DIRTY SEVEN CLUB
Discussion in '2.5 Gen Tundras (2014-2021)' started by matictundra, Feb 18, 2019.
  1. Sep 24, 2024 at 7:49 AM
    #3451
    Totmacher
    Totmacher New Member
    Daniel
    West TN
    mesquite Tundra or blue 4Runner
    Some
    A great truth has been spoken here.
    CaptRussia253 likes this.
  2. Sep 24, 2024 at 8:08 AM
    #3452
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Deaner and eccracer104 like this.
  3. Sep 24, 2024 at 8:08 AM
    #3453
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
  4. Sep 24, 2024 at 8:13 AM
    #3454
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Also…
    Sack up and replace your steering rack bushings when doing 35s or larger…
  5. Sep 24, 2024 at 8:18 AM
    #3455
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    KevinK and reneaux like this.
  6. Sep 24, 2024 at 9:08 AM
    #3456
    Totmacher
    Daniel
    West TN
    Some
    No. No.
    Do not start spiraling me on this path.
  7. Sep 24, 2024 at 9:24 AM
    #3457
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    2020 Tundra Limited on 35's
    Is this something you should do from the start? Or once they wear out?
  8. Sep 24, 2024 at 9:35 AM
    #3458
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Depending on mileage, I'd suggest sooner rather then later...
    Diff comes out...
    rack comes out
    bushings come out
    bushings go in...
    and reverse!
    Enjoy!
  9. Sep 24, 2024 at 9:56 AM
    #3459
    Totmacher
    Daniel
    West TN
    Some
    I thought someone said it was possible to do bushings and not fully remove rack. Just pry and tilt or scoot a little just right...
  10. Sep 24, 2024 at 10:47 AM
    #3460
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    While you can and I attempted for about for about 10 minutes, before I said "F this" and just pulled it all out. 6 hour job with proper tools, extra hands (@TRDFerguson @TundraPHX) and a whole lot of emotional support.
    Deaner, KevinK, TundraPHX and 4 others like this.
  11. Sep 24, 2024 at 11:21 AM
    #3461
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Depending on mileage, I'd almost rather buy a new steering rack and install bushing on the new one.
  12. Sep 24, 2024 at 11:23 AM
    #3462
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Not a bad idea and I had this thought as well.
    CaptRussia253[QUOTED] likes this.
  13. Sep 24, 2024 at 11:30 AM
    #3463
    reneaux
    reneaux I've been around
    2017 SR5 CM 4x4
    I've done it this way and it is a massive PITA. Both knuckles were bloody by the time I was finished and my beers kept getting warm from neglect.
  14. Oct 1, 2024 at 12:39 PM
    #3464
    TheCompensator
    TheCompensator New Member
    Looking to throw some 37s on my SR5 TSS offroad. This is the lift I am looking at and the bumper to help with that front clearance. Will also be getting +25offset wheels and a BMC. I've already got fenders on the truck. Will this be enough? From what I've seen on plenty of forums from yall this should be but I want to make sure before I pull the trigger.
    BDS Suspension ⚡ (bds-suspension.com) (3" lift)
    Toyota Tundra Baja CBI Front Bumper (2014-2021) — Tundra Lifestyle
    and these are the wheels for those interested
    ICON Alloys Tundra Thrust Satin Black 5-Lug Wheel; 17x8.5; 25mm Offset 2817855557SB (14-21 Tundra) - Free Shipping (extremeterrain.com)
  15. Oct 3, 2024 at 9:22 PM
    #3465
    KevinK
    Back in Arizona. Again.
    Tundras to Sedona
    Im not sure those Fox 2.0 coilovers are gonna handle the weight of that huge bumper.
    How do you plan on using the truck offroad? Gravel side roads? Lots of washboard? Slow and technical trails? Fast and bumpy? What part of the country do you live in and what kind of trails are there?
    I’d consider getting 2.5” coilovers and skip the UCAs if budget is important. You can always add UCA later if you want, but I think a 2.0 and huge bumper may be disappointing if you’re looking for off road handling.
