  1. Nov 4, 2024 at 7:24 AM
    Reddawg1100
    Reddawg1100 New Member
    FL
    21 SR5 Midnight Black DC, AKA: Bat Truck
    Custom rims, front leveling spacers
    Changed the oil for the second time since I bought the truck used a little over a year ago. Used Penzoil Ultimate 0-20 and OEM filter. The filter looked pretty good (~4k OCI). Looked it up and I’ve put about 8K miles on it over the past 15 months (I work from home). I swapped out the PCV valve as well.
    Also did a drain and fill on the transmission. The truck has 96K and while it has a great dealer documented service history from the previous owner, it’s not clear the last time it was done. Looking at the used fluid, it’s been a while. Though It was still ‘red’ and didn’t smell burnt, it was time. I used Valveoline Maxlife. Next is the coolant, diff fluid and spark plugs.
  2. Nov 4, 2024 at 8:02 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    I noticed that with his as well that the manual pump is basically useless and using compressed air isn't very fast IMO. To be honest, I haven't tried using the manual pump on mine but with compressed air it worked great. All the same attachments. It is a little more expensive but not by much. So far I've been happy with it.
  3. Nov 4, 2024 at 8:18 AM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Eibach Pro 2R, Dirt King UCA, 285/70/18 Toyo ATIII, Stillen TruPower CAI, OTT
    Thanks! :thumbsup:
    I'm gonna return the one I have today and give the one you have a try n see if it works better.
  4. Nov 4, 2024 at 9:01 AM
    15SR5CM
    15SR5CM New Member
    Roseville, CA
    2015 SR5
    Bilstein 6112/5160 3/1 w/CB shackles Ironman front bumper, 18+SR5 Honeycomb grill
    I def want to know what you find out!
  5. Nov 4, 2024 at 10:03 AM
    Long Duck Dink
    Long Duck Dink Nope
    North Salt Lake, UT
    2019 Super White 1794 Edition Tundra CrewMax 4x4
    3/2" Readylift, TRD Dual Exhaust, TRD Sway Bar, Line-X Bedliner, ArmorFlex Tonneau, ESP 3 bin storage, Amp Power-Steps, Driver Side Grab Handle, Ronin Antenna, Window Tint, ClearBra. Coming Soon: 20" Method MR305NV. BF Goodrich KO2 275/60/20
    @brevard828 I have a similar setup to what you used to have. I have the standard leafs and a (supposed 2") block in the back. I'm kind of thinking about replacing those leafs and the 2" block with just a set of new leafs like what you got. Can you point me to those links you bought and it sounds like I may need a higher lift in back since you had a 1" block.
  6. Nov 4, 2024 at 10:11 AM
    brevard828
    brevard828 New Member
    2021 Limited TRD Off Road
    Here all that i ordered just for the rear. Ive also got the full IMS for the rest of it. The leafs i got are the meduim ones 2.1" lift. however they have a heavy dutu 900lb spring and the standard 0-300 lb spring. All are 2.1" lift. Their customer service is amazing and it ships out of florida very quickly. @crikeymike is a retailer as well and is super knowledgeable and on the forums a bunch. his site actually had them cheaper
    https://dobinsonusa.com/products/do...air-for-toyota-tundra-2007-to-2019-l59-121-r/
  7. Nov 4, 2024 at 1:22 PM
    SDiegoTT
    SDiegoTT New Member
    San Diego
    2021 Tundra Platinum Silver 4x4 CC
    Stock for now
    A lot of people are running 295/70/18 with a similar lift though I can't say whether they do so without trimming, extra shims, higher setting on the 6112 etc.
    ...but I considered going up to 285/75/18 which would have been slightly taller and I think that would have been fine with my same set up.
    Whether your set up would run with different tire sizes would also depend on your wheel offset.
    redrum448[QUOTED] and BR73 like this.
  8. Nov 4, 2024 at 1:57 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI
    I'm running 295/70R 18's with 6112's on the 3rd setting and wheel spacers to keep them off the UCA
    redrum448 and SDiegoTT[QUOTED] like this.
  9. Nov 4, 2024 at 8:08 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I did a drain and fill of the coolant. First coolant change at 87k miles. Noticed a few weeks ago my overflow tank was pretty low so instead of filling it up, decided to just change the fluid. In the process, noticed my driver side shock is leaking. I was planning on doing 5100’s when my shocks went bad but I wasn’t expecting this early.
  10. Nov 4, 2024 at 8:36 PM
    Qbert
    Qbert New Member
    Suspension installed. Dirt king arms, king 2.5s all around, method 315 17*8.5, BFG KO2, 35*12.5*17. had the shop that installed do the BMC but not happy with looks of it and outcome as tires rub at full lock. Going to take it to another shop and see what they say.
    68 RS/SS, Mullen, C.I. and 12 others like this.
  11. Nov 5, 2024 at 2:39 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    Like those wheels. Hopefully you can get the tires squared away.
