  1. Nov 2, 2024 at 5:45 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Bought this Daytona 12ton bottle jack from Harbor Freight with the 15% weekend sale today to replace the stock one. Fits perfect in the ESP storage bin. Bent the bracket for the stock jack down so I'll be able stick a couple pieces of wood in there. May eventually see about removing that bracket completely and use that small bit of space. The Daytona may even fit in there once removed.
  2. Nov 2, 2024 at 6:15 PM
    Bayou Spartan
    Bayou Spartan New Member
    Black 2019 TRD PRo
    None
    Does anyone have any idea who makes these brackets or frames ?
    WILLINH likes this.
  3. Nov 2, 2024 at 6:16 PM
    Bayou Spartan
    Black 2019 TRD PRo
    None
    I just went to harbor freight and got a floor jack
    I will return and get a bottle jack and swap it out like you did
  4. Nov 2, 2024 at 6:38 PM
    TacomaTRD4x402
    Southern California
    It seems to be a pretty well built bottle jack. I've got the Badland for garage use but I wanted to have something reliable for emergency roadside repair if needed and 12ton is definitely that. A bit of overkill but still better than the stock one IMO.
  5. Nov 2, 2024 at 6:43 PM
    koditten
    Kirk
    Midland of the Mitten
    Yeah, I'm gonna pass on that upgrade. I really don't want Jack oil leaking out onto my floor.
    The mechanical version works just fine.
  6. Nov 2, 2024 at 6:51 PM
    TacomaTRD4x402
    Southern California
    I thought about that too so I was glad that it fit perfectly in the ESP bin which is plastic so if it were to leak, it'd be an easy cleanup :thumbsup:
  7. Nov 2, 2024 at 7:20 PM
    PNW_Husky
    PNW_Husky New Member
    Great Pacific Northwest
    2018 MGM CM Platinum
    What launcher are you using? Nova? Car Launcher Pro? I have been on the fence on these for a few months now. I want to be able to run a split screen with spotify, and Waze. Also, how is the radio? Do you know if it picks up HD stations like our stock units?
  8. Nov 2, 2024 at 7:26 PM
    Dave8699
    Dave8699 Trackrat
    NJ
    04 Tundra AC, 2014 Tundra 1794 Crew Max
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    Im new to launchers but seems like the majority is running Nova prime and that what I got. I run Spotify and waze or YouTube no problem. As for Radio stations it should because it comes with a way to connect oem antenna or you can use the one provided. I don't use the radio so I can't provide feedback on that end.
    bulldog93 and PNW_Husky[QUOTED] like this.
  9. Nov 2, 2024 at 7:34 PM
    PNW_Husky
    Any other issues with other car systems, settings etc. not working?
  10. Nov 2, 2024 at 8:01 PM
    Bayou Spartan
    Black 2019 TRD PRo
    None
    i found this today at homedepot for 16 bucks
  11. Nov 2, 2024 at 8:02 PM
    Bayou Spartan
    Black 2019 TRD PRo
    None
    Has a seal in it too
  12. Nov 2, 2024 at 8:03 PM
    Bayou Spartan
    Black 2019 TRD PRo
    None
    I imagine that it will fit on one side
  13. Nov 2, 2024 at 9:25 PM
    Dave8699
    Dave8699 Trackrat
    NJ
    Nope so far everything works correctly. Only thing that very doesn't count as not working is i wanted to use an OBD scanner to display parameters but can't get it to work correctly.
  14. Nov 2, 2024 at 9:48 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Bannock built
    He’s a member on here too
  15. Nov 3, 2024 at 3:37 AM
    Bayou Spartan
    Black 2019 TRD PRo
    None
    Sometimes I sit and watch tundra builds on YouTube. one day I came across this this build and I wish i had found it sooner I would have ordered them IMMEDIATELY!!
    i LOVE the look of them.. Thanks for letting me know. Have a blessed day..
  16. Nov 3, 2024 at 4:06 AM
    TacomaTRD4x402
    Southern California
    Old.Ski.Bum, bulldog93 and BR73 like this.
  17. Nov 3, 2024 at 6:16 AM
    redrum448
    redrum448 New Member
    Looks great, how much bigger could you have gone? or are there now?
    I have the same setup except 20 inch rims and will be needing tires soon
  18. Nov 3, 2024 at 6:21 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Nice!! I swapped out the OE one with a 6 ton Big Red from Amazon.
  19. Nov 3, 2024 at 6:39 AM
    Those Badland 3 tons are nice. I have 2 of them. One in the garage and one in the truck.
  20. Nov 3, 2024 at 6:52 AM
    RainMan_PNW
    Casey
    Clark County, WA
    I’d personally prefer to not have my fogs aimed to the side that much, but I know that was his intent with the design. They are probably the most solid and best looking mounts for the factory bumper to date.
    bulldog93 likes this.
  21. Nov 3, 2024 at 7:22 AM
    TacomaTRD4x402
    Southern California
    Nice! Do you have it mounted and locked in the bed?
  22. Nov 3, 2024 at 7:23 AM
    Yes. It's locked to the mount and my bed cover locks as well.
  23. Nov 3, 2024 at 2:39 PM
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    I put the Wheelers bump stops on today. Got a before and after picture. And a comparison picture of OE & Wheelers bump stops. I didn’t drive it yet after the install. Tomorrow I will to see/ feel the difference . IMG_6989.jpg
  24. Nov 3, 2024 at 3:41 PM
    GG Tundra NP
    GG Tundra NP New Member
    Installed Air Lift air bags for towing. (Picture is of the single schrader air valve near the tow connector)
    Steve66, RealTruck, ATV25 and 4 others like this.
  25. Nov 3, 2024 at 7:22 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Refinished the White Knuckle sliders today. Raptor liner for the tread plates and matte black for the tubes for easy touch ups.
    Before
  26. Nov 4, 2024 at 3:28 AM
    Northbound Train
    Northbound Train Masshole
    Glenn
    Western MA
    Black 2016 SR5 Double Cab 4x4 5.7
    That’s the hard part! I love my 38 gallon capacity upgrade.
    WFD473 and Steve66 like this.
  27. Nov 4, 2024 at 4:05 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    Does yours have a loud hissing sound when using it with an air compressor? My bosses son has that one and it's loud.
    I have this one...
    https://www.amazon.com/dp/B0C77V5QZ3?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
    it's pretty quiet when using it with an air compressor
  28. Nov 4, 2024 at 5:50 AM
    brevard828
    brevard828 New Member
    2021 Limited TRD Off Road
    Finally completed my IMS lift with the Dobinsons medium leaf pack (L59-121-R). The ride is much better than the 1" block I had previously. The smartcap is 168 lbs and the decked system is apparently 200 empty. I have all of my tools in there so I should be 400-500 lbs constant load. I was nervous about it riding too rough and being too high in the back but i am super happy with how everything turned out. I purchased the bushing kit, greasable pins, and new U-bolts from Dobinsons as well. Had to get new longer carriage bolts for my airbag cradle to fit around these fat leaf packs. RCI Arapaho bumper with the short hoop to go on next. Should be shipping soon!!!
  29. Nov 4, 2024 at 6:05 AM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Do you know what your hub center to fender measurement is on the rear?
  30. Nov 4, 2024 at 6:13 AM
    brevard828
    I can check when i run home for lunch!
    ZPhilip[QUOTED] likes this.