  16. Oct 6, 2024 at 8:30 PM
    #3466
    TheCompensator
    I plan on using the truck for moderate off roading. simple overland back country type use. not racing or anything. the bumper is being considered to help with any front clearance issues.
    I saw that you are using ICONs suspension system on your tundra. do you prefer those compared to FOX? And for clarification is the 2.0 and 2.5 the rating of the spring for what it can handle or its it just a generation newer?
    and budget is not important. I'm just going to do it right the first time and not skip out on anything. not a patient dude.
  17. Oct 8, 2024 at 8:22 PM
    #3467
    GreatBasinTundra
    GreatBasinTundra Beer Me!
    Reno, NV
    2020 Tundra SR5 DC
    Kings f/r, TC UCAs, RCI skids, RCI sliders, C4 bumpers f/r, Warn 12s winch, 35s on 17” Rebounds, softopper, wet okole covers
    Spring rate is completely separate from the shock body. The 2.5 has a larger shock body(.5” larger than 2.0), increased oil capacity and larger piston. For the Tundra with 37s the 2.0 will be getting worked harder than the 2.5. The spring rate will come in to play with or without the bumper. Again, with extra weight the 2.0 will have to work harder even with the properly weighted coil. FWIW, I run Kings with a 2.5 shock body, 650 lbs springs with belly skids a front bumper and winch (still on 35s)
  18. Oct 23, 2024 at 9:25 AM
    #3468
    mdtwyne
    mdtwyne New Member
    2012 RCSB 5.7 4x4
    @sea_weathered - What is that front bumper? Looks super subtle and OEM while still giving more clearance, nice. Thank you!
  19. Oct 29, 2024 at 12:21 AM
    #3469
    sea_weathered
    sea_weathered New Member
    Pacific Ocean
    2018 DC Adventure Chuck Wagon
  20. Oct 29, 2024 at 5:46 PM
    #3470
    Deaner
    Deaner New Member
    Dean
    The Mac
    2010 Rock Warrior
    Getting ready for those DIRTYs! Highly considering the Mickey Thompson Baja Boss A/Ts. Good reviews in another thread.
  21. Oct 29, 2024 at 7:02 PM
    #3471
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Great tire for sure
    Deaner[QUOTED] likes this.
  22. Oct 29, 2024 at 7:25 PM
    #3472
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    #biased
  23. Oct 30, 2024 at 9:27 AM
    #3473
    Deaner
    Deaner New Member
    Dean
    The Mac
    2010 Rock Warrior
    37s on order! Mount and balance very soon! Excited to join the club!
    :spending:
  24. Nov 1, 2024 at 3:03 PM
    #3474
    Deaner
    Deaner New Member
    Dean
    The Mac
    2010 Rock Warrior
    I know you got these Mickey Thompsons a while ago now. I'm making my way through the whole thread again. Are these the M/Ts or A/Ts? How are you liking them?
  25. Nov 1, 2024 at 3:46 PM
    #3475
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    MT, and Rey only advocates for them. Lol
    Deaner[QUOTED] and reywcms like this.
  26. Nov 1, 2024 at 3:58 PM
    #3476
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Yep, on my fresh set again. Love them won’t run another tire on my rig. Mine are the MT
  27. Nov 1, 2024 at 5:46 PM
    #3477
    Deaner
    Deaner New Member
    Dean
    The Mac
    2010 Rock Warrior
    Haha I've been reading a few threads of people swearing their loyalty to Mickey.
    Nice man. I just ordered the A/Ts. Other than being a great tire, they look killer!
  28. Nov 1, 2024 at 8:28 PM
    #3478
    Orange 2017
    Orange 2017 New Member
    2017 lifted and supercharged
    New tires for the tundra, it was time to replace the 7 year old procomps
    Mountun Goat and Deaner like this.
  29. Nov 1, 2024 at 8:29 PM
    #3479
    Orange 2017
  30. Nov 3, 2024 at 5:47 AM
    #3480
    Deaner
    Deaner New Member
    Dean
    The Mac
    2010 Rock Warrior
    Glad to see another 2nd Gen in here. Looks great!
