General Supercharger Thread
  1. Nov 2, 2024 at 8:36 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, solid Offroad engine mounts, DIY Traction Bars, Tuning by snivspeedshop.com
    During the processing if your connection is bad it will take forever or be incomplete and get a augment null message. I got text message but not a call during a write and was ok.
  2. Nov 2, 2024 at 11:52 AM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    im surprised the guy with the rear mounted turbo isnt in here. racing around with zero tune :rofl:
  3. Nov 2, 2024 at 12:09 PM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Various fueling parts i need to get rid of. Just pay shipping, free dallas pickup
    Jego, ARES35, AZTundra and 1 other person like this.
  4. Nov 2, 2024 at 12:32 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Decos are where it's at. Life changing after our remodel and the range on the wireless backbone has saved my neighbor a few times when their service was down.
    e30cabrio[QUOTED] likes this.
  5. Nov 2, 2024 at 12:54 PM
    M3Tundra-JK
    Scott
    2005 GX470
  6. Nov 2, 2024 at 1:29 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    ARES35 and M3Tundra-JK[QUOTED] like this.
  7. Nov 2, 2024 at 3:49 PM
    NatesNightMare
    Pinetop Az
    so this guy on a fb group says tundras in the year/s that had factory SC available have a larger fuel map. but hes saying the non SC models have the larger fuel map as well.
    what he did was a rear mounted turbo and hasnt touched and fueling parts and no tune running 4lbs of boost
  8. Nov 2, 2024 at 3:52 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Larger fuel map with no larger components to accommodate the map. What could go wrong
  9. Nov 2, 2024 at 4:18 PM
    blenton
    blenton New Member
    Doesn’t Harrop offer a no-tune stage 1 setup? Stock injectors and stock tune configuration, but maybe a fuel pump upgrade, pushing up to 6.5psi IIRC. Not saying it’s the right way to do it, but Harrop thinks it’s ok.
    Like @reywcms said - what could go wrong?
  10. Nov 2, 2024 at 4:23 PM
    bflooks
    bflooks New Member
    Metrowest MA
    As a turbo guy previously running 4lbs of boost, I can say the stock pump and injectors could support it (at least up to 5k RPM), but without a tune, I'm curious how many miles he's put on it.
    Knowing the oil analysis of my setup and the recent report from Jesse about how great the plugs looked, I'm just not sure how stock would fair long-term, even at low levels of boost.
    e30cabrio, koditten and reywcms like this.
  11. Nov 2, 2024 at 4:35 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Yeah, it’s a larger fuel pump and also a higher fuel pressure boost referenced FPR. Data logs revealed much to be desired though as I recall.
  12. Nov 2, 2024 at 5:41 PM
    NatesNightMare
    Pinetop Az
    i think hes said he at 500mi already without adding anythung or tuning. basically slapped a turbo on and running. hes even doing wot runs
  13. Nov 2, 2024 at 5:51 PM
    NatesNightMare
    Pinetop Az
    guy also clas he had another tundra that ran a 200 shot NOS all stock running 12s and went through more than 30 bottles with no issues no plug changes for 200k mi
  14. Nov 2, 2024 at 5:53 PM
    bflooks
    bflooks New Member
    Metrowest MA
    It would be interesting to hear the progress. Maybe it's fine and tuning is a waste. I struggle with that concept, but time will tell. I ran conservative, but IIRC, 5k RPM was the cutoff based on IDC being over 85%. Essentially the same as everyone here to get to 11 or less AFR.
    To each their own and another data point in the making. Wish it wasn't a FB location.
  15. Nov 2, 2024 at 6:15 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Logs were crap or would have been if it didn't detonate around 4,000rpm causing me to roll out of it. If you're ok with using the knock sensor to "tune" your timing curves, it was fast :)
    Lean is fast, rich is safe.
  16. Nov 2, 2024 at 6:16 PM
    Silver17
    Eastern PA
    Did he run that with 3 T66 turbos and a Motec system exhaust? Good chance he overnighted the stuff from Japan.
  17. Nov 2, 2024 at 6:34 PM
    blenton
    blenton New Member
    :rofl::rofl::rofl:
  18. Nov 2, 2024 at 6:55 PM
    NatesNightMare
    Pinetop Az
    :rofl::rofl::rofl::rofl: right?!
  19. Nov 2, 2024 at 7:14 PM
    blenton
    blenton New Member
    I bet his name is Hector...
    ARES35, HulkSmurf14, Silver17 and 3 others like this.
  20. Nov 2, 2024 at 8:07 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Thanks a lot. Now I'll be watching that movie tomorrow as a result of this exchange. I'm due for the annual viewing. Pretty darn funny, though!
  21. Nov 2, 2024 at 8:09 PM
    blenton
    blenton New Member
    Wait, what? That was MOVIE? I though it was a documentary... I mean, they're on season 37 or something now, right??
  22. Nov 3, 2024 at 1:06 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Well back in 2013 they ran the rear turbo with 535cc injectors, SC tune with about 4 psi without any issues. I dropped off the forums when that dude was tuning tundras around 2015...I lost contact with several members doing a turbo tune and placement like turbokits who was in Texas. He was probably on to something...I've been trying to power up an old phone with pics in my text msgs with the conversion.
    ARES35, Wynnded and Black@Blue19 like this.
  23. Nov 3, 2024 at 1:19 AM
    j_supra
    Manitoba, Canada
    2008 Tundra Limited
    20x9 Vision brawls, 285/60 Toyo at3s, Bilstein 5100s, Tint, rock warrior grille, all chrome removed. fully paint matched, HID headlights, LED tail lights, LED fog lights, Doug thorley LTH, custom exhaust, AEM filter, TRD intake pipe, Joying HU, hertz components and sub,
    If you end up grabbing that air box, I have the stillen front intake tube I'd like to sell if you're interested.
    Mdl likes this.
  24. Nov 3, 2024 at 4:48 AM
    e30cabrio
    I'll PM you, thanks
  25. Nov 3, 2024 at 9:34 AM
    NatesNightMare
    Pinetop Az
    thw guy im talking about is completely stock, no tune, no aftermarket fueling parts etc except for the turbo
    Mdl[QUOTED] likes this.
  26. Nov 3, 2024 at 12:52 PM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    Put in mi DW 650 injectors and DW FP. Have a problem now. I must have run the thin plastic hose that goes to the bottom of the FP bucket around the fuel level float. Now I have a full tank of gas. Was thinking of putting a hose on the return line from the fuel rail and pump it out that way. I am sure that there has to be a way to make the FP stay on to empty the tank. I believe someone did it here recently but searching through 650+ post isn't easy.
    e30cabrio, Mdl and HulkSmurf14 like this.
  27. Nov 3, 2024 at 12:55 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Wanna drop the tank again and make sure?! That'd make me punchy!
    NatesNightMare and Mdl like this.
  28. Nov 3, 2024 at 1:10 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I believe @ARES35 did it recently. Post 17878
    https://www.tundras.com/threads/general-supercharger-thread.85513/page-596#post-3688141
  29. Nov 3, 2024 at 1:26 PM
    pursuit2550
  30. Nov 3, 2024 at 1:29 PM
    pursuit2550
    Yeah, don't want to but I am sure its in the tank unfortunately. Nothing else was messed with. Hopefully with the FP I can drain as much as possible. I probably had about 5 -7 left in the tank when I did it today. Not fun. :mad:
