Top Hat for 6112 on 2021 Platinum
Discussion in 'Suspension' started by Hedley, Nov 3, 2024.
  1. Nov 3, 2024 at 8:28 AM
    Hedley
    Hedley [OP] New Member
    21 Platinum
    Update: the KYB’s arrived and they are - of course - perfect. The Monroe top hats were just not the right part.
    I am putting 6112's on my Tundra. I bought them disassembled, and ordered a generic top hat off Amazon (Monroe Strut-Mate 907923) so I could pre-assemble them and save a little money on installation. I noticed that the bottom side of the top hat has an integrated cylindrical projection that is supposed to fit inside the spring. Otherwise, there is nothing but friction to keep the spring mated to the center of the top hat. The Monroe top hats I ordered are supposedly OEM equivalent, but that center part is much smaller than the ID of the spring. Which means it will not keep the spring centered, but will allow it to move about a half inch in any direction. Is this OK? Do the KYB SM5737 fit inside the springs a little more snugly? I'm trying to find these locally to take the spring in for an actual fit, but they are only available for
    ordering.
  2. Nov 3, 2024 at 9:39 AM
    Isn’t there also a rubber isolator?
  3. Nov 3, 2024 at 10:19 AM
    Hedley
    21 Platinum
    The only thing in the package was what you see plus 4 nuts. The top bushing and washers were with the 6112's.
  4. Nov 3, 2024 at 11:30 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Have you tried looking at the 6112 diagrams?
  5. Nov 3, 2024 at 12:13 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Pretty sure you need the 6112 top hats. They don’t use oem components as it’s a bigger shock and different spring than oem.
  6. Nov 3, 2024 at 12:38 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    memario1214 likes this.
  7. Nov 3, 2024 at 4:10 PM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    You're missing the rubber isolator that avoids metal/metal contact. We don't buy Monroe top hats for the very reason you've found. They don't come with the isolator! The KYB SM5737 will include the necessary top hat as well as an isolator.
    Hedley[OP], RobertD and KNABORES like this.
  8. Nov 4, 2024 at 5:29 AM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    As mentioned above, there should be a rubber isolator.
    KNABORES and Hedley[OP] like this.
