Removing 1st and second oil pan.
Discussion in '1st Gen Tundras (2000-2006)' started by mdfish97, Oct 30, 2024.
  1. Oct 30, 2024 at 1:42 PM
    mdfish97
    mdfish97 [OP] New Member
    2006 Toyota Tundra 4.7L 4x4
    Recently got a 06 4.7 4x4 tundra with a hole in both oil pans. Don’t know if it was internal or external that caused it, but aparrently it happened on the freeway. I want to pull both pans off, potentially replace them if there is no/minimal damage to the crankshaft, bearings, and all the other good stuff in there. I’ve only found two videos on the internet of people doing this. One guy drops the whole front axle and another guy lifts the engine and puts a block of wood on the frame and harmonic balancer. I am just wondering what the best/quickest/easiest way to go about this would be? Whatever the method is, I have the tools,jacks, lifts to do it.
  2. Oct 30, 2024 at 2:07 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Having to pull the pan/pans is very uncommon as they don't leak often, seeing as you have holes it's a bit of a rarity. You may be the one to do it and document your findings.
  3. Oct 30, 2024 at 2:12 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Gonna go ahead & imagine that a rod let loose, even though i've never personally heard of it happening.
  4. Oct 30, 2024 at 2:23 PM
    bfunke
    bfunke Tundra Curmudgeon
    What happens if you slowly turn it over with a wrench on the crank bolt.
    mdfish97[OP] likes this.
  5. Oct 30, 2024 at 2:24 PM
    mdfish97
    I am scared that that is the case. However, I’ve never heard of that as well and these are aircraft engines so I FEEL like it’s unlikely. There’s only 280k on this car.
  6. Oct 30, 2024 at 2:24 PM
    mdfish97
    I have not done that yet. I will today and let you guys know
  7. Oct 30, 2024 at 2:45 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Bore scope through the hole? See if it looks good before wasting time tearing it apart.
    mdfish97[OP], Bprose, bfunke and 2 others like this.
  8. Oct 30, 2024 at 3:32 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I had an 03 Durango V8 (318 I think) work vehicle, en route to a co-worker that needed help, I floored it, it threw a rod punching a hole in block. It sounded horrible but still drove for about 2 miles to my co-worker at about 90mph. Towed back to work from there. 25k miles on it, Dodge put a new long block in it and I had it back in service 1.5 weeks later.
  9. Oct 30, 2024 at 4:10 PM
    mdfish97
    If that’s the case then I will
  10. Oct 30, 2024 at 4:12 PM
    mdfish97
    I did this. It was hard to tell but it seemed like nothing was wrong. Couldn’t tell well but nothing immediately jumped out at me when I had the camera inside
    Weagle likes this.
  11. Oct 30, 2024 at 4:14 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    I had an Audi with an aluminum block...tossed a rod through the block (right where the engine mount was), the engine dropped out, and the rod exited through the hood. I did not try to repair it.
    Jack McCarthy likes this.
  12. Oct 30, 2024 at 4:21 PM
    mdfish97
    While we are here: here’s the v6 I’m about to finish. (Not the one that I started this thread on.) just finished rebuilding the transmission and putting a new torque converter in after transmission blew. (This is a different tundra, will be working on the other tundra later today)
  13. Oct 30, 2024 at 4:45 PM
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    This guy just recently pulled the oil pan to replace the oil pump and I'm going to do the same in a couple of years
    https://www.tundras.com/threads/alternator-mount-snap.148150/#post-3739992
    Having recently replaced my exhaust manifolds and installed headers I can say that when you disconnect the motor mounts, at least on my 2WD, there's plenty of room to jack it up. Me personally I used an engine hoist and will probably do the same for the oil pump. I just wasn't comfortable wedging blocks of wood in there
    not sure what the guy in that thread I linked above did but he seemed to get it accomplished in a reasonable period of time. there's also another video of someone doing it on a 4.7 in a 2nd Gen
  14. Oct 30, 2024 at 5:14 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    I'd like to see what exactly those holes look like
    Jack McCarthy and NickB_01TRD like this.
