  1. Oct 30, 2024 at 2:19 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I added white tape to the rear of the light channel there to act as a reflector. Worked gud
    w666, Neo, FrenchToasty and 1 other person like this.
  2. Oct 30, 2024 at 3:20 AM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    I swear I tested the other socket and it had no current in either position, or during any position of the headlights. Must be designed for multiple uses. Am I correct?
  3. Oct 30, 2024 at 3:55 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Naw that light coms on with your dash lights. (Headlights)
    Did you have your dimmer know turned down?
    The Black turn socket? I have no idea what it does
    shifty` likes this.
  4. Oct 30, 2024 at 4:11 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    I very well may have, but I always run with it all the way up/bright.
    It was broken at that time and I had rigged it red neck style.
    May revisit that. Thx for the info :hattip:
  5. Oct 30, 2024 at 4:38 AM
    Make this into a thread so I can follow it. I wanna know why people say it's not worth the price. I wanna know if those uniball lowers eliminate the shit factory design. I have questions.
  6. Oct 30, 2024 at 4:51 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I found some answers. Also Rusty has some uniball UCAs he's looking to sell. MCM Fab. Figured you might be interested.
    https://youtu.be/dE_LiLHPNNE?si=enFooBbpMK-33-Qk
    BroHon and whodatschrome like this.
  7. Oct 30, 2024 at 8:20 AM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    You have to honestly ask yourself, what’s the ultimate goal for my rig?…trail king?…starbucks queen? Are you simply after a bit more lift height, and if so how much? I’ve spent thousands in the past on my jeep’s suspension so i’m not judging. But the tundra IFS platform cost so much dang $$$$ just to get a decent quality suspension and still not get very much ride height increase or suspension travel.
    Anything uniball are more or less racecar parts and will automatically take more maintenance. Make sure to have multiple bottles of Tri-Flow around to keep them quiet. I will have to say that all those parts are pretty sweet looking.
  8. Oct 30, 2024 at 8:29 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
  9. Oct 30, 2024 at 8:37 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Yeah this is my trail rig, my dirty girl. :thumbsup::hearteyes:
    She needs new LCA bushings and I been wanting Solo LCAs since they came out like 2-3 years ago. The uniball lowers are for both piece of mind and because apparently replacing the OEM LBJs on Solo LCAs is a PITA. Luckily my bro in law works at the local Ace Hardware, about a mile away. Coincidentally that's the only place in town that has TriFlow and he can give me a discount. Thanks for the tip. :hattip:
    These parts should go real well with my SPC uppers and King coil overs. This is all culminating in what has been a long game plan toward 35's, 17's, and big brakes.
    I'm going to install my 4crawler 1" body lift soon enough. Once I've got everything install and dialed in, I'll let my bank account recover for a few months until the next big sales hit and buy five Koenig wheels, five 35x10.5r17 (or maybe 35x11.5r17) and the parts for the GX brake upgrade.
    Pretty soon I'll be adding a leaf to my Alcan leaf packs, along with a 1" lift block. Then once another big sale hits I'll upgrade the rear shocks to Kings and see if I can bribe one of my fabricator buddies to do a shock relocation and any additional cutting/welding necessary to make the 35's fit.
    :yes::benchpress:
  10. Oct 30, 2024 at 8:43 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    G_unit3000 likes this.
  11. Oct 30, 2024 at 8:45 AM
    See, here's the point I'm at. My truck isn't a daily. Hasn't been in a long ass time. And if I'm going out and about, I'm more than likely taking the Vic. I also don't care what it drives like on the street. I had solid subframe bushings and solid motor mounts in the SHO. I'll take function over comfort all day long and twice on Sunday. But that begs the question: are uniballs any worse comfort wise, or just more maintenance? I'll shoot some lube in em every oil change. That's only once a year anyways. I don't see a downside besides price. If it helps me offroad that's all I care about.
    Actually, @inv3ctiv3 just wrapped up his suspension build which is exactly what I want. I'm pretty sure he just got in my head and copy/pasted it.
    JakeJake, BroHon, shifty` and 3 others like this.
