When you replace your headlight assemblies,
Discussion in 'Lighting' started by RLHULK, Sep 22, 2017.
  1. Sep 22, 2017 at 4:20 PM
    RLHULK
    RLHULK [OP] Too many gamma rays in all that BBQ smoke.
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    Do you have to adjust the aiming of the lights?
    How do you set the leveling motors?
    Or is everything preset?
  2. Sep 22, 2017 at 10:40 PM
    RLHULK
    Rich
    2022 Silverado LT.
    Yup I saw that thread, IIRC it was referring to retrofits, but if I buy replacement stock tundra headlamp assemblies will I need to aim them or are they preset and just bolt on?
  3. Sep 22, 2017 at 10:46 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    They are probably pretty darn close. You will want to check them. I don't recall exactly how, something like park 25 feet from a wall, brightest intensity light should be measured and equal to the height of headlight bulb on the car, i think slightly higher on passenger side is ok. I'll try find the actual procedure, I want to check mine too. I may aim mine a little higher even if they are correct now, I never get flashed, and a couple times not even with high beams on. I can always ask down with the leveling motors if I need to.
  4. Sep 22, 2017 at 10:48 PM
    RLHULK
    Rich
    2022 Silverado LT.
    That's what I was thinking. Would it only be a vertical adjustment or is there a side to side as well?
  5. Sep 22, 2017 at 10:55 PM
    Pudge
    CT
  6. Sep 22, 2017 at 10:55 PM
    Pudge
    CT
    I looked today and only saw a vertical adjustment screw, it's actually part of the leveling motor.
    My old cars and trucks I could do a side to side adjustment as well, but I can see why they may have some away with that, no way to aim lights dead left into traffic anymore lol
  7. Sep 23, 2017 at 9:43 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    If you swap the level motors you will HAVE to adjust...you should check aim anyway with any new assembly because not all trucks sit the same
    I parked in front of my garage, turned lights on, taped off the top of the beam. Swapped headlights, swapped over motors to my new set. Closed garage door and adjusted to the same height as before.
    NewImprovedRon and Pudge like this.
  8. Oct 4, 2017 at 5:51 PM
    Bogardian
    Bogardian New Member
    Blake
    2017 SR5 CrewMax
    I haven't received my lights yet, but does anyone have the thread on how to add the OEM leveling motors to the Spyder DRL Lights?
