used on sub boxes?
  8. Nov 5, 2024 at 4:18 AM
    #1868
    NickB_01TRD
    KY
    What is there to gain from having carpet lining on the cap? Mine doesn't have any but other than looks what good would it do me?
  9. Nov 5, 2024 at 4:55 AM
    #1869
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I imagine it would help insulate and sound deaden some.
    OldGuy03 and NickB_01TRD[QUOTED] like this.
  10. Nov 5, 2024 at 5:00 AM
    #1870
    You also wouldn’t accidentally rake your bald head across the scratchy ass raw fiberglass and have somewhere to stick cool Velcro patches.
    Tlar25, shifty`[OP], OldGuy03 and 4 others like this.
  11. Nov 5, 2024 at 5:33 AM
    #1871
    SharkDog
    SharkDog New Member
    Denver
    2006 Gray DC Tundra SR5
    Dobinson Twin Tubes. Stock.
    If you sleep back there, it helps hold the condensation, so it doesn’t drip on your, previously mentioned, bald head.
    Double DC, Tlar25, OldGuy03 and 4 others like this.
  12. Nov 5, 2024 at 5:51 AM
    #1872
    NickB_01TRD
    KY
    All good points, I suppose it could be good if you were using it to sleep in quite a bit.
    shifty`[OP] and OldGuy03 like this.
  13. Nov 5, 2024 at 5:57 AM
    #1873
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I use 39s on my 100R. Struts will be pretty universal, measure your compressed length and the extended length and find something with the same specs. Don't use a longer compressed length than what is currently installed.
    Condensation, as previously mentioned.
    You can also stick a velcro cargo net on the ceiling. Handy for storing things like towels up there. I also stick a water bottle in one while I'm sleeping back there.
    https://www.amazon.com/gp/product/B071K8KZZC?ie=UTF8
    Tlar25, shifty`[OP], OldGuy03 and 3 others like this.
  14. Nov 5, 2024 at 7:41 AM
    #1874
    I mean, that's a tricky question. Because I typically used higher-nap carpet on speaker boxes that's more akin to your cab floor carpet. What's on my camper shell ceiling is more akin to what you'll find in bass boats. Maybe the're the same? I dunno. Search for "underfelt" carpet, it's low-pile.
  15. Nov 5, 2024 at 8:08 AM
    #1875
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    I've never installed carpet on one but it is definitely low-pile. A search on Amazon produces underfelt carpet as an option as you mention. Looking at leers website they claim their carpet is a nylon product, likely similar to what bedrug is made up of. I think they many be a polypropylene base product through IIRC.
    https://www.amazon.com/Halero-Under...d=13731537914112247791-B0CPL2P5MV-&hvexpln=73
    insulation and condensation collection. Even if you aren't sleeping back there the carpet will help keep your bed space cooler on hot summer days. I guess it depends on what you're storing there and your overall use if that matters to you though.
  16. Nov 7, 2024 at 6:46 AM
    #1876
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
  17. Nov 7, 2024 at 6:55 AM
    #1877
    Bonus: They're a member here.
    OldGuy03 likes this.
  18. Nov 9, 2024 at 6:33 PM
    #1878
    Dook55
    Dook55 RCLB Guy
    Montana
  19. Nov 14, 2024 at 1:16 PM
    #1879
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Can anybody give me a rough estimate of how far I should gap the cab and cap?
  20. Nov 14, 2024 at 1:18 PM
    #1880
    2-3 fingers depending on your sausages
  21. Nov 14, 2024 at 1:18 PM
    #1881
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    I can just about fit 2 fingers. But i like it tight, until it rattles rearward.
    3 fingers at the notch for the 3rd brake light.
  22. Nov 14, 2024 at 1:23 PM
    #1882
    NickB_01TRD
    KY
    Should check how well the glass lines up with the tailgate and it's latches as well I would think.
  23. Nov 14, 2024 at 1:28 PM
    #1883
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    That's my main concern. Probably going to try that ratchet strap idea too
  24. Nov 14, 2024 at 1:29 PM
    #1884
    NickB_01TRD
    KY
    I used two clamps in the back of mine after that but it hasn't moved a bit in two years
  25. Nov 14, 2024 at 1:39 PM
    #1885
    With my Leer, there's a very clear body line it follows, all you need to do is line it up. It’s possible other manufactures weren’t as design-oriented as Leer was though. I’ve been nothing but overjoyed with the fermenting the neeer Leer 100 series shells on our 1st gen trucks…
  26. Nov 14, 2024 at 1:47 PM
    #1886
    Dook55
    Dook55 RCLB Guy
    Montana
    Yes, this is the limiting factor, there is no room to go back or forward, the tailgate decides for you.
    One other point to take into consideration... it's not unusual for tailgates to get bowed a little from loading heavy objects. When that happens it's a real pain to lock rear windows that only have one handle in the middle. It takes two people because you have to bow the glass a little to make it fit. In such a case you could just mount the topper a little farther back.
  27. Nov 14, 2024 at 1:49 PM
    #1887
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I've got 8 clamps at my disposal. Figure I'll use 6.
  28. Nov 14, 2024 at 1:50 PM
    #1888
    NickB_01TRD
    KY
    Mine is single handle and I usually have to give one side a push when latching but not very hard so I just leave it be.
  29. Nov 14, 2024 at 1:54 PM
    #1889
    I should add to this: The fitment you see, I have approximately one fingertip's separation at the back/corner/sides of the cap, and it lines up perfect with the body line.
    So I guess I'd say proper fitment is having about a pencil with to a finger width at the rear corner.
  30. Nov 14, 2024 at 1:58 PM
    #1890
    My fitment. This one (ARE Impulse) sits on top of the rail, does not overlap.
    Could probably go a smidge forward, but the hatch is already touching the tailgate in the middle.