  12. Oct 30, 2024 at 9:24 AM
    inv3ctiv3
    inv3ctiv3 New Member
    Jim Bob
    I've had TC uppers and lowers on every truck I've owned. My Tacoma had LT for 70k miles and uni-ball TC uppers for over 100k miles with no issues besides regular maintenance. I also never put trifle in my uni balls; if they got squeaky, I'd pour boiling water in them, but that was rare. The ball joint replacements are fantastic on these trucks, but they are very tight at first, so you gotta break them in a bit. Uniballs are not difficult; do basic maintenance, and you'll be fine. If you're hypersensitive to the occasional squeak or noise, then maybe stay away, but if you are offroad your truck, there's no better option.
  13. Oct 30, 2024 at 2:48 PM
    Dakillacore
    Georgia
    I'm not sure if this is common knowledge here, but I wanted to give it anyways just in case it helps someone.
    If you don't have a key fob or your key fob battery is dead, you can put your key in the door and twist it clockwise twice to unlock all of the doors. Twisting it once will unlock only the drivers side door and twice will unlock all doors.
  14. Oct 30, 2024 at 4:38 PM
    Dook55
    Dook55 RCLB Guy
    Montana
    One of my Tundras came with a key fob. I tossed it in a kitchen drawer on day one and haven't touched it since. One of the reasons I drive older vehicles is that I don't have to be burdened by unnecessary gadgety stuff that fills my pockets. All I need is one thin little key to get in and start it. I have never replaced the battery in that key.
    NUDRAT[OP] and MT-Tundra like this.
  15. Oct 30, 2024 at 5:10 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
  16. Oct 31, 2024 at 8:32 AM
    ToyotaDude, Dakillacore and BroHon like this.
  17. Oct 31, 2024 at 12:19 PM
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    This is the definition of hooptytrix :rofl:
    BroHon, Neo and 455h0le_dachshund like this.
  18. Oct 31, 2024 at 2:55 PM
    Neo
    Neo New Member
    Alabama
    Went to a local salvage yard today to see the 1st Gen Tundras and remaining parts available. Found a 2003 AC with several cool features that I didn't know were available. First, it had a power rear sliding window. The control was in the dash next to the dimmer pot.
    This same Tundra also had radio controls on the steering wheel.
  19. Oct 31, 2024 at 2:58 PM
    You swipe that switch?
    FrenchToasty and Jack McCarthy like this.
  20. Oct 31, 2024 at 3:08 PM
    starting to cook down a batch of ceremonial Halloween 2-alarm chili, three bean (of course), in celebration of my Texas homeboys who can’t get enough beans in their chili. I may add a bunch of hominy this year just for the hell of it.
  21. Oct 31, 2024 at 3:31 PM
    Neo
    Neo New Member
    Alabama
    Nah. I thought about it, but I figured actually wiring that feature up would be more trouble than it was worth. I was actually looking for a fog lamp push switch. There were only 2 x 1st Gen Tundras on the yard and the other had all blanks in the dash.
  22. Oct 31, 2024 at 3:43 PM
    JakeJake
    2000 Tundra AC 4X4
    Feeling a great relief tonight, it's all downhill from here.
  23. Oct 31, 2024 at 3:50 PM
    A step in the right direction…..
    bmf4069, G_unit3000, BroHon and 3 others like this.
  24. Oct 31, 2024 at 4:00 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    03+ had the fog switch on the signal stalk
    shifty` likes this.
  25. Oct 31, 2024 at 4:01 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    FTFY
  26. Oct 31, 2024 at 4:02 PM
    Neo
    Neo New Member
    Alabama
    Yep, it was there, but I was looking for the in-dash switch for the 2002.
  27. Oct 31, 2024 at 4:25 PM
    You should install the stalk. It should be pre wired there. The wires attached to the back of the button blank in your truck will be for the rear slider. Take advantage of the wires to the stalk.
  28. Oct 31, 2024 at 4:49 PM
    More like “Watch that last step!”.
  29. Oct 31, 2024 at 4:53 PM
    Someday, someone will ask you to build them a stairway to a bar called Heaven. That should be fun. The exit will consist of a slide for the intoxicated into a cab.
    bmf4069, shifty` and FrenchToasty like this.
  30. Oct 31, 2024 at 6:53 PM
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    I was in Brooks Hall. 4 stories IIRC.
