Underside wash/rust preventative?
Discussion in 'Detailing' started by J-H, Nov 4, 2024.
  1. Nov 4, 2024 at 1:56 PM
    J-H
    J-H [OP] New Member
    2005 Tundra Access cab V6
    I got a new (to me) 2005 Tundra, 180k miles, on Saturday. From what I can tell, it's been kept in a garage the whole time, and is allegedly always a Texas truck. It's very clean overall, and is an upgrade (although I'm having to get used to the smaller windshield and eye-level rear view mirror creating a blind spot).
    The frame is pretty well rust free and looks very clean and solid, but a lot of the bolts and other parts on the underside look like they have exterior rust. There's minor surface rust on the drive shaft but it looks OK for a 19 year old part to me. The exhaust system is the worst part, but I think that's typical.
    The frame is pretty clean, so I'm assuming it benefited from the recall I've seen mentioned online.
    I am also not sure this is rust, because - see picture one below - even the rubber on the spare tire is reddish! Maybe some parts are attracting dust/gunk more than others?
    What's the best way to get this cleaned up and protected?
  2. Nov 10, 2024 at 6:27 PM
    Maverick345
    Maverick345 New Member
    2024 SR5
    If it were me I would spray the undercarriage down really good with a power washer to remove any lose dirt and get a couple of can of rust converter and call it a day.
  3. Nov 10, 2024 at 8:01 PM
    Randydw
    Randydw New Member
    Randy
    Ozark,mo
    2021 platinum crew cab
    I had an 04 tundra that I traded in three years ago here in Missouri, which I’m sure we get more snow and ice than Texas. and my undercarriage looked much better than yours. Are u near the coast?
  4. Nov 10, 2024 at 9:07 PM
    Runway
    Runway New Member
    Kenneth
    Houston, Texas
    2016 White Tundra 1794
    Spending a lot of time at the beach can cause some of that. The response above from Maverick345 is a good one.
  5. Nov 12, 2024 at 10:42 AM
    J-H
    J-H [OP] New Member
    Supposedly the truck belong to an older gentleman up until 2020, and he lived not far from here (E. TX, humid). So far everything else the seller said has been accurate. It's always possible that the older gentleman had a second house on the beach or up north where they put salt on the roads. No way to know!
    Are all rust converter sprays about the same?
  6. Nov 12, 2024 at 11:58 AM
    Tundra Dude 45
    Tundra Dude 45 New Member
    Eric
    2019 SR 4.6L DC 4X4
    8” BAMuffler, TRD airflow accelerator, front window tint/windshield sun stripe, debadged tailgate 4x4 emblem, trimmed mud flaps, antenna removed stainless screw added, TRD rear sway bar, AFE high flow air filter.
    I use Fluid Film or PB Blaster Surface Shield. Been thru 5 northeast Ohio winters and still looks good. Been using since new when purchased. Laserwash weekly.
    dondino likes this.
