Help with brakes please
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by greentrbo95gst, Nov 3, 2024.
  1. Nov 3, 2024 at 3:59 PM
    greentrbo95gst
    greentrbo95gst [OP] New Member
    Huntington Beach
    Cooked my brake fluid coming down the Cerro Gordo mine trail yesterday and got stuck half way down until dark until things cooled down. I need to uprade rotors, pads, fluid and some ss lines. Please share your sources and experiences. Thanks
  2. Nov 3, 2024 at 4:20 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    So you Were using the transmission to Slow down Along with the Brakes - Right? Won't really work any other way...
    greentrbo95gst[OP] likes this.
  3. Nov 3, 2024 at 4:21 PM
    greentrbo95gst
    Huntington Beach
    Yes, but very careful as my water temp shoots up when I engine brake.
  4. Nov 3, 2024 at 4:28 PM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    If your budget allows for it, jumping up to a Powerbrake kit is a massive upgrade over stock. They also have pad/rotor upgrades that aren't quite as big, but still a solid upgrade over stock.
    :spy: We've got them 15% off for the month of November as well :spy:
  5. Nov 3, 2024 at 4:38 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Alcon kit as you’ve seen on the other thread. Front and rear option which is a significant difference.
  6. Nov 3, 2024 at 5:24 PM
    greentrbo95gst
    Huntington Beach
    Do you have a link? What comes in the kit?
    SS lines? Would prefer Hawk pads with some slotted rotors and high temp fluid
  7. Nov 3, 2024 at 5:25 PM
    greentrbo95gst
    Huntington Beach
    I'm trying to order a four wheel camper project M camper. Not sure if Alcon fits in the budget for now. :monocle:
  8. Nov 3, 2024 at 5:39 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    if you’re having braking issues with your current setup you may want to shift that budget before adding more weight lol
  9. Nov 3, 2024 at 5:51 PM
    greentrbo95gst
    Huntington Beach
    True, but I think there are other options without having to replace the caliper and more budget friendly.
  10. Nov 3, 2024 at 5:56 PM
    SoJersey
    SoJersey New Member
    This. OE replacements will have their limits… they’re a slight upgrade. With all of the added weight of mods rotor size and calipers will be the safest and best choice, just not wallet friendly.
  11. Nov 3, 2024 at 6:08 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    It’s physics. The oem setup is limited by material mass and other factors. An oe setup isn’t the way unfortunately when adding a ton of weight. Sure you can band aid the problem but the problem still there.
  12. Nov 3, 2024 at 6:32 PM
    greentrbo95gst
    Huntington Beach
    Does Alcon kit work with the 17" wheels?
    My drives are mostly slow and steady and I still think high temp fluid with much better pads, vented rotors and SS lines will be a massive improvement over OEM.
  13. Nov 3, 2024 at 6:46 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Yes it does work with 17s I’m running 17s
  14. Nov 3, 2024 at 7:04 PM
    greentrbo95gst
    Huntington Beach
    Nice build man. Sounds like I should do it right the first time.
    Tripleconpanna likes this.
  15. Nov 3, 2024 at 7:12 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Brake fluid should at least be DOT4 instead of the stock Toyota DOT3. Boiling points are higher. A racing DOT4 fluid may even be more beneficial, with the downside that you'll need to replace the fluid yearly. Motul 600, Amsoil Dominator, etc -- lots of choices to get a higher boiling point.
  16. Nov 3, 2024 at 7:15 PM
    greentrbo95gst
    Huntington Beach
    I use motul 600 in my other cars and don't mind replacing it annually. Good call.
  17. Feb 11, 2025 at 6:48 AM
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    2006 Tacoma TRDS 4X4, 2021 Tundra LR TRD Pro
    This is very strange... I've been up Cerro Gordo in my 21 Pro a few times and I always come down in 4 Wheel Low so I can stay off the brakes and never noticed engine temp climbing...
    As @reywcms said...Pads, lines, and rotors are not going to make any difference in braking capacity. Regardless, anyone who is braking the whole way down CG is going to overheat brakes, even with massive upgrades. Our trucks are heavy bitches...
    reywcms likes this.