  12. Nov 5, 2024 at 3:21 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    You're welcome, hopefully you have a similar experience as I have
  13. Nov 5, 2024 at 5:45 AM
    mverkaik
    mverkaik New Member
    Hamilton, MI
    2021 TRD PRO CrewMax
    WeatherTech Floorliners Toyota Running Boards Reflex Liner Truxedo X15 Pro cover.
    You know that we have come a long way in automotive reliability when it is a surprise that the shocks on a 6,000 pound truck run nearly 90,000 miles an we comment on "how early" they are failing!
    In my lifetime it was frowned upon to buy a car with 90,000 miles on it because it was nearly used up!
  14. Nov 5, 2024 at 6:31 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Yeah it's definitely crazy how technology has advanced.
  15. Nov 5, 2024 at 10:17 AM
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    I finally drove the truck today to try the super bump stops out. I took it where I hunt at. I drove up a forest road, maybe a good 1/2 mile, faster than I normally do to see how they perform on the dips and bumps. It did ride smoother/ softer over the terrain. I think it was a good mod. Pic is part of the forest road. Update; I had to check to see if it’s a 1/2 mile. On the way out I put the trip on. It’s.8 of a mile from parking area on the gamelands to the highway. And I drove slow on the way out. I could still feel a difference for the better.
  16. Nov 5, 2024 at 5:42 PM
    AthenaOffroad
    AthenaOffroad YouTube wannabe
    Niko
    2014 Blue Ribbon Metallic Tundra DC SR5
    Bought a set of wheels. Got some curb rash and scratches but i plan on sanding them and painting them satin black. whole set was $150 I believe they came off the xsp edition tundra back in 2011
  17. Nov 5, 2024 at 6:16 PM
    How bad did they butcher it?
  18. Nov 5, 2024 at 9:20 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Dig those wheels! :thumbsup:
    AthenaOffroad[QUOTED] likes this.
  19. Nov 6, 2024 at 6:04 AM
    AthenaOffroad
    Niko
    Thanks!
    BlueRibbon4x4[QUOTED] likes this.
  20. Nov 6, 2024 at 1:22 PM
    Ebrperk
    Ebrperk Old member
    South Central Kansas
    2018 1794 MGM
    Tinted windows, go rhino D6 side steps and shorty antenna, Bilstein 5100's rears, 6112's fonts set to 2.5" Rocktrix RT111 18x9 -12offset NItto Terra Grapplers G3's 275/70 R18's. Amp from James @ Tech12volts FRAC Harness
    I added the tiedowns a couple of months ago, they prove invaluable for securing small loads like a couple of 2X's
    bulldog93[QUOTED] likes this.
  21. Nov 6, 2024 at 3:14 PM
    Dave8699
    Dave8699 Trackrat
    NJ
    04 Tundra AC, 2014 Tundra 1794 Crew Max
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    Just a little red bar
  22. Nov 6, 2024 at 3:20 PM
    JrJrOffroad
    JrJrOffroad Somewhere in the west
    Anthony
    Monument, CO // Cave Creek, AZ
    Did my t case fluid change. Meant to do this with the diffs last month but wanted to get new drain/fill plugs. Messy but the holes in the RCI skid made it easy to do without moving the skid. Cleaned up easy after it was done IMG_4812.jpg
    New plugs with the white goop sealant on them from Toyota is part # 36136-0C010 and you need two of them :)
    you could reuse the old ones I suppose but I wanted clean threads
  23. Nov 6, 2024 at 3:38 PM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Love some pre-trip maintenance
    JrJrOffroad[QUOTED] likes this.
  24. Nov 6, 2024 at 3:51 PM
    Not my truck but low mileage still for being almost paid off.
  25. Nov 6, 2024 at 4:33 PM
    Beckusmc
    Beckusmc New Member
    Black Tundra Platinum
    Hello Everyone,
    I have a 2021 Tundra Platinum crew max and was wondering if anyone has the correct part numbers for the drivers side front pillar and handle. I am not sure what year will work so was hoping someone out there had this information.
    Thank You,
    BR73 likes this.
  26. Nov 6, 2024 at 4:34 PM
    It's a whole kit and it fits the 07-21.
  27. Nov 6, 2024 at 4:37 PM
    koditten
    Kirk
    Midland of the Mitten
    What color?
    I just got one delivered from Sparks Toyota for my '21 limited. They bent me over for $130.
    Mine was grey.
    HulkSmurf14 and BR73 like this.
  28. Nov 6, 2024 at 4:39 PM
    Beckusmc
    Beckusmc New Member
    I am looking for the light gray color
    koditten likes this.
  29. Nov 6, 2024 at 4:45 PM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    Changed the oil and filter and antifreeze. Then had it sprayed with fluid film.
    The salt is coming.
  30. Nov 6, 2024 at 4:50 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    I believe there is a thread on here all about the L/S grab handle mod that has what you need.Driver's side grab handle update is the thread