  15. Oct 31, 2024 at 11:31 AM
    mdfish97
    Can you send the YouTube link? I can’t pull it up on here
  16. Oct 31, 2024 at 11:31 AM
    mdfish97
    Coming today. Started raining hard yesterday and couldn’t get to it.
  17. Oct 31, 2024 at 11:51 AM
    Weagle
    Prattville, AL
    shifty` likes this.
  18. Oct 31, 2024 at 5:26 PM
    mdfish97
    Here is the holes and the truck. I turned the engine today and nothing happened except for as a certain point in the crank I could hear the piston that was closest to the whole hissing. It sounded like a healthy hissing of a piston with good compression.
    Weagle likes this.
  19. Oct 31, 2024 at 5:46 PM
    mdfish97
    So what do you guys think? Maybe caused externally and just change the pan?
  20. Oct 31, 2024 at 5:58 PM
    Assume nothing. Compression test and bore scope the cylinders.
  21. Oct 31, 2024 at 6:04 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Pull the pan & show us the carnage.
    FrenchToasty and Jack McCarthy like this.
  22. Oct 31, 2024 at 6:36 PM
    This.
    Weagle likes this.
  23. Oct 31, 2024 at 6:40 PM
    whodatschrome
    lots of dents
    I see what looks to be the lowest part of a bellhousing and bit of a transmission. And that transmission looks to have some large chunks missing from its housing (and not the pan)?
    Weagle likes this.
  24. Oct 31, 2024 at 6:42 PM
    Think the image is looking the other way. Towards the motor and that’s the lower and upper oil pan, right?
    whodatschrome[QUOTED] and Weagle like this.
  25. Oct 31, 2024 at 7:38 PM
    whodatschrome
    lots of dents
    Yup, you’re right. I must have been holding my phone backwards when i was looking at that pic.
    Weagle likes this.
  26. Nov 1, 2024 at 11:30 AM
    badass03taco
    badass03taco New Member
    2005 Limited Double Cab 4wd
    Is the hole an innie, or an outtie?
    Did something come out of the pan, or did something go into the pan? Should be able to determine between these two by the hole yes?
  27. Nov 1, 2024 at 11:36 AM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    I’m a professional mechanic so here’s my two cents…
    one: is the hole entry into the motor or exit from the motor? That’ll tell you if it’s internal
    two: borescope into the pan is a good idea, also checking each cylinder for damage is good. If the motor turns over easily you might be fine.
    three: I can send you the manual for pulling the pan from our diagnostic/repair manual but at least on the 2007 with the 4.7 it calls for a lot of hours (if you want the manual send me your vin)
    four: can you fill the motor up with oil without it all coming out the pan? If so do that and start the motor after you’ve checked everything, yeah it’ll push the oil out but it’ll let you hear for damage
  28. Nov 4, 2024 at 5:55 PM
    mdfish97
    I can’t tell if it’s entry or exit. I horoscopes the pan and everything seemed fine with what little I could see from the camera. Motor turned easily, haven’t horoscopes the cylinders through the spark plugs ( I will Wednesday) also on Wednesday I will get you the VIN. Also on Wednesday I will put a bit of oil in and start it. I already got the replacement pan from the wrecking yard. It was an Alaska car with the heat pads and they glued all the gaskets together so I ended up just ripping the whole engine out to get it in a position where I could easy tear off the pan. I don’t want to do all that with my car so the manual will be very much appreciated.
    joseph_womack[QUOTED] likes this.
  29. Nov 4, 2024 at 5:56 PM
    mdfish97
    I don’t know how to determine entry or exit by the hole.
  30. Nov 4, 2024 at 5:59 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Any bits bent inwards out outwards? Maybe not on the cast section, but on the steel?
    joseph_womack and Weagle like this.
